TR2/3/3A TR3 Windsheild wiper Motor Question
mountainman
I have my windshield wiper motor on my bench and tried to run it with a battery charger and it will not run only hums. I have cleaned it up inside and out and lubricated everything. The battery charger is a 12 volt 10 amp charger. Should that run it.
Thanks
Greg
Geo Hahn
I would think yes.
You should have connected green wire (hot) a black wire (ground) and a green/black wire (the switched ground).
As for that red wire that goes to the wheel-house (for the park function) I think it can be ignored for this test though grounding it should cause the motor to run irrespective of the switch being on or off (wheel house provides a ground until the linkage is in the park position).
It is a bit confusing as there is both a real ground and a switched ground -- I think you need both for the dingus to run.
<span style="font-style: italic">Maybe a picture will help:</span>
TR3driver
Great Pumpkin - R.I.P
Nope, only take two wires to make it run. With the housing and ground terminals not connected to anything, just connect your battery charger between terminals 1 and 2. The "real" ground is only for the "park" function.
A "10 amp" charger should run it, although perhaps not at full speed. If you have it wired as I've suggested and it doesn't run, there is likely something wrong with the motor.
But don't forget that the park switch connects terminal 1 to the housing during part of the cycle.
MDCanaday
Just be thankfull you have a tr3,and not a tr2.My friend just spent 7 months getting his armature re-wound by some speciality electric place...at dreadfull expense.You cant find an original tr2 unit anywhere.(that works)
MD( mad dog)
TR3driver
OTOH, rewinding an armature yourself isn't all that difficult. Used to be taught in high school shop class "back when".
Did a TR3 heater motor myself once, trying to get more power out of it. Spun the fan noticeably faster, but turns out it didn't blow much more air.
gsalt57tr3 TR2/3/3A TR3 Windsheild Wiper Motor Triumph 7
mountainman TR2/3/3A TR3 Windsheild Frame Question Triumph 8
jfarris For Sale TR3 Stock Fan used (1956) Triumph Classifieds 0
jfarris For Sale TR3 Speedometer SOLD Triumph Classifieds 3
S TR2/3/3A My tr3 was stuck in reverse after a short drive Triumph 3
luke44 TR2/3/3A TR3 not engaging 2nd gear Triumph 24
R TR2/3/3A TR3 Wiper motor Triumph 10
H For Sale TR3 RHD tonneau cover nee Triumph Classifieds 0
J TR2/3/3A TR3 Soft top speed limit? Triumph 9
