Transmission seals- how to remove?
lbcfan
If this has been a prior topic I apologize.
I can't figure out how to remove the rear oil seal cap to install a new one.It seems to have been crimped in 3 places to hold it on. The service manual shows a special tool that looks as though a graduated screw was threaded into the drive shaft opening to pull the cap off.
The other pain is the oil seal in the bushing for the speedometer drive. No way to grab it to remove.
Any suggestions would be appreciated.
Michael
Gerard
Michael,
For the rear seal, you'll need to pry up the crimps to knock off the metal cap. A sharp chisel will usually do. If you have a Dremel with a cutoff wheel, and a steady hand, you could make some short slices (either parallel or perpendicular) that will make it a little easier. Pop the new one on and use a chisel to crimp into place.
I've never tried to replace the bushing for the speedo drive, so can't help there.
regularman
if its just a regular lip seal, you can use one of those slide hammers with the fingers that will lock in there. You can get one of the slide hammer kits cheap at harbor freight. It works good on a lot of things like that.
L
lbcfan
Thanks.
The fit seems so tight that getting anything in the crack will be difficult. I guess I'll have to destroy it to save it...
L
lbcfan
Gerard-
Got it done with a sawsall (don't ask).
Do you put any gasket sealer at the metal to metal when you press on the new seal cap?
Thanks again for all of the help.
Michael
Gerard
lbcfan said:
Gerard-
Michael
That sounds a little frightening... :hammer:
A little sealer wouldn't hurt.
Tim Hollister
Reminds me of the time I let my young son remove the differential from the race Midget. He wanted to help Dad get ready for the next race so why not?
On the way home from work, I called him and asked how it went. He told me had some trouble getting the differential itself out but he had successfully used the air chisel (what did he say?!?!) to break it loose from the axle housing!
Needless to say, I was very anxious during the rest of the drive home - an excruciating 35-40 minutes! All I could picture was a destroyed diff housing.
Luckily all it took was a little clean up with a file to smooth things out with no real damage done. Evidently the vibration and force of the air chisel broke it loose very quickly.
Overkill? I'd certainly say so! The son learned something and more importantly, so did I! LOL!
Tim
B Transmission seals Spridgets 12
C TR4/4A Transmission seals that do? Triumph 6
WillR MGB transmission seals worth replacing? MG 8
gbtr6 TR6 Transmission seals Triumph 21
hondo402000 TR6 Transmission Seals, TR6, where to get them Triumph 2
Johnny Transmission oil seals Austin Healey 8
Jim_Gruber Correct Transmission Oil for Datsun 210 5-speed Spridgets 1
mctriumph SOLD!! Tr7/ Tr8 transmission Triumph Classifieds 0
C TR6 Transmission Number Meaning Triumph 5
R 100-4 Transmission Austin Healey 1
J TR4/4A TR4A automatic transmission conversion Triumph 6
Popeye TR4/4A Transmission noise - intermittent Triumph 22
D XK150 Transmission Input Shaft Jaguar 1
A TR2 Transmission overhaul Restoration & Tools 0
E General MG Transmission Fluid Level MG 2
B Transmission Gear Lockouts Austin Healey 8
K Putting a Getrag 5 speed OD transmission in a Jaguar Mkll ? Jaguar 4
AUSMHLY Transmission Noise Austin Healey 11
KVH General TR Transmission Problem Triumph 3
T Looking for "BillMs rear transmission mount" Spridgets 2
T For Sale Excellent Original 1968 TR250 Frame with Engine & Transmission Triumph Classifieds 6
D TR2/3/3A Torque for bolts back of transmission ? Pl Triumph 0
bighealeysource Side-Shift Transmission Austin Healey 13
D transmission conversion Other British Cars 1
PAUL161 T-Series Original transmission sold MG 2
KVH TR4/4A Assembling Transmission to Engine--Vice/Versa Triumph 4
BritBite Transmission Repair Austin Healey 8
AUSMHLY Transmission Bearing, Sealed vs. Non-Sealed Austin Healey 6
AUSMHLY BJ8 Transmission Gasket Austin Healey 0
AUSMHLY R & R BJ8 Transmission Bearings Procedure Austin Healey 1
AUSMHLY BJ8 transmission 3rd gear chipping Austin Healey 0
AUSMHLY BJ8 transmission mainshaft bearing force needed to install/remove Austin Healey 1
AUSMHLY BJ8 Transmission Oil Capacity Austin Healey 1
TR6Canuck For Sale 72 TR6 clutch and transmission Triumph Classifieds 4
N Ribcase transmission won’t engage 3rd or 4th gear Spridgets 19
N Sprite "Ribcase" Transmission Austin Healey 3
AUSMHLY Transmission Sliding Hub Plungers Austin Healey 9
AUSMHLY BJ8 Transmission Front/Rear Bearing Shim Austin Healey 2
AUSMHLY Denis Welch Pre-Load Transmission Washers Austin Healey 0
AUSMHLY BJ8 Transmission just rebuilt now has metal filings Austin Healey 10
S MGB Transmission cross member re-install MG 14
AUSMHLY Flushing the Transmission/Overdrive Austin Healey 7
WHT BJ8 Transmission Installation Austin Healey 0
T Weight of BJ7 Transmission/Overdrive Austin Healey 10
T How to ship transmission from Canada to Rivergate in Tennesee? Spridgets 8
AUSMHLY BJ8 Transmission Gasket Sealer Austin Healey 18
