TR4/4A TR-4 Transmission/OD leak
yelsink
Member
Had engine & Trans/OD rebuilt, new gears etc. 1500 miles ago. I know the crank pan leaks, but not bad. But I have a transmissinon oil leak someplace. Anybody have any suggestions as to what it might be?
bgbassplyr
Normal?
TR3driver
Great Pumpkin - R.I.P
Could be almost anywhere, but the places I've had the most trouble with are the adapter plate (which can get distorted until it won't seal) and the OD drain plug.
Oh yeah, and the seals for the shift rods. Seems that most of the replacements sold these days don't fit properly unless you add a backing washer behind them.
TomMull TR2/3/3A Transmission oil leak Triumph 17
KVH General Tech OD Transmission Leak Triumph 5
trrdster2000 GT6 Leak in transmission Triumph 2
Zimmycobra TR4/4A Transmission leak Triumph 1
Bremer TR2/3/3A Leak from transmission Triumph 4
S Spitfire Triumph Spitfire 74 transmission bellhousing leak Triumph 6
T 1275 transmission oil leak Spridgets 2
KVH TR4/4A TR4A Transmission Overdrive Plug Leak Triumph 13
hondo402000 TR6 Transmission Leak TR6 Triumph 28
hondo402000 TR6 TR6 Transmission leak Triumph 5
MadRiver Major BT7 Transmission Leak Austin Healey 6
Luke_Healey Transmission leak or overfill? 1098cc engine Spridgets 9
healeyboz Transmission leak Spridgets 11
KVH Transmission Leak Triumph 3
E BN 2 Transmission Leak Austin Healey 9
Jim_Gruber Correct Transmission Oil for Datsun 210 5-speed Spridgets 1
mctriumph SOLD!! Tr7/ Tr8 transmission Triumph Classifieds 0
C TR6 Transmission Number Meaning Triumph 5
R 100-4 Transmission Austin Healey 1
J TR4/4A TR4A automatic transmission conversion Triumph 6
Popeye TR4/4A Transmission noise - intermittent Triumph 22
D XK150 Transmission Input Shaft Jaguar 1
A TR2 Transmission overhaul Restoration & Tools 0
E General MG Transmission Fluid Level MG 2
B Transmission Gear Lockouts Austin Healey 8
K Putting a Getrag 5 speed OD transmission in a Jaguar Mkll ? Jaguar 4
AUSMHLY Transmission Noise Austin Healey 11
KVH General TR Transmission Problem Triumph 3
T Looking for "BillMs rear transmission mount" Spridgets 2
T For Sale Excellent Original 1968 TR250 Frame with Engine & Transmission Triumph Classifieds 6
D TR2/3/3A Torque for bolts back of transmission ? Pl Triumph 0
bighealeysource Side-Shift Transmission Austin Healey 13
D transmission conversion Other British Cars 1
PAUL161 T-Series Original transmission sold MG 2
KVH TR4/4A Assembling Transmission to Engine--Vice/Versa Triumph 4
BritBite Transmission Repair Austin Healey 8
AUSMHLY Transmission Bearing, Sealed vs. Non-Sealed Austin Healey 6
AUSMHLY BJ8 Transmission Gasket Austin Healey 0
AUSMHLY R & R BJ8 Transmission Bearings Procedure Austin Healey 1
AUSMHLY BJ8 transmission 3rd gear chipping Austin Healey 0
AUSMHLY BJ8 transmission mainshaft bearing force needed to install/remove Austin Healey 1
AUSMHLY BJ8 Transmission Oil Capacity Austin Healey 1
TR6Canuck For Sale 72 TR6 clutch and transmission Triumph Classifieds 4
N Ribcase transmission won’t engage 3rd or 4th gear Spridgets 19
N Sprite "Ribcase" Transmission Austin Healey 3
AUSMHLY Transmission Sliding Hub Plungers Austin Healey 9
AUSMHLY BJ8 Transmission Front/Rear Bearing Shim Austin Healey 2
