TR2/3/3A TR3 motor mount
bnw
Should I shim the motor mounts on my smallmouth so the dog in the fan bolt lines up perfectly with the hole in the radiator for the hand crank, or am I going over the deep end here?
TR3driver
Great Pumpkin - R.I.P
If you kept the hole & support for the hand crank, then you might as well go ahead and make them usable, IMO. Having the nose of the motor up a bit higher makes it easier to change fan belts anyway.
OTOH, I abandoned the hand crank many years ago, and I can't say I've ever missed it.
B
bnw
I had too many starter failures when I was a kid in the 60s to give up the hand crank. As for the shims, do I make them, or are they out there?
TR3driver
TRF has them on sale at the moment. P/N 109582.
Last time I had a starter problem was 2001, on the way home from VTR in Breckenridge, CO (1000 miles each way). Made me mad enough to buy a "gear drive" replacement, which is still working fine today.
Geo Hahn
If you choose to make some shims, they look like thia:
When I had my radiator recored I kept the crank hole -- only reason I redid the rad was because the apron was already off for the timing chain and although the radiator cooled fine it was pretty beat up.
I had to shim the motor mounts a bit as the crank hole in the replacement core was a tad high. Might as well do new motor mounts if you haven't already.
I once had the starter fail on day 1 of a ten day trip. Got in a lot of practice:
Also a bit of fun to demonstrate at car shows and, of course, handy when adjusting valves & timing.
B
bnw
I posted this about a year ago:
In 1966, I stalled my 1960 TR3 in the middle of a busy 5 way intersection in Chicago. My starter, of course, was junk. Just as the impatient drivers at all 5 stoplights were about to get on their horns, I jumped out of the car, hand crank in hand, stuffed it in the guide in front, brought it up on compression and gave it a quick snap. She lit up instantly ( I had done this before ) I jumped back in and proceeded to drive off to a melody of hoots, beeps and applause. THAT is why I've scrapped (sold) a perfectly good R&P. I was 18 at the time.
TODAY: That is also why the hand crank MUST work on my 57!
TR3driver
Good one!
CJD
That's what the wife is for...to pop the clutch while you push!! I went for a year in the '70's with a bad starter...just picked a good incline before I turned 'er off.
John
Tr3aguy
I pulled the push start on a date once.....leaving the house as her father watched......bad battery....I had to show him the car started before I could take her out again. Oh yeah and I did get her home on time.... :driving:
ekamm TR2/3/3A tr3 motor mount Triumph 5
PatGalvin TR2/3/3A TR3 Shifter and Motor Mount Support Ques... Triumph 7
J TR2/3/3A TR3 fan and motor mount R&R Triumph 4
R TR2/3/3A TR3 Wiper motor Triumph 10
Joel Lester TR2/3/3A TR3 Wiper motor wiring and testing Triumph 5
K TR2/3/3A TR4 motor with overdrive in a TR3 slave cylinder mounting position? Triumph 2
S TR2/3/3A When lifting the tr3 motor Triumph 10
NutmegCT TR2/3/3A TR3 - Motor Trend magazine, 1956 Triumph 2
S TR2/3/3A grease in tr3 D2 wiper motor Triumph 2
S TR2/3/3A color of tr3 D2 wiper motor Triumph 5
S TR2/3/3A Wiper motor brushes tr3 Triumph 2
S TR2/3/3A wiper motor tr3 Triumph 4
S TR2/3/3A new tr3 motor Triumph 7
T TR2/3/3A How do I remove fan on TR3 heater motor? Triumph 6
tinman58 TR2/3/3A How to break in a TR3 motor Triumph 7
mgedit TR2/3/3A Wiper Motor Bracket for 56 TR3 Triumph 9
C TR2/3/3A TR3 w/motor swap FS Triumph 14
K TR4/4A Putting aTR4 motor and trans in a TR3 Triumph 4
B TR2/3/3A tr3 or 4 motor? Triumph 16
mountainman TR2/3/3A TR3 Wiper Motor Triumph 4
mountainman TR2/3/3A TR3 Wipper Motor Wiring Triumph 4
P TR2/3/3A tr3 wiper motor mounting Triumph 7
mountainman TR2/3/3A TR3 Windsheild wiper Motor Question Triumph 4
Got_All_4 TR5/TR250 Switching a TR3 wiper motor over to a TR250 Triumph 4
Tinkerman TR2/3/3A Reasembly of Starter motor, TR3 Triumph 4
Moseso TR2/3/3A Deep in the TR3 motor Triumph 12
K TR2/3/3A Torqing the head again?....rebuilt motor... TR3 Triumph 4
M TR2/3/3A TR3 Wiper Motor Rebuild Triumph 8
martx-5 TR2/3/3A TR3 Wiper Motor Triumph 3
C TR2/3/3A Motor and Trans Out!!! TR3 shift lever??? Triumph 6
JPeter TR2/3/3A TR3 motor mounts Triumph 5
gsalt57tr3 TR2/3/3A TR3 Windsheild Wiper Motor Triumph 7
