TR2/3/3A Plugged valve cover breather Cap?
karls59tr
Bronze
Anyone heard of a plugged breather cap causing oil pan leaks? I had replaced the oil pan gasket about a year ago and did all the prescribed metal straightening and gasket recommendations. After some time i noticed I was still getting some oil leaks. Realizing I had never thoroughly cleaned the breather cap I let the mesh soak in solvent and blew it out with compressed air. The leaking seems to have stopped! Is it possible that pressure was building up in the motor and forcing oil out where it shouldn't? Where does the "blow by" tube fit into this scenario?:confused:
CJD
The crankcase is supposed to ventilate as air from the fan is captured by the valve cover cap. The slight positive pressure from the fan forces a bit of air into the engine. Then, the draft tube on the lower left is designed to pull a slight negative pressure as the car moves, so the crankcase fumes are drawn out there.
If the cap was plugged, there is a good chance your draft tube is also plugged. I would think both would have to be restricted to cause the crankcase to build pressure and cause a leak. Of course bad rings can cause enough internal pressure to overwhelm the vents.
gecoughenour
Member
I had a similar experience recently at the TRA in Gettysburg. I had an aftermarket alloy valve cover fitted and apparently the tiny hole in the oil filler cap, which is on the rear of the head not the front, may not let this ventilation system function. I also had a new silicone gasket on the valve cover that had a one inch piece missing when I removed the valve cover. It was blowing oil out, into my battery box, so most of it drained out the battery box drain tube. Going back to stock valve cover and cork gasket to see if that helps.
gecoughenour
Member
wouldnā€™t under the valve cover be open to the crankcase and draft tube via the push rods?
Yes. I checked my drat tube and it was perfectly clear. I'm still pondering why I had positive pressure under the valve cover. The engine only less than 5 K miles on it, so don't think a valve stem seal is leaking. I'm going back to the stock valve cover to eliminate the alloy cover as a variable in the analysis.
D TR2/3/3A Block coolant passages plugged - pull the head? Triumph 46
S Plugged Grease Zerks Spridgets 7
B TR6 TR6 Heater core plugged? Triumph 9
K TR2/3/3A Plugged 3A block drain? Triumph 6
7 Carbon canister plugged Other Cars 2
M T-Series Is a plugged TD rocker cover vent tube OK? MG 11
C Gas line plugged? MG 13
K Suggestions concerning plugged cooling passages? Triumph 18
R Plugged Fuel Line Austin Healey 4
sim looking for 2 valve spring kippers for a 948 Spridgets 3
R Valve Drain Pipe Austin Healey 13
R T-Series Valve gap for an MGTD 1953. MG 5
6 Valve Oil Seals Spridgets 10
K TR2/3/3A Cylinder head removal and valve adjustment Triumph 2
P TVR Big Valve 4.3 TVR 0
Erica General MG Oil Drain Valve -- mine is an MGB, but they have others MG 3
J MGB BRAKE VALVE ? MG 11
jehuie PCV valve explanation? British Motor Corp 5
R 3000 Heater Valve Austin Healey 4
T TR2/3/3A valve springs Triumph 15
kodpkd For Sale Alloy valve cover for AH 100-6 3000 PRICE DROP! Austin Healey Classifieds 1
T TR2/3/3A valve guides and piston clearance Triumph 6
kodpkd Valve Cover Gasket - Don't do this! Austin Healey 14
KVH General Tech Heater control valve/cable Triumph 1
G Valve Train Lubrication Austin Healey 1
KVH General Tech Valve Timing--No Marks Triumph 20
newmexTR3 For Sale TR2-4 performance valve springs, collars, exhaust seats, cotters Triumph Classifieds 0
D Water Valve Connection Austin Healey 4
R TR2/3/3A Rule 9 Valve Adjustment Triumph 8
RJS General TR Lever Shock - HD Shock Valve Triumph 2
JPSmit Product Review - air compressor drain valve. Harbor Freight Restoration & Tools 9
M TR5/TR250 Bypass valve Triumph 27
I Bugeye valve rebuild suggestions Spridgets 8
G Valve Cover Gasket Silicone Adhesive Austin Healey 5
J Oil Pressure Relief Valve Austin Healey 3
K TR2/3/3A An alternate valve adjusting sequence? Triumph 3
K TR2/3/3A Camshafts and Valve Settings Conundrum? Triumph 7
charlie74 TR6 ā€˜74 valve springs Triumph 0
Joel Lester TR2/3/3A What type of valve to use when rebuilding the head? Triumph 10
tj_tr3_tr6 TR4/4A looking for Machine Shop TR4 Valve Job Ventura - Los Angeles area Triumph 4
M TR6 PDWA valve Triumph 6
M Ray Juncal Valve Covers Austin Healey 5
M 1973 TR6 oil and filter changed - oil shooting out from high pressure valve? Triumph 15
BillyB62 TR2/3/3A Anyone seen a valve cover like this Triumph 0
alexisrexx TR6 Oil Sludge in Valve Cover - Normal? Triumph 16
K TR2/3/3A Brake Restrictor valve? Triumph 9
Lin Heater water valve question Spridgets 2
D MGB MBG valve clearance MG 1
K TR2/3/3A Finding valve lash with cam specs? Triumph 8
A T-Series MGTD oil pump bypass valve MG 0
