Gasket sealer on bell housing to gear box
MarkA
I am re-sealing the transmission to stop big oil leaks. The largest is the joint between the gear box and the bell housing. It looks like the box has been apart in the past, probably when the OD was changed. Which gaskets need sealant? And what sealant is good to use? It seams that the bell housing shouldn't use a sealant since it uses crush shims to hold the input shaft bearing/main shaft tight, and you don't want to increase the gap. It did have a light coat of regular Permatex on all gaskets previously...
Mark
Keoke
MarkA said:
I am re-sealing the transmission to stop big oil leaks. The largest is the joint between the gear box and the bell housing. It looks like the box has been apart in the past, probably when the OD was changed. Which gaskets need sealant?-------------- All of them.
And what sealant is good to use-
A light coat of Halomar should do you just fine.
Mark
--------------------------Fwiw--Keoke
John Loftus
I used hylomar on the gasket too. As Keoke says .. a light coat .. which is not always easy but keep spreading it around until it is thin and leave no clumps. Make sure you check/replace if necessary the rubber pad (limits the shift rod travel) that fits in the recess in the bell housing. BTW, most of my leaking was coming from the gearbox front seal (located in the bell housing) .. you are probably changing both front and rear seals but just thought I'd mention it.
Cheers,
John
Stretch
You might want to check torque after 24-48 hrs when using hylomar. I found it seems to permeate through fiber gaskets and relaxes bolt torque somewhat. Out of the tube it has a solvent that evaporates off over time.
M
MarkA
Hi John,
I thought that the leaking was comming from the front seal and wicking. But after looking inside the bell housing, the front seal was not the major source (although a contributor). The larger leak was at the bell housing to gear box joint. I am replacing both shaft seals, all gaskets, and the mounts and bushings. I didn't see the shift rod rubber pad. I will check for it...
Thanks,
Mark
M
MarkA
Hi John,
When I got home, I checked it out. It is there, full of oil, and hard. Should the pad be hard or a bit soft. It is softer that the metal itself, but...
What material did you use for a replacement pad? I am replacing the synchros this weekend with the help of a friend who is an offroad/racing transmission professional. Well, I'm reading the manual to him while he does the work! Is there anything else to look out for?
Thanks,
Mark
John Loftus
Hi Mark,
My apparently original pad was hard and cracked. I'm sure they were originally softer much like tire rubber that hardens with age. I cut a new shape from a some type of oil filter gasket that I had (wanted to make sure it was material that would stand up to hot automotive oil). You may need to cut two and assemble with RTV gasket adhesive to get the right thickness. I also used a little RTV to glue the pad into the recess to make sure it stayed put. This might have been overkill but I recall seeing evidence of contact cement on the old part and in the recess.
There are some tech articles at the following sites with some gearbox and OD overhaul tips.
team net healey tech tips
read the one called 'the wire trick'
OD rebuild
M
MarkA
Hey All,
I received a new gasket set from Moss yesterday. The new gaskets are a lot thicker than the originals. I am sure they will seal up better than the originals, but what other effect will the thickness have? Anyone have experience with them and their effects? Should I be looking for more shims before the re-sealing starts?
Thanks,
Mark
Dave Russell
Yoda - R.I.P
Hylomar has been through some confusing changes in ownership/distributors. There is a variety available which is solvent free thus non hardening see "advanced formula" below.
https://www.hylomar-usa.com/_resources/_html/products.html
It is similar to the Hylomar that Permatex was marketing a couple of years ago.
Stretch
I appreciate the info on hylomar. I used it on my transmission with high expections of stopping numerous leaks. You can imagine my disappointment after pulling the transmission, rebuilding it and then having leakage again at most joints, using new gaskets and hylomar exclusively. Had I know it came from the 1960's....
Keoke
MarkA said:
Hey All,
I received a new gasket set from Moss yesterday. The new gaskets are a lot thicker than the originals.----
Yep,somtimes they be green too!
Of course they will.
but what other effect will the thickness have?--- None
Anyone have experience with them and their effects?----Every one that has rebuilt a tranny in the last 10 years
starts?--It will be OK just torque it up tight.
Thanks,
Mark
---------------------------Keoke-- /bcforum/images/%%GRAEMLIN_URL%%/cowboy.gif
KLUTZ Wedge Adding Blue Devil head gasket sealer Triumph 4
AUSMHLY BJ8 Transmission Gasket Sealer Austin Healey 18
D TR2/3/3A OD cover plate gasket sealer. Triumph 17
B Gasket Sealer on Intake/Exhaust Manifold Gasket. Austin Healey 7
T TR4/4A Head gasket sealer question Triumph 7
KVH General Tech Gasket Sealer and Sealants Triumph 6
S TR2/3/3A copper gasket sealer and push rods Triumph 10
S TR2/3/3A gasket sealer for the bear plate Triumph 7
M Water Pump Gasket & Sealer Spridgets 10
CinneaghTR Oil Pan Gasket Sealer? Triumph 14
V Valve cover gasket & sealer??? Spridgets 11
D Gasket sealer British Motor Corp 2
T TR6 TR6 water pump gasket - also use sealer as well? Triumph 9
B What Gasket Sealer to Use on Engine Parts? Spridgets 8
S Timing cover gasket sealer Spridgets 6
J Head Gasket Sealer Spridgets 9
L Does anyone use gasket sealer on the oil pan? Austin Healey 2
C Gasket Sealer Triumph 5
T TR6 TR6 water pump installation - use gasket sealer Triumph 7
C Exhaust/Intake gasket sealer? Austin Healey 4
K TR2/3/3A Is it possible for an intake manifold gasket leak.... Triumph 9
K TR2/3/3A Update on the head gasket repair......something is not right/ Triumph 5
K TR2/3/3A New head gasket is installed.....did a compression check motor cold. Triumph 4
J Spitfire Payen Head Gasket -which way up ? Triumph 6
K TR2/3/3A Applying the Permatex copper gasket spray to the head gasket? Triumph 6
sim 948 aluminum head gasket Spridgets 2
K TR2/3/3A head gasket repair wire Randall Triumph 1
tinman58 TR2/3/3A Head Gasket Triumph 15
K TR2/3/3A Failed intake manifold gasket? Triumph 2
K TR2/3/3A Heavily carboned spark plugs in relation to a failed FO8 gasket? Triumph 12
K TR2/3/3A Update on the blown head gasket Triumph 33
K TR2/3/3A Bad news...blown head gasket??? Triumph 15
RJS TR4/4A Fuel Pump Gasket Triumph 8
kodpkd Valve Cover Gasket - Don't do this! Austin Healey 14
AUSMHLY Engine Flush After Head Gasket Leak Austin Healey 19
KVH General Tech Head Gasket Sealant Triumph 4
KVH General Tech Permatex Aviation Form a Gasket; Permatex Ultra Gray Triumph 12
P MGB Zenith water choke gasket needed MG 4
T TR2/3/3A tr3 head gasket Triumph 38
AUSMHLY BJ8 Transmission Gasket Austin Healey 0
G Valve Cover Gasket Silicone Adhesive Austin Healey 5
DrEntropy MGB Head gasket R&R goes on... MG 13
tahoe healey Cork Gasket Prep Austin Healey 17
LAW75 Timing Chain Cover Gasket Austin Healey 12
Joel Lester TR2/3/3A Advice for which head gasket material is best Triumph 8
Csarneson Head Gasket Seal Austin Healey 6
Tr3aguy TR2/3/3A Gasket part way off Triumph 10
B Bonnet hinge gasket Spridgets 10
