Voltage regulator on an 8
G
Mine blew out on the way home yesterday - or at least I hope that's what it is. Fuel and heat pegged full, charge at zero. Since I got home at 2am, I'm not fully compos, so looking is out of the question. It would of course be unreasonable to expect me to wait until I buy the manual.
With that as a given, does anyone know:
1. where it is?
2. if replacements are available?
3. if i have it right - it's not something stupid like a fuse?
DNK
Alan,I have read that is a common occurance. Has happened to me a couple of times,though I have never seen the fuel do it. I replaced my Alt. and it hasn't been on the oad since so I can't tell you if it fixed it.
G
It sorta fixed itself this morning. It then happened again 2 hours later. Oh and I found out that there isn't a regulator per se.
Mickey Richaud
Alan -
Mine acted similarly. Found that it was a bad ground. In my case, the ground strap from the engine to the body - scraped the new paint at the contact point, and added dielectric grease. No problems since.
I know it doesn't make sense!
So, how do you like the 8, aside from this?
Mickey
G
It's a nice GT. It could be a nice all rounder, but it needs work.
Mine needs stiffer springs and better shocks. It wallows over bumps and it didn't like NJ and Pa roads one little bit - potholes upset it badly.
It also needs tuning - it's running pig rich, has a hard start and has nothing power wise after 110 (or about 4500rpm). I found this out in Maryland when a kid in a Supra 300ZX TT decided he wanted to blow by me. He was a bit shocked when he couldn't...
There are some other issues - the power steering is leaking, the top has a split and the seats need foam - badly.
Other than that, it's not a bad car. It eats highway.
It also gets just a hair under 25mpg at 80.
With a bit of work it'll be a great car.
Mickey Richaud
The uprated spring kit will do wonders for the handling. Ride's a bit firmer, but still comfy.
And it IS nice getting that kind of mileage, indeed! I've managed to pinch 28 out of mine, while still having fun with it. :wink:
Sopwith_Camel MGB voltage regulator MG 11
7 What voltage regulator? Other Cars 21
L BUG EYE WHAT CAUSES A VOLTAGE REGULATOR TO STICK ON WHEN U TURN KEY OFF Spridgets 3
S TR2/3/3A grounding the voltage regulator Triumph 14
Jim_Gruber Voltage Regulator Question Spridgets 4
HighAltitudeTR3 TR2/3/3A Battery/Control Box/Voltage Regulator Triumph 20
S TR4/4A voltage regulator - digital Triumph 13
TulsaFred Moss Lucas Control Box/voltage regulator Spridgets 4
N TR4/4A voltage regulator Triumph 5
C Voltage regulator Austin Healey 12
F TR2/3/3A Voltage Regulator and Charging issues Triumph 11
R RB 106/2 12V Voltage Regulator Needed Austin Healey 1
R TR6 How does one test the voltage regulator in th late TR6? Triumph 2
S TR2/3/3A Generator and voltage regulator on a tr3 Triumph 17
M pre adjusted voltage regulator Spridgets 4
I Anyone have a bad voltage regulator for a bugeye? Spridgets 2
H Tr 3 Voltage regulator Triumph 6
J TR4/4A TR4A voltage regulator help Triumph 16
Twosheds Voltage Regulator Lecture Triumph 11
M TR2/3/3A tr-3a Voltage Regulator Triumph 25
M voltage regulator adjustment hard Spridgets 18
M voltage regulator=cause draw Spridgets 10
KVH "Hot" Wires at the Voltage Regulator Triumph 11
B Fried voltage regulator Spridgets 2
S TR2/3/3A Tr3 Voltage regulator Triumph 15
tinman58 TR2/3/3A 2010 TR3 voltage regulator Triumph 20
AUSMHLY BJ8 Voltage Regulator...adjustable? Austin Healey 5
H TR2/3/3A TR3A Lucas Voltage Regulator Adjustment Triumph 1
H TR2/3/3A Tr3A Voltage Regulator Triumph 2
MGTF1250Dave Solid State Voltage Regulator Up-date Triumph 7
MGTF1250Dave Solid State Voltage Regulator Conversion Triumph 9
Moseso Denso Alt Voltage Regulator Triumph 2
R voltage regulator[control box] labeling problem Austin Healey 9
71TR6 16ACR Internal Voltage Regulator Triumph 3
heliguy Voltage Regulator MG 7
S voltage regulator Triumph 18
6 How to Adjust Voltage Regulator Spridgets 0
healeyboz Voltage Regulator Spridgets 12
Timd Voltage Regulator Install Spridgets 0
healeynut RB340 Voltage Regulator Puzzler ? Austin Healey 5
N Voltage Regulator Issue Spridgets 3
neilh Instrument voltage regulator - 79 Midget Spridgets 2
D voltage regulator 68 sprite Spridgets 2
J Voltage Regulator Triumph 5
bighly Wanted, Voltage regulator housing Austin Healey 0
H Voltage Regulator Jaguar 1
R generator/voltage regulator Other British Cars 2
L Voltage Regulator Adjustments??? Bad Generator??? Spridgets 10
J BJ8 Voltage Regulator Austin Healey 14
G Voltage Regulator - Europa S2 Lotus 2
