[ QUOTE ]
The day after driving my BN 2 I have a pool of transmission oil on the floor of my garage. Some may be coming out of the front seal, leaking through the bell housing, but the bulk of the puddle seems farther back. The leak is not a drip- it is a large, dinner plate size puddle. What do you think? It is a scary amount of oil. Any ideas?
Mike--
first thing to determine is whether it is engine oil or transmission oil. If the oil in your engine is detergent and you've driven any miles at all it should have begun to "change" and be noticeably different from that in the tranny. In the meantime check the respective levels in the engine and transmission--with that much you should see a difference on the dipstick or at the fillhole. Also, is it possible that you overfilled the transmission and that it is coming out a vent?
Good luck and keep us posted.
