Why do I think I can do these things. I did get the old grill off the car, and have the top four screws in properly with spire nuts. The screw holes in the bottom of the grill do not align of course, but for now it looks okay and I will wait for the non-driving season to fix that. When I removed the grill I also took off the front bumper, and now one of the nuts to bolt the bumper on does not line up with the hole in the front apron. If I insert the bolt in from the frame towards the front of the car, I can see about 3/4 of the bolt with the remaining part hidden behind sheet metal. Is there an easy way to flex this to get them aligned?
Also, when I removed the turn signals to take out the old grill, I found that all the wires to the lights had press in connections under the hood, and the three wires coming out the back of the lights are all black. I thought I had properly labeled five of the wires before detaching, but the sixth wire on the right turn signal was not attached to anything. I believe it was to be the ground, but I cannot find where that would have been attached. On the left side there were adjacent grounds for the headlight and turn signal, but that is not the case on the right side. When I turn on the parking lights, the rights side is now brighter than the left, but I don't know if that was the case before. When I turn on the left turn signal, all is well with the world. But when I turn on the right turn signal, the front one has a dim glow, and the rear one does nothing now. I tried swapping the two wires in the turn signal itself that are close to each other, but that does not seem to have an effect.
Any suggestions to either of my problems before I drive it back into the shop?
