TR6 tr6 su conversion
rjc157
does anyone know what to do with the vacume advance where does it get connected or does it even get connected ,
poolboy
What year car ? I probably should ask what distributor ?
If the module you are concerned about is on the cockpit side of the dizzy, it's a vacuum retard.
In that case don't worry about it. Once your engine gets past 1100 rpms vacuum has dropped and the centrifugal advance weights are taking over the timing.
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
I TR6 TR6 EFI Conversion Triumph 19
B TR6 Moss TR6 Vacuum Advance Conversion question Triumph 8
S TR6 TR6 speedo to electronic conversion anyone? Triumph 15
Coyote1 TR6 Weber 45 MCHH conversion for TR6 Triumph 15
B TR6 TR6 Weber 45 MCHH Conversion Kit Triumph 10
bobh TR6 New TR6 Transmission Conversion Triumph 3
rjc157 TR6 tr6 su conversion Triumph 8
H TR6 TR6 HS6 Conversion Triumph 6
YYCDave TR6 TR6 Rear Shock Conversion & Tire Size Triumph 2
DanNagy TR6 TR6 Weber Carb Conversion Triumph 11
B TR6 TR6 alternator conversion Triumph 20
mgbmedic MGB MGB or TR6 -- 280Z 5 Speed Conversion MG 2
T TR6 Thoughts on HS6 conversion for TR6? Triumph 11
C TR6 TR6 Shock Conversion Kits Triumph 13
LeeMcKee TR6 TR6 Five Speed Conversion? Triumph 5
A TR6 TR6 heater fan conversion?? Triumph 5
A TR6 FREE, Manual Overdrive Shifter conversion [tr6] Triumph 1
kodanja TR6 TR6 Ford type 9 conversion Triumph 0
A TR6 TR6- Group buy of Moss axle and hub conversion?,or Triumph 4
A TR6 tr6 5speed conversion??? Triumph 14
G TR6 TR6 seat conversion Triumph 10
V TR6 TR6 Fiberglass bumper conversion? Triumph 1
milemarker60 TR6 TR6 Roadster Conversion? Triumph 10
v8triumph TR6 Rover V8 Conversion TR4 - TR6 chassis Triumph 8
Webb Sledge TR6 TR6 Carb to Lucas Injection Conversion Triumph 4
B TR6 TR6 Electronic Ignition Conversion Triumph 10
G TR6 TR6 V8 Conversion Triumph 14
bigbadbluetr6 TR6 tr6 tranny conversion? Triumph 11
B TR6 Tr6 4 speed to 5 speed conversion? Triumph 13
C For Sale 69 Triumph TR6 Racecar Triumph Classifieds 0
