Silicon valve cover gasket
TR6BILL
Does anyone know if J.M.Wagner is still making those silicon valve cover gaskets to fit the stock steel valve cover for the TR6? I cannot get a reply from his email. Does anyone have a new one laying around they can part with or that I can buy from them? I PMed one forum member who has lots of spares. Thought I would go to the rest of the forum to check.
tomshobby
I don't have one Bill but it is worth your trouble if you can find one.
Also, JM is not always easy to get in touch with. I once had his phone number but cannot find it. I think I once gave it to Paul (Brosky). You might check with him.
T
TR6BILL
Thanks, Tom. That member that I PMed was Brosky. The only person that I know that carries 3 spare distributors! Surely he would have a spare...... :smile:
TR4nut
Justin is still making gaskets - I just picked up one for my TR4 about 2 weeks ago from a local club member who took advantage of his "buy 4 get 1 free" offer.
Randy
MGTF1250Dave
Aloha Bill,
I recently bought one on e-bay for my TR3 and was really pleased with it. It fit well on the stock valve cover and when installed stood about 1/8" proud of the valve cover. Excellent seal against the head with no leaks.
He also makes them for TR6 stock valve covers (along with several other LBCs)and here is a link to a current offering on e-bay:
https://cgi.ebay.com/ebaymotors/Triumph-T...sspagenameZWDVW
The buy it now price is $15 which is what my TR3 gasket cost.
bgbassplyr
Just bought from him on ebay. Very easy transaction.
TR3driver
Great Pumpkin - R.I.P
He recently resurfaced onto the local Triumph scene, so it might be worth trying again.
PeterK
MGTF1250Dave said:
Aloha Bill,
Those are NOT Justin Wagner's silicone gaskets. His are not flat but fitted to the inside lip of the valve cover so they do not move. Also cost more than $15. The ones on ebay are punch from flat sheet.
Justin's day job involves travel so be patient. https://www.jmwagnersales.com/
vettedog72
The "punched from flat sheet" ones appear to fit up on my after market aluminum valve cover. The aluminum valve cover does not have a ridge, lip or valley, just flat mating surface. I plan to "Glue it" to the cover and I hope it will seal. My plans don't all ways work out but for $15 its worth a try.
PeterK
Good to know. One of mine has an alloy cover and I've been using cork. At very least, the silicone will last longer. Bit Justin's is still nicer :savewave: but he still hasn't got one done for alloy covers. He said there were too many size variables in making them fit.
Opa
Steve's gasket is not flat cut.It is radiused to fit the valve cover and flat on the head side,at least mine was. Had mine for about two years IIRC no leaks. It does not have the stand up lip on the inside as the wagner gasket.
mrv8q
MGTF1250Dave said:
Aloha Bill,
I hope I'm not speaking out of turn here, but I'm not sure the above eBay offering is from Justin. He's located in SoCal, and those are in Iowa. ISTR
Justin mentioning another seller on eBay; perhaps this is it...
MGTF1250Dave
Aloha All,
I'm sorry if I inferred that the silicone valve cover gaskets I referenced where made by J M Wagner, they are not. I have seen his product on his website and they look very substantial and seem to be a quality product.
The ones I referenced and bought are for stock steel valve covers and have a radius top to fit in the groove form into the valve cover. I held the gasket in the place in the valve cover using Permatex Indian Head Gasket Shellac Compound. The flat bottom of the gasket creates a good seal against the head.
It was my intention to offer Bill an alternate source for a silicone valve cover gasket for his stock steel valve cover.
poolboy
They are still that way. They're plenty thick and you get a good seal with only finger tightening the valve cover nuts.
BobbyD
I've have one of Justin's first TR6 gaskets and the ones being sold on eBay ARE NOT Justin's. They may work but they don't even come close to the customized fit that Justin's offers. In almost 10 years mine has never leaked so much as a drop of oil and it's been on and off a half dozen times. So what we have is another great product and we can't get an answer from the source. A few months ago I emailed Justin about forum members complaining about his lack of response and heard back very quickly. Basically work & personal life takes priority, followed by Triumphs. It's a great product and I hope you get yours.....just keep emailing Justin.
T Justin Wagner's Silicon Valve Cover Gasket Triumph 7
T Silicon valve cover gasket Triumph 17
DNK Silicon Valve gasket MG 5
Got_All_4 General TR Someone asked where to get DOT5 silicon brake fluid a while back Triumph 4
HealeyRick Silicon Valley Healey Austin Healey 2
T TR2/3/3A Is there a Silicon safe Master Cylinder for TR3? Triumph 21
W BN1 using silicon brake fluid Austin Healey 7
Basil SIlicon vs Glycol-based Jaguar 9
tahoe healey test for silicon vs dot3/4 Austin Healey 1
MGTF1250Dave Silicon Grease Restoration & Tools 2
sim looking for 2 valve spring kippers for a 948 Spridgets 3
R Valve Drain Pipe Austin Healey 13
R T-Series Valve gap for an MGTD 1953. MG 5
6 Valve Oil Seals Spridgets 10
K TR2/3/3A Cylinder head removal and valve adjustment Triumph 2
P TVR Big Valve 4.3 TVR 0
Erica General MG Oil Drain Valve -- mine is an MGB, but they have others MG 3
J MGB BRAKE VALVE ? MG 11
jehuie PCV valve explanation? British Motor Corp 5
R 3000 Heater Valve Austin Healey 4
T TR2/3/3A valve springs Triumph 15
kodpkd For Sale Alloy valve cover for AH 100-6 3000 PRICE DROP! Austin Healey Classifieds 1
T TR2/3/3A valve guides and piston clearance Triumph 6
kodpkd Valve Cover Gasket - Don't do this! Austin Healey 14
KVH General Tech Heater control valve/cable Triumph 1
G Valve Train Lubrication Austin Healey 1
KVH General Tech Valve Timing--No Marks Triumph 20
newmexTR3 For Sale TR2-4 performance valve springs, collars, exhaust seats, cotters Triumph Classifieds 0
D Water Valve Connection Austin Healey 4
R TR2/3/3A Rule 9 Valve Adjustment Triumph 8
RJS General TR Lever Shock - HD Shock Valve Triumph 2
JPSmit Product Review - air compressor drain valve. Harbor Freight Restoration & Tools 9
M TR5/TR250 Bypass valve Triumph 27
I Bugeye valve rebuild suggestions Spridgets 8
G Valve Cover Gasket Silicone Adhesive Austin Healey 5
J Oil Pressure Relief Valve Austin Healey 3
K TR2/3/3A An alternate valve adjusting sequence? Triumph 3
K TR2/3/3A Camshafts and Valve Settings Conundrum? Triumph 7
charlie74 TR6 ‘74 valve springs Triumph 0
Joel Lester TR2/3/3A What type of valve to use when rebuilding the head? Triumph 10
tj_tr3_tr6 TR4/4A looking for Machine Shop TR4 Valve Job Ventura - Los Angeles area Triumph 4
M TR6 PDWA valve Triumph 6
M Ray Juncal Valve Covers Austin Healey 5
M 1973 TR6 oil and filter changed - oil shooting out from high pressure valve? Triumph 15
BillyB62 TR2/3/3A Anyone seen a valve cover like this Triumph 0
alexisrexx TR6 Oil Sludge in Valve Cover - Normal? Triumph 16
K TR2/3/3A Brake Restrictor valve? Triumph 9
Lin Heater water valve question Spridgets 2
D MGB MBG valve clearance MG 1
K TR2/3/3A Finding valve lash with cam specs? Triumph 8
