Some you can, some you can't. Look at the pulley shaft size, if the shaft sizes are the same, then have your local machine shop remove the original and put it on the new one. There are several manufacturers and several applications for those pumps. I use to buy one locally for $35, it would always have the larger dia. pulley, I would swap pulleys and be good to go.
