TR2/3/3A TR3 [Toyota] trans question
TexasKnucklehead
My Bently manual doesn't document the Toyota conversion option, and the HVDA instructional manual is not very specific. It seems I have a 5-speed from a Supra, and have ordered some speed-0-meter gears for it. After those are installed, I'll need to add oil until it flows out the fill plug. Where is the fill plug? Is it the gold colored plug on the right side (center of attached picture sideB)?
Having the motor and transmission installed makes the frame look almost like it might be a car again.
tinman58
It is the big one to the left of the black bracket in the top photo.
You will love the 5-speed trans. and it won't leak oil.
Make sure that the drive shaft is a no slip it need to be solid. The yoke from the output shaft (the one from Herman) is the only slip you need. Or in about 1000 miles you will be buying another trans. The driveshaft will smash into the rear oil seal and then it will leak.
Gliderman8
Dan is correct... the plug is to the left of the black bracket. I just completed the same conversion in my TR6.
I don't see the back-up switch clearly in your photo. Could be that the wires are cut short. Before I put the trans oil in, I checked the continuity of the back-up switch and found mine to be bad. You might want to hook up the meter and throw it in reverse a couple of times to check your switch. It's a lot easier to put a new one in now.
Good luck with the conversion... it has been the best addition hands-down that I've done to my car!
T
TexasKnucklehead
Thanks.
I'll check the reverse switch, but the TR3 doesn't have back-up lights. I might add one of those annoying beepers to the switch.
So this is the fill hole?
BobbyD
B TR2/3/3A Mounting Toyota Brake Calipers on my TR3 Triumph 5
tinman58 TR2/3/3A Toyota brakes on a TR3? Triumph 8
T TR2/3/3A Toyota calipers on a TR3 Triumph 11
T TR4/4A Toyota brake conversion for TR3 or TR4a Triumph 7
K TR2/3/3A Toyota transmission for TR3=long distance driving Triumph 13
prb51 TR2/3/3A Tr3 club Toyota conversion Triumph 24
gsalt57tr3 TR2/3/3A 5 speed Toyota transmissions in a TR3 Triumph 3
R TR2/3/3A TR3 Timminge Triumph 11
J For Sale Triumph TR2 TR3 rocker panels, right and left Triumph Classifieds 0
J For Sale Triumph TR2 TR3 Channel - Drip - Rear Edge Triumph Classifieds 0
J For Sale TR2 TR3 Tie Member Triumph Classifieds 0
S TR2/3/3A tr3 valve spring compressor Triumph 5
