TR2/3/3A TR3 tie rod ends
mapleaf
I'm trying to identify some spare tie rod ends and was wondering what the differences are between the inner and outer ends? Thanks
Don Elliott
Check the positions in the photo for the grease fittings. The outer tie rod end has the 90 degree Zert sticking out the round top. For the inner tie rod end, the 90 degree Zert is out the side of the casting and is aiming upwards and facing a bit to to the front. Set the inlets for all your grease fitings so you can easily reach them next time you grease them with your grease gun.
TR3driver
Great Pumpkin - R.I.P
They also have opposite-handed threads, although I forget offhand which is which.
M
Member 10617
Could you circle or otherwise mark the two zerts in the photo?
martx-5
I assume you mean for the tie rod ends...
M
mapleaf
Thanks guys.
Don, from your answer and pic it would appear that:
- the left and right outer ends are the same
- the left and right inner ends differ in that the grease fittings are on
opposite sides, allowing for easy access on the top side, when fitted.
Some of my spare ends are the ones without grease fittings so by comparing threads with the zerk type ends it looks like the inners are right hand thread and the outers are left hand thread.
If I've got this right, I can now mark them and I'm done.
Thanks again.
Don Elliott
That photo is a bit dusty, but was taken about 2005 or 2006 as I was finishing the restoration of a late TR3A for Frank in Toronto.
K TR2/3/3A TR3 Tie Rod Sleeve Triumph 2
K Wanted TR3 Tie Rod Sleeve Triumph Classifieds 2
newmexTR3 TR2/3/3A Separating Tie Rod Ends from Steering Arms TR3 Triumph 18
T TR2/3/3A TR3 tie rods - made of precious metal or what? Triumph 6
mountainman TR2/3/3A TR3 Tie Ends Triumph 4
jfarris For Sale TR3 Stock Fan used (1956) Triumph Classifieds 0
jfarris For Sale TR3 Speedometer SOLD Triumph Classifieds 3
S TR2/3/3A My tr3 was stuck in reverse after a short drive Triumph 3
luke44 TR2/3/3A TR3 not engaging 2nd gear Triumph 24
