MGB What does MGB MGBVC mean?
No, didn't get an answer to that yet. Or if/when the engine was rebuilt, what carbs, manifold, headers, exhaust system, how old the tires are etc. I emailed him a list of questions.
[ QUOTE ]
...As for rust on the car there is none that we could find.
[/ QUOTE ]
My $0.02: That's an interesting comment from the seller...since there's obvious rust (not "dirt from being stored") in several of the photos. I'd be cautious based on this characterization. That said, it doesn't look bad, based on the photos. Some non-stock-looking stuff on the engine, as another poster commented.
I think it's odd that there's only one picture of the sills and it's at an angle that's hard to see.
I've looked at the pictures closely and re-read his email and decided something about this car just 'isn't right.' It's nothing I can put my finger on exactly, but I'm not going to pursue this one any more, unless the bid stays VERY low. I am going to follow up on the LE near me though.
Something isn't right alright! Why would a '71 have a single carb? I'd guess it's because that's an engine out of of an Austin Marina!! As far as the automatic...I'll bet that came from a Marina as well. The shifter doesn't look like an MGB automatic shifter to me. I could be wrong though, because I can only recall seeing one in pictures....
Possibly why
[ QUOTE ]
There are pictures of the engine; however I was not able to locate a serial number on the engine.
[/ QUOTE ]
Casting on the side indicates an 1800cc engine thought, any difference in the engin itself?
Hmmm. Bid's up to $3550, reserve not met, 4 days left on the auction.
As Joe said, the carb isn't right and the engine should be maroon, not black. I'd suspect either a Leyland Marina engine (as he said) or a later model B single-carb engine. Both are far less powerful than the stock twin-SU engine. And that automatic shift console is totally wrong, never appeared in an MG. This one looks like what my Dad used to call "spare parts flying in formation".
I'd run away from this one.
i saw a nice looking rubber bumper "B" for sale at a tire shop on South Penn in Oklahoma City last weekend. Asking 6K, I didn't see any rust, body looked good and paint was a shiny orange. can go back for a phone number if interested.
R MGB MGB does not start when hot MG 6
drooartz MGB Does this MGB center muffler look right to you? MG 10
Thor MGB Does this look like tonneau for mgb? MG 9
N MGB How does on tell if an MGB has Overdrive MG 7
Thor MGB How does driving a mgb compare to midget 1500 MG 10
L What does this column switch do? Spridgets 4
K TR2/3/3A Does this fitting need a Whitworth wrench? Triumph 10
J MGB HELP, my horn does not work! MG 8
R TR2/3/3A Does anyone know the paint Code for british Racing Green for a 1954 TR-2? Triumph 12
S TR2/3/3A overdrive does not function Triumph 45
Bayless How does '67 Sprite top attach to body? Spridgets 3
V MGB Never occurred to me that my '66 would be positive ground. Does the presence of an alternator show that it's been converted? MG 22
B General MG Does odometer record when flat towing. MG 5
Fanch00 Does it make sense to just paint the panels? Austin Healey 3
T Does a car lift exist that could be placed against a wall, and the car rolled sideways onto it? Spridgets 16
TomMull TR2/3/3A rear mount does not line up Triumph 10
K TR2/3/3A Cleaning the Solenoid contacts? Does pressing the small chrome "button" release the bake light fixture to access the contacts for cleaning? Triumph 7
JPSmit Fuel tank sender - how does it work? Spridgets 4
Got_All_4 TR5/TR250 New Hazard Relays Does Anyone know How to Hook Up Triumph 7
steveg TR6 Metal Dash - does anyone make one? Triumph 13
NutmegCT Does this ad seem a bit peculiar? Other Cars 8
S TR2/3/3A What does a condenser do? Triumph 21
pbraun How much does a BJ7 or 8 transmission weigh? Austin Healey 3
D Does this count as British car? Spotted 18
BN6_2197 How does the flasher unit work Austin Healey 4
J TR6 Does this sound ok to you? Triumph 5
BN6_2197 Analyzing Problem of Flasher Unit [warning lamp does not work] Austin Healey 10
B Does anyone still make or sell a quality condenser? Austin Healey 14
T Which Lucas dynamo does a BJ7 have? A C45?? Austin Healey 6
T TR2/3/3A Does this sound like fuel pump problem? Triumph 15
S TR2/3/3A The big brass drain plug on the OD does not thread in easily Triumph 9
F How does overdrive Annulus effect speedometer Austin Healey 10
T General Tech Transmission Countershaft - What Car Does This Fit? Triumph 1
D Does a BJ 8 need a vented fuel cap? Austin Healey 4
RAC68 How does a 12 Volt Alternator charge a battery to read 18+ Volts Austin Healey 8
drooartz The correct tool does make it easier [fill steering rack] Spridgets 4
B MGA What does this founder mark mean? MG 4
D TR2/3/3A Gas tank does not fit! Triumph 4
Got_All_4 TR6 How does this steering lock come off Triumph 9
Gerry M TR6 Overdrive does not engage Triumph 13
HighAltitudeTR3 TR2/3/3A How does this sound?! [Video] Triumph 8
C TR6 ZS 175 What does this screw do? Triumph 2
HealeyRick Who Knew Martin Jansen Does Bikes? Austin Healey 0
Rut How much does a 1275 weigh? Spridgets 8
JPSmit Fuek Tank Sender - does this seem right to you? Spridgets 3
HighAltitudeTR3 TR2/3/3A How does this sound?? Triumph 6
Popeye TR4/4A Found this odd long bolt in my fuel tank... Does anyone know what it is? Triumph 17
simon1966 Does taking a stock BN1 and adding M bits increase its value? Austin Healey 10
D TR4/4A how hot does the timimg chain cover get? Triumph 15
D TR4/4A Does a bolt legend exist? Triumph 3
