Slow progress - but progress all the same
Administrator
Boss
Well, tonight I finished re-installing the pistons in my Spitfire engine, after installing new AE rings! For some reason, gaps in the rings that were installed before were way too wide (double specs) This is what I "suspect" may have been why I was getting too much crank case pressure, and thus oil out the back end (even with a brand new rear seal). Before I put the motor back in, I have to decide how much detailing I want to do on the firewall and frame, front end, etc. first
Tinkerman
Now is the time to do it! It gets real tedious when all the stuff is back in the engine bay. I would suggest you go for it now. Post pictures.
Good luck, Tinkerman
V
vagt6
Ditto what Tinkerman said.
But, I think Basil already knows it! :yesnod:
Do it now, while it's easier.
Administrator
Boss
That's my inclination. One thing that is going to be a pain is that someone had put undercoating on the firewall (the lower part below the ledge). I am pretty sure that is just supposed to be painted, so I may attempt to get all that junk off, then having the entire firewall and frame rails re-painted.
Brosky
You'll be cursing for a short while, but smiling for a long time after that.
Tinkerman
Ditto Paul!
prb51
Basil,
You know the only way to properly 'do it' is to put everything back together as quickly as possible and then, and only then, try and make things look nice.
Darwin
Bronze
This is how it starts. While I have this apart I may as well.......
I feel a severe case of shipwrights disease setting in boss. Be careful. :smile:
V
vagt6
There are a number of ways to deal with that nasty undercoating gunk. One of my preferred methods for smallish areas is to take the wire wheel to it and scrub it off. Then, prime and paint.
Not good for some areas, but works like a charm on others.
Let us know what you do with it . . .
Administrator
Boss
One guy locally suggested that I use a small torch to heat it up, then scrap the majority off with a putty knife.
roofman
I would try thr wire brush first, it may be easier and less messy. If not then go to plan B.
TR3driver
Great Pumpkin - R.I.P
Heat works really well, but don't forget that both the undercoating, and likely whatever is on the other side of the panel, are flammable.
R
RonMacPherson
What about the Dawn stripper, or aircraft paint stripper?
AltaKnight
I had that gunky undercoat stuff in my engine bay from the DPO.
I used carburetor cleaner in a spray can, with copious amounts of shop towelds it came off a treat, it just melted away.
Administrator
Boss
Lots of good suggestions....I'll probably try each in a small area and see which seems to work the best.
Andrew Mace
:iagree: A heat gun is plenty (but still can do some damage if you're not careful). With it and a fairly dull scraper, you'll likely remove most of the coating without scratching the surface underneath. It's possible that you'll then be able to do final cleanup with a solvent and not have to do anything more unless you find spots of rust or damaged paint.
Darwin
Bronze
methalethel ketone. MEK. nasty stuff but will cut most any of the goo.
Brosky
I think that you can buy it at Home Depot, but I've heard others say that it is strong.
Tr4dude slow buffing progress Triumph 8
Tr3aguy Slow progress Triumph 3
T block prep progress-slow and not finished yet-pics Triumph 3
T slow and steady progress... MG 5
motofiaccone Slow, but a little progress Spridgets 14
jlaird Progress-slow Spridgets 4
jlaird Progress- oh so slow Spridgets 9
Carlbanan56 MGB No spark and engine cranking slow MG 10
RichB4493 TR2/3/3A TR3 not starting - Slow/Weak Starter Triumph 33
Joe Reed MGB Tach slow to wake up...why? MG 6
glemon Slow loading FORUM Navigation Questions 4
Tosh TR6 Engine dies slow left turn. Triumph 26
Bugeyze Oil pressure slow to rise Austin Healey 14
4tecdog Overdrive slow to disengage Austin Healey 22
J SU HD6 - Slow Idle Screw Austin Healey 13
tomshobby SU carbs slow to back off. Spridgets 7
vette Slow Ticking Pump Austin Healey 19
S General TR Those who think Victoria British is slow getting our TR parts to us Triumph 10
Airfix Wedge TR8 Zenith Stromberg carbs slow deceleration Triumph 1
M_Pied_Lourd Maybe I am just Slow..... Triumph 15
T Slow clutch Triumph 19
PAUL161 Why So Slow? MG 3
Sopwith_Camel slow turning Spridgets 25
TRclassic3 Slow idle drop Triumph 8
A T-Series Clutch pedal slow to rise MG 11
aeronca65t Midget-flipping and burning in slow-mo Spridgets 11
Tr3aguy Slow.....but remembering where it began. Triumph 3
Frank C. Overdrive slow to engage Austin Healey 10
Woodie engine idle slow to come down MG 14
Steve1970 Very slow in first when letting up on the clutch Triumph 17
Hairyone speedo slow, TPM Spridgets 10
jaegzie Starter Slow on 1275 Spridgets 10
jaegzie No Power [Slow] through starter 59 Bugeye 1275cc Austin Healey 4
L Midget wipers slow and stopping Spridgets 2
TR4nut A-overdrive slow to disengage Triumph 6
Brosky Slow forum, or just my connection? Triumph 27
T Spitfire Spitfire windshield wipers getting old and slow Triumph 15
DNK Slow Forum Triumph 2
Brosky Very slow logon on or just me? Triumph 10
hondo402000 Starter/ slow start problem Triumph 8
Brosky Are we overloaded? Server very slow.. Triumph 4
jlaird Wifes a bit slow this morning Spridgets 9
D OD engages slow Triumph 13
Howard_The_Duck Other than being slow as molasses... Other Cars 29
B Site Slow today? Spridgets 6
Randy Harris Basil? - still very slow access Austin Healey 5
tony barnhill SLOW FORUM Other Cars 1
tony barnhill SLOW FORUM Racing 1
tony barnhill SLOW FORUM Other British Cars 1
tony barnhill SLOW FORUM Triumph 2
