TR2/3/3A Tr3 heater valve
ekamm
I broke the pipe coming out of the heater control valve when I changed motor mounts. It appeared to be 1/4"npt but I was having trouble finding some thing to temporarily fix it that would thread in. Is it british pipe thread? is there some thin that I could use to reconnect it temporarily until I am able to get the correct pipe?
TR3driver
Great Pumpkin - R.I.P
I would remove the valve from the head. The threads in the head are standard pipe threads (3/8 NPT IIRC) so you can install a pipe nipple, elbow and NPT-to-hose barb (all available at your local "home center") to temporarily connect the heater.
Or just install a pipe plug and plug the line to the heater with something, if you can get by without heat for now.
ekamm
ekamm
I did block the line but wanted to connect the heater and then next time I order something get the pipe. The 3/8 was too large the 1/4" was the correct size but I was having trouble getting the nipple to start. I'll take the valve out and see if the threads need to be chased with a tap. I was just wondering if the thread as unusual. When I removed the broken part there were only 2 threads or so in the valve, seems a little shallow even though the wall of the valve isn't very thick and the nipple can't block the valves operation.
Geo Hahn
As I recall that pipe into the valve has a very short threaded portion (as you discovered).
Here is a shot of my TR4 which has no heater. The 45 degree street ell (I think that is what the plumbers call it) and a plug are used in lieu of the valve. You should be able to rig up something similar to either plug it or add a barb where mine is plugged.
TomMull
Eric,
I have a spare clean head and can firm that 3/8 NPT goes right in. I might have a spare pipe too but will need time to dig.
Tom
ekamm
ekamm
The hole in the block is a 3/8 hole, but the outlet from the valve is 1/4". I'll get a chance tomorrow to get it functional again. I'm pretty sure that the threads may be a bit funky from the fitting being pulled on.
TR3driver
I'm almost certain that the threads from the valve for the side nipple are not standard NPT threads. Much finer pitch, and as I recall, straight not tapered. Also the valve body is rather thin for ordinary pipe threads. That is why I suggested removing the valve instead.
ekamm
ekamm
Got it I thought you had suggested taking it out to put a nipple into the valve. I'll likely just cap it off for now.
ekamm
ekamm
So I thought that I would update my post for the record. I took the nipple to my really good local too store and showed the broken piece to an old guy that seems to know everything. He immediately identified the tread as British Standard Pipe Thread. He walked me over by the tap and die section, reached up on the top of a shelf where a box of BSP tap and dies were located. I bought a 3" x 1/4" brass nipple, cut off one end and threaded the cut end to 1/4" x 19 BSP the other still being NPT. Screwed on a reducer that got me to 1/2" barb and that puppy works wonderfully.
P.S. I think that the fitting part of the valve that screws into the block is also BSP maybe 1/2".
jwolff
If I wanted to run without my heater and install a plug in place of my heater valve, what do I need to do to the other side near the distributor? Can I simply remove that pipe and install a plug there as well?
thanks
ekamm
ekamm
Yes I would assume that water will come from both sides as there is nothing to stop it.
TR3driver
Yup. If you remove the adapter that the pipe fastens to, the WP housing will take a pipe plug.
This was actually the standard configuration, the heater was optional. To be "correct", though, you need to remove the fittings at the firewall and replace them with blanking plates.
luke44 TR2/3/3A TR3 Brass Heater Valve to Head - How to treat threads, if at all? Triumph 6
toysrrus TR2/3/3A TR3 Heater Valve Question Triumph 5
mountainman TR2/3/3A Tr3 Heater Valve Triumph 3
Got_All_4 TR2/3/3A TR3 heater valve is leaking like a sieve Triumph 3
Scotsman TR2/3/3A Tr3 heater conversion Triumph 9
parkerg1 TR2/3/3A TR3 Heater Triumph 10
HighAltitudeTR3 Wanted Heater Core, Capping Trim, OD switch 1959 TR3 Triumph Classifieds 3
M TR2/3/3A TR3 Heater Triumph 34
M TR2/3/3A TR3 heater install picture needed Triumph 33
Lukens TR2/3/3A Would you sell your TR3 heater? Triumph 18
T TR2/3/3A How do I remove fan on TR3 heater motor? Triumph 6
Russ Austin TR2/3/3A Attempting to install a heater in my TR3 Triumph 39
M TR2/3/3A Heater removal in TR3 Triumph 13
H TR2/3/3A TR3 heater options Triumph 9
T TR2/3/3A TR3 heater pipe bracket Triumph 6
S TR2/3/3A Repairing a tr3 heater? Triumph 14
S TR2/3/3A tr3 heater Triumph 7
af3683 TR2/3/3A TR3 Heater Hoses Triumph 4
RedTR3 TR2/3/3A TR3 Heater Coolant Flow Direction Triumph 3
D TR2/3/3A TR3 heater reinstall problems Triumph 4
RedTR3 TR2/3/3A TR3 Heater Question Triumph 8
luke44 TR2/3/3A TR3 Smiths Heater Plate Triumph 3
S TR2/3/3A Tr3 heater wirer Triumph 8
M_Pied_Lourd TR2/3/3A TR3 Heater Finish Triumph 8
S TR2/3/3A heater attaching piece tr3 Triumph 4
newmexTR3 TR2/3/3A TR3 heater hose install Triumph 4
Tinkerman TR2/3/3A Unknown Part TR3? Heater Bracket? Triumph 5
newmexTR3 TR2/3/3A tr3 heater vacuum lock? Triumph 2
S TR2/3/3A TR3 pipe leaking [housing to heater] Triumph 3
Got_All_4 TR2/3/3A My TR3 heater fan switch is broken Triumph 8
T TR4/4A TR3 / TR4 heater question Triumph 2
M TR2/3/3A TR3 Heater Core PSI Triumph 3
Geo Hahn TR2/3/3A TR3 Heater Alternatives Triumph 11
J Spitfire Spitfire heater upgrade to TR3? Triumph 7
PeterK TR2/3/3A TR3 heater part Triumph 0
R TR2/3/3A TR3 Timminge Triumph 11
J For Sale Triumph TR2 TR3 rocker panels, right and left Triumph Classifieds 0
J For Sale Triumph TR2 TR3 Channel - Drip - Rear Edge Triumph Classifieds 0
J For Sale TR2 TR3 Tie Member Triumph Classifieds 0
S TR2/3/3A tr3 valve spring compressor Triumph 5
