Up-dated crank seal
gwoz
Updated crank seal
Hello eveeryone I am a new member to the forum so I have a number of questions that you regulars have probably answered a hundred times . I have a 1098 race motor in a 1960 Huffaker BMC Fjr .I have all the info on the car back to 1960 so there is a wealth of information.The motor that is now in the car was built in 93 and was dynoed at 98 hp.I ran it last year 3 times at track days and it runs superb but leaks oil like a sieve thru the rear oil seal.After 2 or 3 sessions the oil gets on the clutch and I get clutch slip.I have pulled the motor and box and intend to fix all the leaks.This required taking the center bulkhead out and completely stripping the car.I changed the front gearbox seal and now I want to fix the crank seal,Mini Mania has the updated crank seal that runs on the crank flange and I have heard conflicting remarks on whether this is a good idea, or should I just replace the standard type seal.I also have rubber seals TAM1089 on the sump pan which I understand are early morris minor .Are these better than the cork seals ? These rubber seals are hard to find. Since I will have the motor apart I will change bearings ,oil pump ,clutch ,water pump etc.The bore looks fine. Thanks for any input.
Graham W
jollyroger
Re: Updated crank seal
Tighten up the bearing clearances to a thou or a thou and a half. Use the cork rubber gaskets they are better. The oil coming out the rear labyrth seal is excess oil from the rear main that floods the rear slinger/labryth seal. Once the slinger area is filled with oil it is no longer a slinger. I run all my engine at .001 clearance. Keeping the bearing tight reduces the oil going to the slinger. The slinger can only handle so much oil. I have full on race engines that dyno to the rear axle 110 HP. I don't have massive puddles under any of my cars. I also run my pistons tight as well. I know someone is going to tell me I don't know what I am doing and this is too tight. I have been running my engines like this in competition for twenty plus years. Works on a big Healey too.
G
gwoz
Thanks Roger for the info.Are there any tricks on breathers to reduce crank case pressure ? Is this a factor ? My motor is vented at the pushrod cover plate and the valve cover.
GrahamW
jollyroger
I vent the 1275 out the dipstick tube. Can't do that on the others. I do vent the 948 out the rear side cover to the rear and up so the oil vapor runs back into the engine. Basically I take the front cover and move it to the rear and then I invert the pipe kinda up and run hose back to can mounted higher than the engine. Some guys put a vent tube in the oil pan near the rear and plumb it up to a can as well.
There are some kits that put a real rear seal on the back of the engines. I have found that mine leak so little I don't need to do it.
D Up-dated fuel delivery Jaguar 3
69sprite Up-dated Sprite Prices Spridgets 5
DrEntropy Dated as 1975 Racing 2
H Up-dated Flasher Relay Unit for Austin Healeys Austin Healey 1
CZ_Dave Still have the "B" that I dated my Bride in MG 6
Robert560 Up-dated my Healey website... Austin Healey 15
Robert560 Up-dated my Healey web page... Austin Healey 6
tony barnhill Up-dated Photos of the Little Midget Spridgets 33
GoBritBaby 3400M Up-dated Pics TVR 5
B TR4/4A Looking at a TR4 tomorrow. --Up-dated with pics!! Triumph 27
Brosky Great news from Puerto Rico!!! Up-dated 4:30PM Triumph 87
SCguy TR4/4A TR4 Engine start Last minute questions? Up-dated! Triumph 14
B Been awhile, but here she is! Pics Up-dated! PRIMED Spridgets 10
B Up-dated Pics! completely restored the drivers seat Spridgets 16
tony barnhill "theMGList" Up-dated Spridgets 0
tony barnhill "theMGList" Up-dated MG 11
LastDeadLast She actually started! [Up-dated with interior pics] Triumph 25
LastDeadLast Help me with a fast idle issue.. Up-dated Triumph 14
Basil EType Owners List Up-dated Jaguar 0
B TR6 71 block & crank Triumph 1
J Wanted WTB Bell Crank Pivot Triumph Classifieds 2
K TR2/3/3A What is the best way to prevent the crank from turning ........ Triumph 27
Michael Oritt Rear Crank Seal Kit Austin Healey 7
M Wanted Dampener Tr4a crank pulley Triumph Classifieds 9
T MG Midget 1500 crank shaft pulley Spridgets 0
S TR2/3/3A Tightening the crank pulley dog bolt on a tr3 Triumph 7
nichola TR6 Door handle and window crank installation Triumph 0
D TR2/3/3A TR3 throttle linkage bell crank. Triumph 30
R Wanted 3 main crank MG Classifieds 1
Twit early TR4 Crank Handle wanted Triumph Classifieds 0
P TR6 Tight window crank Triumph 9
71TR6 Triumph TR4 Coventry Radiator with crank hole- recently refurbished Triumph Classifieds 0
D TR2/3/3A TR3A Crank Dog Triumph 2
K TR2/3/3A The timing mark on the crank pulley.... Triumph 5
K For Sale Starter Hand Crank Triumph Classifieds 0
jtaylor3 1275 EN40 Crank Spridgets 5
J TR2/3/3A Flywheel-Crank Dowel Alignment Triumph 6
R TR2/3/3A Extension Crank Bolt Attachment Triumph 12
M Wanted TR3 Hand Crank Guide Triumph Classifieds 3
Alfred E. Neuman TR4/4A TR4 fan extension and crank bolt length Triumph 9
D TR2/3/3A Crank handle support Triumph 11
Got_All_4 TR2/3/3A Hand crank misalignment Triumph 9
K For Sale TR3 crank handle Triumph Classifieds 0
M Wanted TR-3 Crank Handle Triumph Classifieds 3
R TR2/3/3A Temperature Gauge for 1954 TR-2 & Hand Crank Triumph 17
Got_All_4 TR2/3/3A TR3 engine hand crank Triumph 14
ckeithjordan Wanted WTB: TR3 Crank Handle Guide Stays Triumph Classifieds 1
D BT7 tri-carb installing my crank Austin Healey 4
R General Tech Crank bearing cap broke...Torque?? Triumph 37
Rut Crank/flywheel dowels Spridgets 3
