TR6 tr6 su conversion
rjc157
currently running hs6 su's on my tr6 and feel they run better than the strombergs am thinking of going with a goodparts triple conversion is there anyone out there that has done this conversion and have any thoughts or problems with it thanks
Platinum
You won't regret the trip's!!! Tho I'm no 'rumphie I've done the deed (well in the past) and it'll transform the car.
DNK
Isn't there been a problem with the SU trips. as being to wide?
swift6
If your using HS6's then the side mount float bowls can interfere. Those three carbs are fairly close together on the triple carb manifold. Its the center carb that can cause the tight squeeze issue. Triple SU HIF44's would be pretty good though.
martx-5
swift6 said:
... Triple SU HIF44's would be pretty good though.
That's what Tony at Ratco runs. No trouble with the fit.
swift6
The reason the SU HIF44's work well is because they have an integrated float bowl, just like Zenith Strombergs.
rjc157
rjc157
another question to the group with a stock motor is it even worth the time and trouble and expence to go with a triple set up or just leave it as a dual setup
DNK
If you have a stock motor ,leave it that way
poolboy
I agree. Your engine will get all the fuel it needs with 2 carbs having 1.75 inch throats.
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
I TR6 TR6 EFI Conversion Triumph 19
B TR6 Moss TR6 Vacuum Advance Conversion question Triumph 8
S TR6 TR6 speedo to electronic conversion anyone? Triumph 15
Coyote1 TR6 Weber 45 MCHH conversion for TR6 Triumph 15
rjc157 TR6 tr6 su conversion Triumph 2
B TR6 TR6 Weber 45 MCHH Conversion Kit Triumph 10
bobh TR6 New TR6 Transmission Conversion Triumph 3
H TR6 TR6 HS6 Conversion Triumph 6
YYCDave TR6 TR6 Rear Shock Conversion & Tire Size Triumph 2
DanNagy TR6 TR6 Weber Carb Conversion Triumph 11
B TR6 TR6 alternator conversion Triumph 20
mgbmedic MGB MGB or TR6 -- 280Z 5 Speed Conversion MG 2
T TR6 Thoughts on HS6 conversion for TR6? Triumph 11
C TR6 TR6 Shock Conversion Kits Triumph 13
LeeMcKee TR6 TR6 Five Speed Conversion? Triumph 5
A TR6 TR6 heater fan conversion?? Triumph 5
A TR6 FREE, Manual Overdrive Shifter conversion [tr6] Triumph 1
kodanja TR6 TR6 Ford type 9 conversion Triumph 0
A TR6 TR6- Group buy of Moss axle and hub conversion?,or Triumph 4
A TR6 tr6 5speed conversion??? Triumph 14
G TR6 TR6 seat conversion Triumph 10
V TR6 TR6 Fiberglass bumper conversion? Triumph 1
milemarker60 TR6 TR6 Roadster Conversion? Triumph 10
v8triumph TR6 Rover V8 Conversion TR4 - TR6 chassis Triumph 8
Webb Sledge TR6 TR6 Carb to Lucas Injection Conversion Triumph 4
B TR6 TR6 Electronic Ignition Conversion Triumph 10
G TR6 TR6 V8 Conversion Triumph 14
bigbadbluetr6 TR6 tr6 tranny conversion? Triumph 11
B TR6 Tr6 4 speed to 5 speed conversion? Triumph 13
C For Sale 69 Triumph TR6 Racecar Triumph Classifieds 0
