TR4/4A Transmission leak
Zimmycobra
Folks:
When I rebuilt the mechanical systems on this TR4A IRS (no OD), I did not rebuild the gearbox. It operated very nicely and seemed okay. I cleaned and repainted the exterior and changed the oil completely. The car has been driving for over a year and there is no apparent operational problem with the gearbox. I have noticed a significant amount of oil under the car after being parked for a while. My first thought was the rear engine seal, even though I had it changed to the new style when I had the engine block redone. (Engine sat for almost a year before running after the rebuild) While the leak is reasonable, I do not see a drop in engine oil level. This is making me think that it may be the gearbox leaking from the front seal perhaps (maybe a bit at the rear but hard to say). As most of you know, it is sometimes hard to see exactly where the oil is coming from.
If the gearbox seal or seals is leaking, I really am not relishing the removal and seal replacement right now. I have heard some good things about Blue Devil products for sealing leaks and they do have a transmission product for auto and manual gearboxes. Does anyone have experience with these products - good or bad? Just wondering if it might be an easy and effective way to go until time allows for the removal and resealing of the gearbox.
Your thoughts and recommendations are as always requested and respected. :eagerness:
Regards:
Zimmy
TomMull TR2/3/3A Transmission oil leak Triumph 17
KVH General Tech OD Transmission Leak Triumph 5
trrdster2000 GT6 Leak in transmission Triumph 2
Bremer TR2/3/3A Leak from transmission Triumph 4
S Spitfire Triumph Spitfire 74 transmission bellhousing leak Triumph 6
T 1275 transmission oil leak Spridgets 2
KVH TR4/4A TR4A Transmission Overdrive Plug Leak Triumph 13
hondo402000 TR6 Transmission Leak TR6 Triumph 28
hondo402000 TR6 TR6 Transmission leak Triumph 5
MadRiver Major BT7 Transmission Leak Austin Healey 6
Y TR4/4A TR-4 Transmission/OD leak Triumph 2
Luke_Healey Transmission leak or overfill? 1098cc engine Spridgets 9
healeyboz Transmission leak Spridgets 11
KVH Transmission Leak Triumph 3
E BN 2 Transmission Leak Austin Healey 9
Jim_Gruber Correct Transmission Oil for Datsun 210 5-speed Spridgets 1
Got_All_4 General Tech TR6 Transmission Troubles Pops Out of 3rd gear Triumph 2
mctriumph SOLD!! Tr7/ Tr8 transmission Triumph Classifieds 0
C TR6 Transmission Number Meaning Triumph 5
R 100-4 Transmission Austin Healey 1
J TR4/4A TR4A automatic transmission conversion Triumph 6
Popeye TR4/4A Transmission noise - intermittent Triumph 22
D XK150 Transmission Input Shaft Jaguar 1
A TR2 Transmission overhaul Restoration & Tools 0
E General MG Transmission Fluid Level MG 2
B Transmission Gear Lockouts Austin Healey 8
K Putting a Getrag 5 speed OD transmission in a Jaguar Mkll ? Jaguar 4
AUSMHLY Transmission Noise Austin Healey 11
KVH General TR Transmission Problem Triumph 3
T Looking for "BillMs rear transmission mount" Spridgets 2
T For Sale Excellent Original 1968 TR250 Frame with Engine & Transmission Triumph Classifieds 6
D TR2/3/3A Torque for bolts back of transmission ? Pl Triumph 0
bighealeysource Side-Shift Transmission Austin Healey 13
D transmission conversion Other British Cars 1
PAUL161 T-Series Original transmission sold MG 2
KVH TR4/4A Assembling Transmission to Engine--Vice/Versa Triumph 4
BritBite Transmission Repair Austin Healey 8
AUSMHLY Transmission Bearing, Sealed vs. Non-Sealed Austin Healey 6
AUSMHLY BJ8 Transmission Gasket Austin Healey 0
AUSMHLY R & R BJ8 Transmission Bearings Procedure Austin Healey 1
AUSMHLY BJ8 transmission 3rd gear chipping Austin Healey 0
AUSMHLY BJ8 transmission mainshaft bearing force needed to install/remove Austin Healey 1
AUSMHLY BJ8 Transmission Oil Capacity Austin Healey 1
TR6Canuck For Sale 72 TR6 clutch and transmission Triumph Classifieds 4
N Ribcase transmission won’t engage 3rd or 4th gear Spridgets 19
N Sprite "Ribcase" Transmission Austin Healey 3
AUSMHLY Transmission Sliding Hub Plungers Austin Healey 9
AUSMHLY BJ8 Transmission Front/Rear Bearing Shim Austin Healey 2
