No Power [Slow] through starter 59 Bugeye 1275cc
jaegzie
I am working on putting a 1275 into my bugeye. The enigine came out of a 69 midget. The wiring harness from a 63.
Background of motor, engine ran, it was put into a 69 sprite ran for about 2 years, now it sat for about 2, sealed inside.
I took the wiring out of a 63 to keep the wiring positive ground but run the 1275. Originally I was using the pull switch but it was slow, so I tried the key after getting the 63 wiring harness. Same results. I tried running it direct but still slow. Ive oiled the cylinders and everything but I still cant get it to turn quickly like the rest of the austins. Battery was tested in other cars with no problems. I have tried various starters, probaby 6 and all act the same. any Ideas? TIA
smcmanus
If it is an electrical problem, most of the time it is a bad connection. Check your connections, look for a bad ground, and make sure the timing isn't too far advanced. It could be a bad starter switch. Are your battery cables heavy enough?
Good Luck
Steve
Shane
:iagree:
Loose grounding strap was my issue. Tightened it up and it starts fine now.
healeynut
Do the following:
1) pull off both terminals off the battery, clean with a battery terminal cleaner, and reinstall.
2) turn on the ignition, but use the push button on the solenoid to turn it over.
I bet that will make it faster to turn over.
T USB and Auxiliary Power Connections Austin Healey 6
RJS TR4/4A Power (+) Sources Triumph 7
Guido36 Electric Power Steering Austin Healey 2
Racer-X- Frame mounted power brake pedal/booster/master cylinder kits for RHD cars? Restoration & Tools 1
Eeffoc TR4/4A Out of the blue - started to loose power Triumph 17
H Loss of Power Upon Acceleration Austin Healey 8
C Wanted 1970 XKE power steering pump. Or substitute? Jaguar Classifieds 1
JPSmit Power Pack Restoration & Tools 9
Sopwith_Camel how do i know if my power steering pump is going Jaguar 4
billspohn Engine Swapping for Straight 6 Power Other Cars 3
I Bugeye lack of power Spridgets 1
R TR2/3/3A Power Steering Triumph 2
Russ80MGB MGB 1980 MGB - No power MG 16
V VAUXHALL Astra diesel 1.7cdti loss of power 2012. HELP. Other British Cars 1
AngliaGT Olds,Power Wagon Spotted 1
B Power steering Other British Cars 33
Robert Somma power window installation TVR 3
B Intermittent Loss of Electric Power Austin Healey 18
H MGB 1980 mgb no power from ignition switch MG 23
KiwiStagguy Re building my power steering 71 Stag . Rust and pitting bad . Need a business name to fix it Triumph Classifieds 0
M Power Loss Austin Healey 27
H TR4/4A 67 tr4a runs rough and losses power when hot but not over normal temp Triumph 14
M TR6 EZ Power Assisted Steering Column Fitment Triumph 3
M TR6 Power Steering Rack & Pinion. Triumph 3
C MGA Where to tap into 12v for a power outlet MG 2
G Power to relays Austin Healey 10
M BN1 Loss of Power Austin Healey 21
S Power Steering Austin Healey 3
M TR6 Adding Some Power Triumph 8
nevets interesting article about converting classic cars to electric power Austin Healey 7
S Positive Ground to Negative Ground Power Inverter Austin Healey 11
jfarris TR2/3/3A Loss of Power - ride of shame on flatbed to the house Triumph 15
UmmYeahOk GT6 Zero acceleration power / Car’s RPMs surge when you get in it. Triumph 40
S TR2/3/3A power wirer for the heater switch Triumph 16
dougie Paddy Power Austin Healey 3
D Lilly under her own power... Austin Healey 7
RAC68 Has anyone considered Power Rack and Pinion Stearing and/or an Air Bag suspension Austin Healey 32
G The Formula Power Fuel Catalyst!???????? Austin Healey 17
tomshobby TR6 power assist for clutch pedal Triumph 12
exfed12825 General Tech Electric Power Steering With Fail Safe MG 0
JPSmit DC Power source thoughts Restoration & Tools 11
F 12Volt Bench Power Supply Austin Healey 4
B Power Brake Servo for a 100 Austin Healey 3
R BJ7 wiring power path Austin Healey 21
F BT7 brales poor stopping power - any advice? Austin Healey 19
KVH TR4/4A Engine Power Triumph 10
drambuie Getting more horse power from a Healey 100 Austin Healey 63
AH67 BJ8 losing power and enguine dies Austin Healey 9
L TR6 No power/not enough power to turn signals, wipers Triumph 8
KVH General TR Power Issue on Acceleration Triumph 13
