Help! Flametrap connector source??
Bill Tubbs
99% success in re-installing my original carb gear to my 79 Midget. One connector drove me crazy until I discovered the remnants on the underside of the carburetor. Does anyone know where I can get a replacement for this thing? It appears to be made of brass and is the connector from the distributor to the flametrap and then to the carburetor. It's supposed to just plug into the bottom apparently, but the previous owned glued it in and then broke it trying to get it out for his Weber conversion.
Here are a couple of pictures of it. The serrations are due to my visegrips pulling it out ;-)
https://tubbs.cc/mg/flame1.jpg
https://tubbs.cc/mg/flame2.jpg
Thanks.
Bill Tubbs
https://tubbs.cc/mg
B
Bill Tubbs
Okay... no responses on this one so I broke down and soldered the heck out of the two broken pieces. Doesn't look pretty, but there are no leaks and it will probably work.
B
Bill Tubbs
Whoops. Spoke too soon. The soldering didn't hold so I'm back to looking for the original part again. I was thinking about replacing the whole part with a piece of fuel line, but as I started to fit it I realized that it would be right over the manifold and probably get a little hot. So... WHERE in the heck can I get that replacement connector??
Help!!!!!
Bill
B
Bill Tubbs
That was suggested to me in an email but I have no idea how to do brazing. I wonder if I could take it to a radiator shop and ask them to do it... another issue is where to find the exact diameter tubing. I'm sure this stuff is brass and not copper, right?
CraigFL
You can braze with MAPP Gas -- a different bottle for a propane torch. If you don't feel confident about doing it then a radiator shop might be ok. You'll probably have to fabricate the piece -- use brass or stainless...
B TR4/4A Some Help with Setting Distributor Triumph 47
N Wanted Help with car identification Other British Classifieds 2
I MGB Help! What is this part for? MG 13
P Please help identify this tourer Spotted 13
angelfj1 TR5/TR250 TR250 Need Help identifying wires (2 - black) feeding starting solenoid Triumph 6
C MGB More Weber help needed MG 27
V 96 Chimera help needed TVR 1
V Help with identifying morris eight Other British Cars 12
J MGB help, turn signals do not work MG 3
J MGB HELP, my horn does not work! MG 8
I MGB Alternator help MG 0
Southwarks TR2/3/3A TR2 door help! Triumph 2
P General Tech Positive Earth?? Very confused. A little help? Triumph 19
Texas TR3 TR2/3/3A Convertible top webbing installation help? Triumph 5
apbos The next rabbit hole. Help ID the chassis. Racing 27
R Help With Spridget Speedometers Spridgets 4
apbos Help Identify this car chassis Racing 20
tr6web TR6 Sputtering help Triumph 6
R TR6 Help: Brake Part Source or …. ? Triumph 1
B Help for Old Men Restoration & Tools 15
Basil Admn Note Our neighbors need emergency help Triumph 0
Basil Our neighbors need emergency help Spridgets 0
Basil Admin Note Our neighbors need emergency help MG 0
Basil Emergency help requested for our neighbors Austin Healey 0
B TR6 Help with color and color code / paint recommendation Triumph 4
JohnGone MGB Help getting my 1980 MGB to pass CA smog test MG 19
K TR6 Need help with Mimosa Yellow Paint Triumph 1
Bayless Help please installing bonnet release cable Spridgets 8
T TR2/3/3A Help - Cooling system problem Triumph 7
D TR6 Help with tr6 engine diagnosis Triumph 11
H Wanted MK2 - Please, help needed Jaguar Classifieds 60
D Spitfire 1980 California Spitfire, Help Figuring What To Do With It? Triumph 15
I Bugeye oil leak help Spridgets 4
A TR6 Carburetor help Triumph 5
Darwin GT6 Diff Help Please Triumph 2
J TR2/3/3A Need help with a value for this TR3 please Triumph 6
M Need help removing the pinion assembly from a late 1275 steering rack Spridgets 7
V VAUXHALL Astra diesel 1.7cdti loss of power 2012. HELP. Other British Cars 1
jehuie Help...replaced my alternator and now my water pump is leaking. Spridgets 16
algot1901 HELP with wheel bearings Other British Cars 1
K TR2/3/3A The guide bolts to help gearbox install? Triumph 19
S MGB Mgb with nissan cylinder head. I am a new member, introduction and help MG 1
T Lotus 7 - help identifying parts Lotus 5
TheRealDestrux MGB 1977 MG MGB need help putting top down MG 1
6 Electrical Help Please Spridgets 7
B MGB Help MG 2
P Help with torquing bolts Restoration & Tools 3
E GT6 Help electrical guru needed Triumph 4
C TR2/3/3A So many newbie questions any help is appreciated! Triumph 6
