Valve cover gasket choices ?
Ed_K
I took my aluminum valve cover off today to check rocker arm clearances and the old cork gasket is no longer any good.
... Is a cork gasket the only choice available ?
Ed
I've never seen anything else available for a Healey, like neoprene(sp?).
I get a pretty long service life out of my rocker cover gasket; I only adhere it to the (aluminum) cover, and don't have any trouble with it sticking to the clean and dry head flange.
I think the secret is that the head flange is scraped of paint and wiped of oil prior to assembly. Just a thin smear of silicone to stick the cork gasket to the aluminum or steel cover.
Ed_K
Ed_K
Thanks Randy,
The old one has been through several off/on cycles and got deformed and then cracked apart. Neoprene (sp) is what I hoped might be available but apparently it isn't for our cars. A new cork one is on the way along with some stainless steel cap nuts and SS cup washers from V.B.
So you fasten the gasket to the cover, not the head as Dave R. had suggested in old posts ( makes a dam to contain the oil when the engine is running with the valve cover removed to check on rocker arms leaking excessive oil ) ?
Ed
GregW
Platinum
Ed
I think this just boils down to taste. I'm with Randy though, I'd rather clean up gushed oil than have cork fall inna' engine while I was scraping.
Patrick67BJ8
Once upon a time(mid 1970's) in a far away place called Jacksonville, Florida, I found a parts supplier(and a old one at that), who had about 6 "rubber" gaskets. I bought them all and sold them at a nice price.
steveg
It's usually considered good practice to glue the gasket to the removable part.
I've had good results gluing the rocker gasket to the rocker cover with Permatex, then placing the assembly on a piece of wax paper on a plate glass tabletop with a couple of books to weight it in place. Leave overnight--this allows the surface of the gasket to be perfectly flat.
kodpkd Valve Cover Gasket - Don't do this! Austin Healey 14
G Valve Cover Gasket Silicone Adhesive Austin Healey 5
vette Valve Cover Gasket Austin Healey 18
6inline Valve cover gasket woes Austin Healey 11
T TR6 TR6 Aluminum Valve Cover Gasket Triumph 3
K TR4/4A The "silicone type" valve cover gasket? Triumph 3
mgedit TR2/3/3A Justin Wagner Silicone Valve Cover Gasket Triumph 2
Gliderman8 TR6 Silicone valve cover gasket Triumph 4
Anthony_S TR2/3/3A TR3a valve cover gasket - checking clearances Triumph 8
M Preferred valve cover gasket Triumph 12
Westfield_XI Best valve cover gasket? Spridgets 22
V Valve cover gasket & sealer??? Spridgets 11
bighealeysource Replacing cork gasket on BJ8 valve cover Austin Healey 3
T Justin Wagner's Silicon Valve Cover Gasket Triumph 7
T Silicon valve cover gasket Triumph 17
angelfj1 Valve Cover Gasket - Too Thin? Triumph 15
T Valve cover gasket - sealant needed? Triumph 7
Brosky Wagner's Silicone Valve Cover Gasket Triumph 8
B Upgrading valve cover - gasket sealant question Triumph 15
roofman TR6 TR6 silicone valve cover gasket Triumph 9
roofman TR6 TR6 silicone valve cover gasket Triumph 2
Brosky New Silicone Valve Cover gasket arrived Triumph 26
S Leaky valve cover gasket Triumph 5
B Advice on installing a cork valve cover gasket.... Spridgets 8
P Valve Cover Gasket Austin Healey 5
mrv8q TR2/3/3A tr3 valve cover gasket Triumph 5
B TR6 TR6 Valve Cover Gasket Triumph 5
kodpkd For Sale Alloy valve cover for AH 100-6 3000 PRICE DROP! Austin Healey Classifieds 1
BillyB62 TR2/3/3A Anyone seen a valve cover like this Triumph 0
alexisrexx TR6 Oil Sludge in Valve Cover - Normal? Triumph 16
S Price check on TR3A valve cover Triumph Classifieds 0
D TR6 Valve cover paint Triumph 5
B TR4/4A TR3 valve cover on TR4A Triumph 4
Ripper01 For Sale TR-6 Valve Cover/ Cap Triumph Classifieds 0
K TR2/3/3A Plugged valve cover breather Cap? Triumph 4
K TR2/3/3A Valve cover breather cap? Triumph 5
AUSMHLY Rubber hoses; heater box and valve cover breather Austin Healey 2
C How best to restore red script on valve cover? Austin Healey 7
Northcoaster TR4/4A Lost info on person interested in my valve cover Triumph 1
AH67 Wanted WANTED: Valve cover 6 Cylinder Healey Austin Healey Classifieds 2
AH67 Wanted WANTED: Valve cover 6 Cylinder Healey Austin Healey Classifieds 0
M TR2/3/3A TR3 Valve cover vent oil leak Triumph 8
NutmegCT T-Series Loose valve cover oil cap MG 4
D valve cover Austin Healey 7
wangdango 6-cylinder alloy valve cover Austin Healey 53
wangdango 3000 valve cover bolts/chrome/ss? Austin Healey 4
HealeyRick Rare Barn Find Valve Cover Racer Austin Healey 9
glemon General TR Simple Improvement Valve Cover Washers Triumph 2
M TR2/3/3A Valve cover question Triumph 6
