useless carb balance tool
Hoghead
I bought a STE snail type SU carb balance tool and unless I am missing something it is useless on a big Healey as when the device is stuck in the carb throat, the scale is impossible to see being under the fender
80.00 well wasted, or is there some extension solution using a moulded hose?
red57
I started with a unisyn and removed the small flow meter that came on it and added a hose and a much larger and remote flowmeter. The secret to these flow meters is keeping them vertical which is hard to do with the unisyn as produced but easy with a hose and a remote meter. I hang the meter from the bonnet and then I'm free to move the unisyn base back and forth from carb to carb as much as I need without disturbing the vertical orientation of the meter (I run triples)
I don't know what a unisyn costs these days but a flow meter like the one shown is around $20-30.
Dave
mgtf328
Sorry about your $80 but you can feel good knowing that you've saved me and a few others $80.
I use the "SU tuning tool", stuck in the damper tube for balancing my carbs, the carbs are after all flow measuring devices. I made the tools out of a couple of writing pen barrels with some bent wire glued in the ends. Seems to work well enough, costs nothing and saves me skinning my knuckles getting the air filter on the rear carb off.
AJ
bob hughes
AJ
Yup
My friend had a go setting mine up after my rebuild with a couple of pencils down the damper tubes and a some pencil marks - me - I use a piece of rubber tubing and my ear.
:cheers:
mgtf328
Yes, but you have to take the rear filter off to do that and getting it back on is a nightmare. If anyone knows an easy way to do it I'd be greatful!
I could never tell the difference doing it by ear anyway just as I can't get the knack of using the lifting pin to check the mixture. I always end up raising it too high and almost stalling the thing.
AJ
ozhealey
Hoghead,
The snail balancer is actually brilliant in my opinion and money well spent. In particular if you have not had years of experience balancing multiple SU carbs. I have a BJ7 and the tool is incredibly accurate albeit as you say, awkward to use unless.... I used a mirror on an expandable rod (most of us have one) for a while and was able to read the gauge. Then I went to an auto parts store and got a top radiator hose with a 90 degree elbow which fitted snug into the snail, with this I can easily read the gauge between the two SU's.
I have been tuning my car for over 20 years and tools have ranged from a piece of garden hose and coat hanger wires in the dash pots tops, to a Gunston colour tune and a unisyn with the tube and orange bead. While my carbs are fairly well synchronised and tuned (I thought for fifteen years), a friend gave me a snail flowmeter when he sold his car and I gave it a try just for fun. Amazingly, I found the STE snail to be the best of all the tools and I would now give everything else up if I had to choose just one tool. If I tune with all the other gadgets and get them as best I can (including by ear), I then put the snail in the inlet and even the very minor gauge differences can be seen. I can tune to get the exact same readings easily and my carbs have never been happier. Even one eighth of a turn on the screw will change the reading by a very visible amount.
The only tools I use now (for around 5 years) and I believe the most effective for me are the STE snail and the rod/wires which go in the dashpot (they come in the blue plastic sleeve tool kit).
I'm sure many will not agree and at the end of the day it is all individual choice, I just wanted to give a plug for the poor old snail.
Cheers
Tony
RonR
I am assuming that the tool in question is similar to Moss 375-324 and here https://www.amazon.com/Carburetor-Synchrometer-Weber-Dellorto-Mukuni/dp/B00SLH03R4
For the past 46 years, I have been using a very old Sun exhaust gas analyzer to set the mixture and a Unisyn gauge to set the balance. The tube pivots on the Unisyn tool to keep it vertical if one desires, so I don’t understand the need for the separate hose as red57 described. I don’t understand the need for the tube to be vertical either since all that is being measured is a relative vacuum.
I am not sure how important the goal of perfectly balanced carburetors is on a big Healey since the 6-port intake manifold is not internally divided and the accuracy of the origin hose-in-your-ear method was adequate when the cars were manufactured.
For that matter, how perfect do they need balanced on any British car running SUs?
For the rear air cleaner, I have a 1/2" open end wrench which I have cut down to a length that assists in access to the bolts.
H
Hoghead
This is the tool I find impossible to use. I can see that it would be great, but on a big Healey, it is buried under the fender and impossible to read.
Off to see if I can find a rad hose extension and/or mirror on a stick
I use a Uni-Syn and tilt the vertical tube back a bit so it fits under the shroud. We're not measuring absolute flow, just getting both/3 carbs to flow the same at a given throttle setting, so whatever error there is will be the same on all carbs.
Balancing at idle is not sufficient, either; you have to check them at some off-idle speed as well.
ozhealey
Hoghead,
The tool you provided in the picture is the one I use.
I agree with Ron in that "perfect" tune and balance may not be necessary or have a huge effect, however it is nice to know it can be done, and I love the challenge.
To get over the air filter removal issue, I use the rounded RAMFLO filters (not original I know but better than original in terms of functionality) which have a wire clip which is easy to remove the mesh and foam and leave the base plate/dish in place. Taking my air filters off to tune takes 30 seconds and is as quick to re-install.
Cheers
Tony
Lotuswins
I agree with Tony, this is the best flowmeter I know of for balancing the carbs. I have HS6's on my BJ8, and don't have a problem....get creative with a mirror, or elbows...they sell them to work with this meter. It quantifies the flow too, which is handy for measuring flow through the radiator to compare fan performance.
Deleted member 21878
i wonder if some shop-vac fittings would be the right size to make this work better. Lowes has a variety i think.
EV2239
If you set the lift on the butterflies using a 1.5 thou feeler gauge and then make sure both throttles open together, you don't need a flowmeter. These cars set to the book fairley easily unless they've got hot cams when tickover will be uneven.
H
Hoghead
Set it by ear and it runs great.
80.00 well wasted for me, although some have more patience and/or flexibility than I to make this tool work
steveg
I was unable to get the "snail" to work with my horizontal carbs & DMD manifold. After reading the Des Hammill book, I ordered the Gunson CarBalancer on eBay.
It has a clip to hold the scale vertically; the stopper is adjustable for airflow:
red57
You will love it - same result as my home made set up I referred to above which was also inspired by Des Hammill's book. Makes it so much easier to get them even - both idle and off idle
Behold, the simple manometer!
Invented__on purpose__by Otton von Guerick in the 17th Century to prove his experiments with vacuum.
PROOF, that one needn't rush out to buy the latest 21st Century tools to work on an old Healey!
With a some variation in where I pick up the vacuum pulse signals, it's the method I use to balance the Weber throttles too. It is also how I set up and calibrated countless numbers of gas-fired industrial burners and other types of pressure and flow instrumentation devices when I worked as a systems integration tech in Lafayette, Louisiana during the 80s-90s.
Though these are weighted to represent Mercury (MMHg) they are in fact stainless steel rods; they can't spill OR get blown across the control room when hit with too much pressure__true story; beware of "stuck" pressure regulators...). Nor can liquid Mercury (or water) get sucked into a running engine!
steveg
Randy - If one were interested in adapting SUs for manometer use, would the holes for the connection stubs be outboard of the butterfly, inboard or riding on top as the rear carb vacuum pickup is?
Addendum: video below answers question - it has to be on the engine side of the butterfly.
Some folks make manometers out of bottles:
https://youtu.be/7D_f05_a74Y
+1 :cheers:
B Valve Cover Plate Rivets: Useless junk or am I missing something? Austin Healey 10
T useless information department MG 2
M USELESS PASSENGER SIDE BULLIT MIRROR FIX Triumph 21
M Useless old parts Jaguar 0
C LCB header with 1500 single carb inlet manifold Spridgets 1
Southwarks TR2/3/3A Carb balance woes Triumph 6
K TR2/3/3A Adjusting the H6 SU carb jet? Triumph 1
S Weber carb set Other British Cars 7
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
S Carb Problem Austin Healey 13
S Leaking HD6 Rear Carb Austin Healey 10
wangdango Carb Rebuild Necessity Austin Healey 3
M New Member with an HD8 Carb Question Austin Healey 1
craigshealey3000 Carb Tuning for Cold Starts Austin Healey 2
J TR6 Stromberg Carb Mixture Adjustment Triumph 6
G HD8 Carb Leak Austin Healey 7
K TR2/3/3A RE: Pulling the choke knob all the way out....the carb jets should be down how far? Triumph 5
G HD8 Carb Banjo Bolts Austin Healey 2
K TR2/3/3A Setting the SU carb jet again....... Triumph 2
Zitch SOLD!! SOLD - Tri-Carb Exhaust manifold for a 3000 Austin Healey Classifieds 0
P MGB Zenith 175 cd carb damper oil MG 2
P MGB 1980 MGB carb and oil questions MG 3
K TR2/3/3A TR-3B carb question Triumph 13
E MGB MGB ZS Carb 175CD MG 4
T Air Filter Recommendations for My Tri-Carb Austin Healey 7
HealeyPassion For Sale Tri-Carb Complete Set including manifolds Austin Healey Classifieds 13
D Carb Choke Cable Austin Healey 9
T TR2/3/3A Photo of front TR3 carb linkage Triumph 11
G TR6 Carb Spacer Triumph 4
S Carb Float Levers Austin Healey 9
R TR6 Throttle/Carb issues 73 TR-6 Triumph 40
D TR2/3/3A Another Carb question. Triumph 22
K TR2/3/3A Dist vacuum pipe to carb..... Triumph 5
M TR2/3/3A Paltech SU Carb Rebuild--Problem Triumph 3
RGK TR5/TR250 SU carb ID help Triumph 6
Healey Nut Tri-Carb Throttle Controls Austin Healey 4
jlaird MGB V6 carb help MG 14
71TR6 TR2/3/3A TR3A SU Carb rebuild opinions requested Triumph 12
E MGB SU CARB OIL 1965 mgb MG 3
Michael Oritt SU H6 carb for Le Mans--order of assembly of fuel bowl lid Austin Healey 2
D Tri carb: order of installation question. Austin Healey 5
Lotuswins Wanted TR4 H6 rear carb body Triumph Classifieds 4
E MGB SU carb air cleaners MG 10
Healey Nut Tri-Carb Project Austin Healey 213
doc50 For Sale Zenith carb, fits many cars. Other British Classifieds 0
tahoe healey Dumb carb question Austin Healey 23
jfarris TR2/3/3A Happy with my Paltech Carb rebuild Triumph 8
2 TR2/3/3A SU carb. Acts like an expansion valve ! Triumph 10
dbenichou289 TR2/3/3A SU carb linkages Triumph 2
CLB62 1962 BT7 Tri-Carb for sale on BaT Austin Healey 2
