Silicon valve cover gasket
TR6BILL
Where can I buy the silicon valve cover gasket for a stock TR6 valve cover??
T
TR6BILL
Dang, you ask that guy the time and he tells you how to build a watch. Very, very complete instructions. I will give him a call, Paul. Thanks.
<span style="font-size: 8pt">I sorta apologize for the flamingo comment....</span>
Brosky
I'd feel hurt if you didn't say SOMETHING once in a while, Bill.
roofman
I emailed that guy once a month for about 6 months and he never got back to me.
BobbyD
I don't know if Justin travels a lot or what but I've heard the same complaint from others. I did see a post on the Triumph Mail List from him a few weeks ago so he's still around. As Paul said, this is a great product and it works as advertised. I've had the valve cover off about 5 or 6 times in the 8 or so years that I've had the gasket and it's never leaked a drop of oil in all that time. If you guys don't hear back from him let me know and I'll try and rattle his cage over on the Triumph Mail List.
BritSpit
I find that if you have enough oil leaking from elsewhere on the engine the trickle from the rocker cover is barely noticeable! :smile:
Brosky
I had trouble reaching him as well, as he does travel for long periods, but as soon as he got back to his inventory, he shipped right away. I'd suggest flooding him with email. It worked for me.
Minesweeper
If you don't feel like cajoling someone into selling their product to you, get a silicone gasket on Ebay. I got the $15 one ($3 shipping), received it within three days and it has worked perfectly on my TR6
Scott
BobbyD
Scott........is that the red one that's half round? I'm glad it worked perfectly on your car because I've seen a number of Mail List posts about it being difficult to fit. The beauty of Justin's design is way it fits the shape of the valve cover lip and you can re-use it over and over again. However for $15, the eBay guy does offer a cheaper solution and immediate shipping.
Brosky
Justin had a dozen when I talked to him this spring. I should have bought all of them and resold them.
TR4nut
Personally, I like Justin's, but it is meant for a stock cover. If I do mount an aftermarket alloy cover I'll definitely consider the other ebay option.
Randy
Minesweeper
Yes, that's the one. I used silicone gasket maker to adhere the half-round side to the valve cover (was wishing I had three hands at the time, but the fit was right on) and clamped it to a flat surface overnight. No sealant between the gasket and cylinder head and no leaks so far (knock on wood).
I did look at Justin Wagner's gasket. I liked what I saw, but having already spent way more than I had intended, I went for the less expensive alternative.
Scott
Brosky
<div class="ubbcode-block"><div class="ubbcode-header">Quote:](was wishing I had three hands at the time, but the fit was right on)[/QUOTE]
Those little plastic or wooden spring style clothes pins will work nicely here.
Opa
I have the same silicone gasket on my 6.No leaks so far. More info at www.gasketinnovations.com. Steve Downing is his name.
I use a piece of 3/4 inch MDF board that I picked up at a cabinet shop with three studs mounted to fit valve cover. Put on a little ultra blue and mounted cover to board over nite.Used to install cork gasket to cover same way.
T Justin Wagner's Silicon Valve Cover Gasket Triumph 7
T Silicon valve cover gasket Triumph 17
DNK Silicon Valve gasket MG 5
Got_All_4 General TR Someone asked where to get DOT5 silicon brake fluid a while back Triumph 4
HealeyRick Silicon Valley Healey Austin Healey 2
T TR2/3/3A Is there a Silicon safe Master Cylinder for TR3? Triumph 21
W BN1 using silicon brake fluid Austin Healey 7
Basil SIlicon vs Glycol-based Jaguar 9
tahoe healey test for silicon vs dot3/4 Austin Healey 1
MGTF1250Dave Silicon Grease Restoration & Tools 2
sim looking for 2 valve spring kippers for a 948 Spridgets 3
R Valve Drain Pipe Austin Healey 13
R T-Series Valve gap for an MGTD 1953. MG 5
6 Valve Oil Seals Spridgets 10
K TR2/3/3A Cylinder head removal and valve adjustment Triumph 2
P TVR Big Valve 4.3 TVR 0
Erica General MG Oil Drain Valve -- mine is an MGB, but they have others MG 3
J MGB BRAKE VALVE ? MG 11
jehuie PCV valve explanation? British Motor Corp 5
R 3000 Heater Valve Austin Healey 4
T TR2/3/3A valve springs Triumph 15
kodpkd For Sale Alloy valve cover for AH 100-6 3000 PRICE DROP! Austin Healey Classifieds 1
T TR2/3/3A valve guides and piston clearance Triumph 6
kodpkd Valve Cover Gasket - Don't do this! Austin Healey 14
KVH General Tech Heater control valve/cable Triumph 1
G Valve Train Lubrication Austin Healey 1
KVH General Tech Valve Timing--No Marks Triumph 20
newmexTR3 For Sale TR2-4 performance valve springs, collars, exhaust seats, cotters Triumph Classifieds 0
D Water Valve Connection Austin Healey 4
R TR2/3/3A Rule 9 Valve Adjustment Triumph 8
RJS General TR Lever Shock - HD Shock Valve Triumph 2
JPSmit Product Review - air compressor drain valve. Harbor Freight Restoration & Tools 9
M TR5/TR250 Bypass valve Triumph 27
I Bugeye valve rebuild suggestions Spridgets 8
G Valve Cover Gasket Silicone Adhesive Austin Healey 5
J Oil Pressure Relief Valve Austin Healey 3
K TR2/3/3A An alternate valve adjusting sequence? Triumph 3
K TR2/3/3A Camshafts and Valve Settings Conundrum? Triumph 7
charlie74 TR6 ‘74 valve springs Triumph 0
Joel Lester TR2/3/3A What type of valve to use when rebuilding the head? Triumph 10
tj_tr3_tr6 TR4/4A looking for Machine Shop TR4 Valve Job Ventura - Los Angeles area Triumph 4
M TR6 PDWA valve Triumph 6
M Ray Juncal Valve Covers Austin Healey 5
M 1973 TR6 oil and filter changed - oil shooting out from high pressure valve? Triumph 15
BillyB62 TR2/3/3A Anyone seen a valve cover like this Triumph 0
alexisrexx TR6 Oil Sludge in Valve Cover - Normal? Triumph 16
K TR2/3/3A Brake Restrictor valve? Triumph 9
Lin Heater water valve question Spridgets 2
D MGB MBG valve clearance MG 1
K TR2/3/3A Finding valve lash with cam specs? Triumph 8
