A few years ago I converted my overdrive to a manual shift. With my new engine Im going with the Supra 5sp conversion, so Im giving my overdrive manual shift conversion away. It includes shifter,boot and mounting bracket and cable and two mounting brackets for the cable. I had the cable custom made, the shifter is a small custom back and forth shifter that mounted under the trans cover with the shift rod sticking through--down and to the left of the regular shifter.(my cost was about $160)It really was a nice set up and looked good in the car (sorry no pictures), it worked really well and was able to shift up and down in second through fourth gear-giving you seven speeds.(very fast and positive shifting). The set up only has about 500 miles on it and here is what you would have to do---Mount all brackets, adapt the end of the cable to the overdrive shifting lever, cut a small oval hole in your cover for the shift rod to stick through and operate, mount the boot. you would need a little skill in getting this back the way it was mounted in my car. I would like to see it go to a good home with someone who will be able to use it. So Here it is FREE to the first private message. you pay shipping.
