TR2/3/3A tr3 motor mount
ekamm
So I got a SMALL case of the while I'm in there. I notice jacking up my motor to get the steering gearbox out that the motor mounts were pretty much jello. So I decided no better time than the present to replace them. When I took them out there were two slotted "shims" I guess that I would call them. The parts catalog says the are as needed. I guess that my question is what do they do and how many are needed?
Geo Hahn
I've never messed with them but I would think the idea is to use as needed to get the hand crank dog to line up with the hole in the radiator. But then I suppose the hole in the radiator has become an 'as needed' item itself.
ekamm
ekamm
Makes sense, I can't think of any other reason.
JohnnyMead
Eric,
I'm in a "while I'm there" mode too and am thinking about the motor mounts. What should I watch out for when jacking up the front of the engine? Anything need to be disconnected, rear trans mount loosened?
Thanks,
John
TR3driver
Great Pumpkin - R.I.P
In retrospect, I wish I had drained the cooling system and disconnected the upper radiator hose. It didn't break at the time, but was kind of strained by the time the engine was high enough to clear the stud on the mount, and it did fail a few days later.
ekamm
ekamm
I wish Randall would have said that some time ago as I snapped mine off just at the heater valve when I needed to rock the engine a bit to get out the passenger side mount. I cur off a 1/8 to a 1/4 inch of each of the bolts coming out of the mount. I had read that in a post from someone else. I had the engine jacked up all the way up and touching the accelerator linkage but the mounts were too tall and the bolts are considerably longer than they need to be. I also found lining up the hole in the mount with the frame a PITA but finally got the engine moved to the correct way and got them in. The motor is quite solid now and I'm glad that I did it.
B TR2/3/3A TR3 motor mount Triumph 9
PatGalvin TR2/3/3A TR3 Shifter and Motor Mount Support Ques... Triumph 7
J TR2/3/3A TR3 fan and motor mount R&R Triumph 4
R TR2/3/3A TR3 Wiper motor Triumph 10
Joel Lester TR2/3/3A TR3 Wiper motor wiring and testing Triumph 5
K TR2/3/3A TR4 motor with overdrive in a TR3 slave cylinder mounting position? Triumph 2
S TR2/3/3A When lifting the tr3 motor Triumph 10
NutmegCT TR2/3/3A TR3 - Motor Trend magazine, 1956 Triumph 2
S TR2/3/3A grease in tr3 D2 wiper motor Triumph 2
S TR2/3/3A color of tr3 D2 wiper motor Triumph 5
S TR2/3/3A Wiper motor brushes tr3 Triumph 2
S TR2/3/3A wiper motor tr3 Triumph 4
S TR2/3/3A new tr3 motor Triumph 7
T TR2/3/3A How do I remove fan on TR3 heater motor? Triumph 6
tinman58 TR2/3/3A How to break in a TR3 motor Triumph 7
mgedit TR2/3/3A Wiper Motor Bracket for 56 TR3 Triumph 9
C TR2/3/3A TR3 w/motor swap FS Triumph 14
K TR4/4A Putting aTR4 motor and trans in a TR3 Triumph 4
B TR2/3/3A tr3 or 4 motor? Triumph 16
mountainman TR2/3/3A TR3 Wiper Motor Triumph 4
mountainman TR2/3/3A TR3 Wipper Motor Wiring Triumph 4
P TR2/3/3A tr3 wiper motor mounting Triumph 7
mountainman TR2/3/3A TR3 Windsheild wiper Motor Question Triumph 4
Got_All_4 TR5/TR250 Switching a TR3 wiper motor over to a TR250 Triumph 4
Tinkerman TR2/3/3A Reasembly of Starter motor, TR3 Triumph 4
Moseso TR2/3/3A Deep in the TR3 motor Triumph 12
K TR2/3/3A Torqing the head again?....rebuilt motor... TR3 Triumph 4
M TR2/3/3A TR3 Wiper Motor Rebuild Triumph 8
martx-5 TR2/3/3A TR3 Wiper Motor Triumph 3
C TR2/3/3A Motor and Trans Out!!! TR3 shift lever??? Triumph 6
JPeter TR2/3/3A TR3 motor mounts Triumph 5
gsalt57tr3 TR2/3/3A TR3 Windsheild Wiper Motor Triumph 7
