What Connector for this sensor? [TKC5050]
DNK
Looks correct
Standard 2 connector in these cars
M XJS Fuel Injector, Air Temp Sensor, Water Temp Sensor Harness Connector Replacement Jaguar 0
TheRealDestrux MGB Unknown connector on alternator MG 6
fpstude TR4/4A Fuel Pipes Connector Triumph 4
K TR2/3/3A Gas tank pipe connector? Triumph 6
K TR2/3/3A Gas tank to pipe connector.... Triumph 1
GTP1960 TR2/3/3A SU, H6 carb vacuum line connector? Triumph 2
I TR6 Source for this electrical connector Triumph 4
M Wiper motor connector removal - 1275 Midget Spridgets 4
L Separating Lucar Spade connector Spridgets 9
rlich8 TR4/4A TR4A Brake Master Connector Leak Triumph 2
L TR2/3/3A 3-way connector TR3A - wiring loom Triumph 2
Stinger TR4/4A TR4A Starter Solenoid Connector Triumph 2
tweety Alternator wiring connector, Sources? Spridgets 4
I Bugeye electrical connector where can I get these? Spridgets 18
CinneaghTR TR4/4A TR4A Horn: 2 wires into 1 connector? Triumph 9
T electrical connector Spridgets 5
tahoe healey Spark plug connector and dizzy repair Austin Healey 2
Tinkerman TR2/3/3A TR3 A 5 Way Connector Question ? Triumph 9
jhorton3 Multi-pin Electrical Connector Spridgets 9
1965_MGB Lucar [bullet] connector crimp tool? Restoration & Tools 14
K TR2/3/3A TR3..Red light On...Dynamo Connector Triumph 5
DNK Bulk Head Connector. Triumph 7
P MGB Vacuum tube connector for 72 MGB melted... MG 10
N WIRING HARNESS CONNECTOR PLACEMENT Austin Healey 7
MrPandy TR6 Mystery TR6 connector... Triumph 5
MrPandy TR6 Mystery connector - TR6 Triumph 2
B Help! Flametrap connector source?? MG 5
L 1994 XJ12 Throttle Position Sensor unavailable, alternatives ? Jaguar 1
A MGB Stuck water temperature sensor MG 26
R Thermal sensor Spridgets 2
G Thermo Fan Sensor Austin Healey 5
Basil DIL's O2 sensor problem - SOLVED Other Cars 11
B Temperature Sensor Removal Austin Healey 10
R Temperature sensor Help me Austin Healey 18
N BT7 water temperature sensor removal Austin Healey 13
DugMoney Need Advice - Moving Temp Gauge Sensor 1275 Spridgets 3
S BJ7 frozen temperature sensor to block Austin Healey 17
JFS TR2/3/3A Temp Sensor Removal Triumph 6
55modified Radiator sensor thread type size needed for bn1 Austin Healey 12
steveg Has anyone used a knock sensor? Austin Healey 0
K TR2/3/3A Temperature sensor size where it fits in the housing? Triumph 4
sim 02 sensor question Spridgets 13
Jim_Gruber Temp sensor wire spring re attachment to probe Spridgets 3
C How to remove temp sensor at block? Austin Healey 16
Rut Temp sensor Spridgets 9
DanLewis Thermostatic fan switch that fits Bugeye radiator temperature sensor hole? Spridgets 19
jhorton3 Brake Pressure Sensor Options Spridgets 3
R wide band O2 sensor recommendations? Spridgets 10
luke44 TR2/3/3A TR3 Water Temp Sensor Installation Problem Triumph 37
martx-5 SU carbs and the Oxygen Sensor Triumph 2
