V8 and the V6 Tasmins have the same radiator?
tr7andtvr
Do the V8 and the V6 Tasmins have the same radiator?
I think that there is more than one option on the V6 cars one has an electric fan?
This is for my 5.0 conversion....
mrtvr
Yes, there were different radiators used for the V8 and V6 wedge TVRs. There were also a couple of different style radiators used on the V6 Tasmin/280i series. The series 1 and 1 1/2 wedges had a radiator in front of the engine whereas the Series 2 cars had a nosecone radiator. The former had a clutch driven fan while the latter used electric fans.
The V8 radiator was also cooled by twin electric fans.
Marshall
TXCoyote
In my recent V8 conversion I am using the V6 nosecone radiator and it seems to work fine but that is with a Rover Motor. Not sure how a 5.0 would work as it may have more stringent heat requirements.
tr7andtvr
tr7andtvr
How do you convert over to the nose cone type? What do you mount the radiator to? Could someone send me pictures? My guess is that the rover v8 puts out more heat than the ford, but that is just a guess.
Andy
Sparkie
Andy,
I can probably get you some pics this weekend, but I'll warn you that there's not much visible.
As far as capacity, the 5.0 would be putting out more BTU's and therefore have a higher cooling requirement. That being said, the Rover engine is not nearly as forgiving as far as overheating. Probably a mute point as your wedge probably doesn't have the same rad as the Rover powered cars.
I was looking on EBay for aluminum radiators and it really pays to get a rad for a popular car. Some of the lower profile ones, like for a Camaro, look like they could be made to fit at an angle. As I am finishing the shock & spring install this weekend I will take a look.
What year was your wedge?
TXCoyote
Guys,
As far as I can tell the Ford V6 and Rover V8's used the same radiator. My current project a Lotus 7 clone Superstalker uses a 2002 V6 Superchaarged GM motor and a 87 Hyundai Excel 4 cylinder radiator without any cooling issues according to the 100 or so owners. Of course it is an open car without heat or air but the radiator is tiny!
P Post-War Other Herald Windshield: Is it the same as.... Triumph 2
R 2500M Inner Fenders - are they the same as a Vixen 2500? (Also Tire Size) TVR 3
Joel Lester TR2/3/3A Are all "stock" camshafts the same? Triumph 9
tr6nitjulius General TR Different Times Same Glory! Triumph 3
S TR2/3/3A Are a tr3 and tr4 radiators the same Triumph 3
drooartz MGB Same car, same spot, 6 years apart MG 12
S TR2/3/3A Not all tr3 fuel pumps are built the same Triumph 5
D TR4/4A Trans replacement front oil seal not same size as original Triumph 2
B TR2/3/3A Another/maybe the same fuel delivery problem Triumph 5
jmayzer different part, same situation Spridgets 11
Got_All_4 TR2/3/3A Steering box oil seal & same seal for input shaft in tranny Triumph 2
K TR2/3/3A Is the 4A Gearbox Top Cover the same as the TR6 Top Cover? Triumph 2
drambuie It's funny no matter where Healey owners are in the world, Our garages look the same! Austin Healey 34
weewillie not british but a classic all the same Spotted 6
K TR6 Are TR6 dasboards the same as TR4A? Triumph 5
T Hmmm - not quite the same. What to do? Triumph 10
T TR6 TR3 - TR6 floor pans the same? Triumph 2
Jer No...these cars are not the "same" Spridgets 2
H BJ7 horn button, same as Sprite? Austin Healey 5
HealeyRick Sunday Will Never be the Same Austin Healey 0
G MGB MGB/ Datsun Z wheels the same? MG 1
J Bugeye single piece top frame same as two-piece? Spridgets 4
C Think my coil overheats, but new coil: same prob Triumph 19
JPSmit I think Batman was eating at the same restaurant Spotted 8
G Is a 4.22 carrier the same as a 3.90? Spridgets 7
G Are all jets the same size in a carb family? Spridgets 14
M TR5/TR250 TR250 Bonnet same as TR4? Triumph 4
K Spitfire GT6 Rad same as Spitfire Rad? Triumph 4
JamesWilson Two Rochdales for sale at the same time Other British Cars 1
theleisure 1098 & 1275 Oil Pans-- Same or Different? Spridgets 4
M are all folding top frames the same Spridgets 8
M are the British cars the same as American Spridgets 7
Steve P. MGA Metropolitan 1500 engine same as MGA??? MG 4
K TR6 T4A IRS chassis frame same as the TR6? Triumph 4
T TR6 TR4A sway bar same as TR6? Use same bushings? Triumph 12
R Paint question...Same Body Color or Change Color? Triumph 17
chicken Are BJ7 doors the same as BJ8 Austin Healey 8
W Are they the same? Spridgets 0
JPSmit second verse same as the first [almost] Spridgets 13
Stewart Throwout bearings all the same? MG 7
Basil Slow progress - but progress all the same Triumph 21
T Wedge VickyBrit & Roadster Fac TR7/8 door panels same? Triumph 2
S 87mm pistons and liners, are they all the same? Triumph 2
64rocksprite Ribcase - all the same? Spridgets 4
R Stag Need stag rear end seals bearings same as TR 6? Triumph 3
PATR8 UGGGG!!!! I saw an 8 same color green I picked Triumph 7
toysrrus "SCAM ARTISTS ON EBAY AGAIN": Are they the same? Triumph 4
T HS4 and HIF4 inter-carb linkages the same? MG 10
KLUTZ Properly tuned HS4's.. are they all the same? MG 6
