voltage regulator=cause draw
mightymidget
One of the reason I rewired the Midget I was searching for an electrical draw. I knew my regulator was not putting out. but I think it is the electrical draw.
As I finished installing all the new wiring under dash everthing was fine until I hooked 12V from my starter switch to the Voltage regulator, I got a terrible draw immediatally.
I am going to order a new regulator tomorrow from Moss. but is this resonable? Can a regulator have a dead short?
I have opening the regulator up for inspectionand there are no signs of shorts
jlaird
Yea can. I no nothing about them really, I consider them a remove and replace item.
Sarastro
The current from the battery goes through the regulator to the rest of the car. So, if you get a heavy draw when you hook up the regulator, it's not necessarily a problem in the regulator.
It's possible for the short to be inside the regulator, but pretty unlikely. Something would have to come loose, and I'd think you could see that easily when you took the top off.
jlaird
Ahh, Steve has spoken. Thanks Steve we all appreciate your wisdome on all things electrical.
jlaird
And Steve said "if you get a heavy draw when you hook up the regulator, it's <span style="color: #FF0000"><span style="font-weight: bold">not necessarily </span></span>a problem in the regulator."
Guess what, I would replace the regulator. I expect this is one of those cases where the prob is internal to the regulator.
Sarastro
Well, if that's what's happening, it seems pretty clearly to be the regulator. You really should be able to see where the problem is, though.
Did you look at the underside? There are a number of connections in that narrow space under the regulator, visible only when you take the whole thing off. It's not impossible that something is wrong there; then, it would be easy to short to the body.
But, in any case, if you've hooked up only the battery-to-regulator lead (A or A1 terminal, I forget which) and you get a large current when you do it, it can't be much else.
M
mightymidget
I am going to take a stab at it again tonight
From what I understand from web searching this is how the regulator for a early 1275 Midget is wired. Regulator part # 542-101 in Moss cat.
A
A1 Hot wire from Starter switch (Brown)
F Field to generator (small wire)
D big wire to generator (Brown yellow)
E Ground (Black wire I assume)
The E has thrown me, Has my research served me correctly. Currently my voltage regulator is not grounded. could that be my problem?
The_architect
Mightymidget
E is definitely ground, but I cannot say whether that is your problem (although things are generally grounded for a reason). To elaborate on what one of the previous posters was saying, you must make sure that the A and A1 terminals are not being accidentally grounded to the body. At least on my regulator these were bare wires on the underside of the regulator, so this is not out of the question.
That would give you a serious draw for sure!
You might find this pdf on the topic of voltage regulators to be helpful.
Voltage regulators 101
Best
Charlie
M
mightymidget
Well I should of had a clue when the wiring on the rest of the car was a mess,
It just looked right, the wires to the regulator. never assume
No more electrical draw.I removed all the wires from the voltage regulator, then removed VR from the car, inspected for shorts etc.. reinstalled VR and wired "correctly" and install a ground wire (that wasn't there before)
No more draw. to late here on the east coast to crank up and see if it is charging..........just hope generator and VR are OK from being wired wrong
Sarastro TR4/4A Exasperating experience with voltage regulators Triumph 3
wkilleffer MGB 1974 MGB SU fuel pump voltage issue MG 11
K TR2/3/3A TR3 with alternator conversion... red light stays on and low voltage on the voltmeter gauge? Triumph 1
Sopwith_Camel MGB voltage regulator MG 11
7 What voltage regulator? Other Cars 21
R TR6 No voltage at solenoid tap Triumph 7
L BUG EYE WHAT CAUSES A VOLTAGE REGULATOR TO STICK ON WHEN U TURN KEY OFF Spridgets 3
Kurtis TR4/4A Voltage Control Module Triumph 15
TAS525 TR2/3/3A Brand New Generator Low Voltage Triumph 25
K TR4/4A Voltage Stabalizer and Fuel Gauge Readings Triumph 5
K TR2/3/3A What vehicle is this Lucas voltage stabilizer from? Triumph 8
S TR2/3/3A grounding the voltage regulator Triumph 14
S TR2/3/3A voltage regulators gap and oxidation Triumph 10
T TR4/4A Why is the new voltage stabilizer I got marked with 'top"? Triumph 4
T TR2/3/3A Why is voltage stabilizer not needed for TR3 fuel gauge? Triumph 4
S TR4/4A voltage stabilizer Triumph 2
Jim_Gruber Voltage Regulator Question Spridgets 4
S TR4/4A Voltage stabilizer and cable routings? Triumph 5
HighAltitudeTR3 TR2/3/3A Battery/Control Box/Voltage Regulator Triumph 20
NutmegCT Voltage gauge Restoration & Tools 1
Bill_S TR4/4A Failing Voltage Stabilizers Triumph 1
S TR4/4A voltage regulator - digital Triumph 13
Mink TR4/4A Moss voltage stabilizer, part number 131-555 Triumph 15
TulsaFred Moss Lucas Control Box/voltage regulator Spridgets 4
N TR4/4A voltage regulator Triumph 5
C Voltage regulator Austin Healey 12
steveg Heater Blower voltage drop Austin Healey 8
M TR2/3/3A Voltage regulators Triumph 5
cmacmillan TR6 Losing voltage at + side of coil Triumph 12
F TR2/3/3A Voltage Regulator and Charging issues Triumph 11
M TR4/4A Voltage Stabilizer question. Triumph 10
R RB 106/2 12V Voltage Regulator Needed Austin Healey 1
Zimmycobra TR4/4A Question on Voltage Stablizer Triumph 6
R TR6 How does one test the voltage regulator in th late TR6? Triumph 2
Darrell_Walker High battery resting voltage - sign of imminent demise? Triumph 15
S TR2/3/3A Generator and voltage regulator on a tr3 Triumph 17
M pre adjusted voltage regulator Spridgets 4
I Anyone have a bad voltage regulator for a bugeye? Spridgets 2
H Tr 3 Voltage regulator Triumph 6
M TR4/4A Voltage Stabilizer TR4A. Triumph 14
6 Voltage Output Question Spridgets 3
Superwrench Voltage Reg Austin Healey 1
J TR4/4A TR4A voltage regulator help Triumph 16
G low voltage to right side turn signal Austin Healey 3
Bob Claffie Voltage stabilizer Triumph 10
A Headlight Voltage Drop MG 5
N DC voltage output f Austin Healey 2
G Only voltage gauge works Triumph 10
Twosheds Voltage Regulator Lecture Triumph 11
M TR2/3/3A tr-3a Voltage Regulator Triumph 25
