Voltage Regulator
JoeBeets
The ammeter on my 61 TR3 constantly reads around 30 amps at anything over 1200 rpm. I suspect my voltage regulator is not cutting out and I'd like to test it, but I cannot find anything written on how to do it. Can someone help. Is it just easier to replace it? Thanks.
Kurtis
[ QUOTE ]
[/ QUOTE ]
The Bently manual has a very good step-by-step procedure for testing/adjusting the control box settings. I tried to follow it when I experienced similar problems with the voltage control box on my TR4. After completely screwing the thing up, I ended up buying a new one - sparks and magic, bah!
If don't find the procedure elsewhere, I can scan the appropriate sections of the manual for you this evening (it will be late) and shoot them to you.
Kurtis
I sent you an e-mail. Good luck!
Tinkerman
Hi Kurtis:
I wouldn't mind having the info also. I am doing a frame off on a 61 3-A. I bought a basket case so it is all new unploud ground for me.
Regards, Tinkerman. tinkerman@citlink.net
Sopwith_Camel MGB voltage regulator MG 11
7 What voltage regulator? Other Cars 21
L BUG EYE WHAT CAUSES A VOLTAGE REGULATOR TO STICK ON WHEN U TURN KEY OFF Spridgets 3
S TR2/3/3A grounding the voltage regulator Triumph 14
Jim_Gruber Voltage Regulator Question Spridgets 4
HighAltitudeTR3 TR2/3/3A Battery/Control Box/Voltage Regulator Triumph 20
S TR4/4A voltage regulator - digital Triumph 13
TulsaFred Moss Lucas Control Box/voltage regulator Spridgets 4
N TR4/4A voltage regulator Triumph 5
C Voltage regulator Austin Healey 12
F TR2/3/3A Voltage Regulator and Charging issues Triumph 11
R RB 106/2 12V Voltage Regulator Needed Austin Healey 1
R TR6 How does one test the voltage regulator in th late TR6? Triumph 2
S TR2/3/3A Generator and voltage regulator on a tr3 Triumph 17
M pre adjusted voltage regulator Spridgets 4
I Anyone have a bad voltage regulator for a bugeye? Spridgets 2
H Tr 3 Voltage regulator Triumph 6
J TR4/4A TR4A voltage regulator help Triumph 16
Twosheds Voltage Regulator Lecture Triumph 11
M TR2/3/3A tr-3a Voltage Regulator Triumph 25
M voltage regulator adjustment hard Spridgets 18
M voltage regulator=cause draw Spridgets 10
KVH "Hot" Wires at the Voltage Regulator Triumph 11
B Fried voltage regulator Spridgets 2
S TR2/3/3A Tr3 Voltage regulator Triumph 15
tinman58 TR2/3/3A 2010 TR3 voltage regulator Triumph 20
AUSMHLY BJ8 Voltage Regulator...adjustable? Austin Healey 5
H TR2/3/3A TR3A Lucas Voltage Regulator Adjustment Triumph 1
H TR2/3/3A Tr3A Voltage Regulator Triumph 2
MGTF1250Dave Solid State Voltage Regulator Up-date Triumph 7
MGTF1250Dave Solid State Voltage Regulator Conversion Triumph 9
Moseso Denso Alt Voltage Regulator Triumph 2
R voltage regulator[control box] labeling problem Austin Healey 9
71TR6 16ACR Internal Voltage Regulator Triumph 3
heliguy Voltage Regulator MG 7
S voltage regulator Triumph 18
G Voltage regulator on an 8 Triumph 5
6 How to Adjust Voltage Regulator Spridgets 0
healeyboz Voltage Regulator Spridgets 12
Timd Voltage Regulator Install Spridgets 0
healeynut RB340 Voltage Regulator Puzzler ? Austin Healey 5
N Voltage Regulator Issue Spridgets 3
neilh Instrument voltage regulator - 79 Midget Spridgets 2
D voltage regulator 68 sprite Spridgets 2
bighly Wanted, Voltage regulator housing Austin Healey 0
H Voltage Regulator Jaguar 1
R generator/voltage regulator Other British Cars 2
L Voltage Regulator Adjustments??? Bad Generator??? Spridgets 10
J BJ8 Voltage Regulator Austin Healey 14
G Voltage Regulator - Europa S2 Lotus 2
