TR2/3/3A TR3 Rear Leaf Spring Shackle Bushes Upgrade
karls59tr
Bronze
Going thru my parts bin and found a kit that I ordered online some time ago and forgot I had. It consists of bronze bushings and large flat washers that go over the shackle pins to replace the rubber bushes.It seemed like a good idea at the time I bought the kit, in that it would provide lateral stability and prevent sideways movement, but now I'm wondering how it would affect the ride seeing as how there are no rubber components in the setup?(Well I know it's a buckboard ride anyway but...:smile:. Anyone have an opinion on this mod?
T
TRDejaVu
If that is the Joe Alexander kit, then I fitted it to my TR4. It should be noted that I replaced the mount on the other end as well and also stripped down, cleaned and applied UHMW tape to the spring leafs. After all that, the car rode tighter and smoother than before, although not modern car standard by any stretch of the imagination.
Moseso
I've got that kit too. No problems. It DOES seem to make the car respond a little more consistently than the old rubber bushes.
K
karls59tr
Bronze
Not sure if its the Joe Alexander kit. How difficult was it to install the kit? I'm assuming I should soak the old spindles and bushes with penetrating oil for a night or two before removal. Any unforseen difficulties in the change out? I think I'm going to leave the silent bush at the front of the spring because of the horror stories I hear about removal. One day when I lift the body off I'll tackle yjat job. Not even sure if the front bush can be removed with the body on?
TR3driver
Great Pumpkin - R.I.P
Depends on whether you can get the pins out or not. I changed both of my front bushes recently, with the body on the frame.
Being somewhat dubious about the benefits of the bronze rear bushings on the street, I went with the poly ones from TRF, and stock silentblocs up front. Even with my low profile, sticky tires, evidence seems to suggest that the rear end doesn't move around enough to matter unless you are seriously into autocrossing or similar racing.
Twosheds
Sounds more like Ken Gillanders' kit to me. I put one on the TR3 racecar.
Didn't notice a huge difference either way, but I changed several things at once.
M_Pied_Lourd
Karl,
I have installed them on mine. Is this what yours look like?
Cheers,
David
K
karls59tr
Bronze
Randall Did you have to jack the car body up as high as you could and then use the fabricated tool to remove the pin?
M_Pied_Lourd
Bought it from The Roadster Factory. I believe they source it from ARE
https://www.the-vintage-racer.com/webroot/Chassis_Suspension/
I did it a little while ago but as I recall I had to ream the bushing a little bit and then before assembly I used a wheel bearing/axle grease on the spindle.
Cheers,
David
TR3driver
I just put the car up on stands, as usual for doing any work underneath. High enough to get my impact gun onto the U-bolt nuts, but not particularly high as I recall. And my "fabricated tool" was just some bits of hardened all-thread, nuts, washers sockets, pieces of pipe, etc. Sorry I didn't think to take any pictures.
Twosheds
I'm wrong.
Ken Gillanders' kit used big fender washers, if I remember correctly.
K
karls59tr
Bronze
Do you think there would be much difference between the fender washers and the nylon /urethane washers? I might have bought the Ken Gillanders kit as the washers you mention were in the bag with the bronze sleeves. Oddly enough I found a set of the nylon/urethane washers kicking around in the box as well!!! Maybe the urethane would have bit of flex...but is that a good thing?
Twosheds
Ken lists a stainless and nylatron rear spring locating kit: https://www.britishframeandengine.com/parts1.html
No photo.
This is the one I put on the racecar. I have to say that I forget if it was for the front or the back mounting!
I think it came in Racetorations packaging. But we've already found that my memory is failing, haven't we?
TR3driver
Don't know if the same would apply to the rear suspension, but Ken recently told me that he has quit stocking the Nylatron front suspension parts. Apparently, the fact that they last darn near forever has really killed the demand for them :laugh:
K TR2/3/3A TR3 Rear Leaf Spring Front Pin Removal Triumph 17
H TR2/3/3A TR3- installing rear leaf springs = nightmare.... Triumph 5
J For Sale Triumph TR2 TR3 Channel - Drip - Rear Edge Triumph Classifieds 0
jfarris For Sale TR3 Rear Sway Bar Triumph Classifieds 0
Donald1107 TR2/3/3A TR3 Rear Shocks Triumph 11
B Wanted TR3 Hardtop Rear Stiffener Brackets Triumph Classifieds 0
J TR2/3/3A TR3 Rear seat Triumph 11
K For Sale TR3 rear rebound brackets Triumph Classifieds 0
J For Sale Triumph TR3 rear differential and rear brake assembly - Northern Illinois Triumph Classifieds 1
E For Sale Tr3 rear axle, rear end Triumph Classifieds 6
K For Sale TR3 rear cockpit center capping Triumph Classifieds 0
J Wanted Need tr3 rear axle housing Triumph Classifieds 0
D TR2/3/3A TR3 Engine dumping Coolant out its rear end - HELP Triumph 5
A TR2/3/3A Newbie wrestling with TR3 rear wheel studs Triumph 3
Tinkerman TR2/3/3A TR3 A REAR WING BOLTS order of assembly? Triumph 3
Got_All_4 TR2/3/3A Tr3 rear differential seal Triumph 7
J TR2/3/3A Tramp bar for rear of TR3 or?? Triumph 7
mgedit TR2/3/3A Steady Springs Rear Brakes 56 TR3 Triumph 0
jfarris TR2/3/3A Wanted - TR3 Monza Muffler - Rear Section Only Triumph 1
M TR2/3/3A TR3 overdrive trans rear speedi sleeve Triumph 6
K TR2/3/3A TR3 Exhaust header's proximity to rear of generator? Triumph 4
J TR2/3/3A Strange fiberboard panel behind rear seat in TR3 Triumph 10
1937dodge TR2/3/3A Anyone have any photos of TR3's sporting rear finned aluminum brake drums? Triumph 8
T TR2/3/3A TR3 Rear wheel cylinder attachment clips Triumph 6
mgedit TR2/3/3A Rear Drum Brakes 56 TR3 Triumph 2
rckuhlman TR2/3/3A TR3 Castle Nut on Right Rear Axle Triumph 3
K TR2/3/3A TR3 4:11 gears in rear Diff Triumph 6
S TR2/3/3A rear brakes tr3 Triumph 1
S TR2/3/3A tr3 rear main Triumph 24
M TR2/3/3A Topping off rear shocks on TR3 Triumph 11
Kleykamp TR2/3/3A TR3 rear fender bolts Triumph 2
RickAnderson TR2/3/3A Wanted: TR3 Rear Bumper Overrider - any condition. Triumph 2
M TR2/3/3A TR3 rear axle hub gasket ???? Triumph 4
S TR2/3/3A rear fender vinyl tr3 Triumph 6
mgedit TR2/3/3A Rear capping 56 TR3 Triumph 4
M TR2/3/3A Topping off rear shocks on TR3 Triumph 13
Kleykamp TR2/3/3A TR3 rear fender needed Triumph 18
K TR2/3/3A TR3 rear overider distance from body? Triumph 3
Tr3aguy TR2/3/3A Rear Lettering TR3 post 60000 Triumph 3
luke44 TR2/3/3A TR3 Rear Bumper Overriders - Upside Down? Triumph 12
T TR2/3/3A The light came on: my TR3 rear apron. Triumph 12
S TR2/3/3A tr3 rear interior panels Triumph 6
J TR2/3/3A TR3 Rear Apron Replacement Triumph 4
K TR2/3/3A TR3 Rear Overider Bracket "distance tube"? Triumph 10
J TR2/3/3A stainless steel rear spring pins for TR3 Triumph 19
O TR2/3/3A TR3 Rear Main Seal Triumph 5
A TR2/3/3A More TR3 Rear main seal problems. Please Help!! Triumph 8
J TR2/3/3A '56 TR3 Brakes and rear axle advice Triumph 7
tinman58 TR2/3/3A Rear main seal TR3 Triumph 11
O TR2/3/3A TR3 Rear Turn lights Versus Rear Stop Tail lights? Triumph 5
