TR2/3/3A TR3 Alternator Conversion
RedTR3
I am considering the conversion and would like any recommendations for the easiest, most foolproof kit on the market. Thanks, Tim
TFB
Tim,I havent ran my motor yet ,but my conversion is done and was pretty easy.
I used the Moss fan eliminator kit with thin belt.Didnt neeed to change 40A Kubota($69 ebay)alternator pulley.Some small mod to pedastal mount and it fit right in using stock adjsument arm.I had to cut away Rt. hand drive streering box mount. About $310 for everything,including new belt.
Tom
RedTR3
RedTR3
Hey, I just discovered that Triumph Rescue has a complete kit with alternator, pulley, belt, all hardware for $175....I think this may the the way to go. Looks pretty easy.
M_Pied_Lourd
Hi Red,
I got an alternator conversion kit and modified control box from Art Lipp. I haven't installed it yet but the instructions that were sent along with it look very straight forward. Looks like the only modification that needs to be done it a flattening of the old generator slide bracket and a little grinding of this bracket for clearance. He provides a template to do that as well.
AS an FYI, I am still using the wide belt and the new alternator has a pulley that works with this.
Cheers,
M. Pied Lourd
K TR2/3/3A TR3 with alternator conversion... red light stays on and low voltage on the voltmeter gauge? Triumph 1
TR3driver TR2/3/3A Mea Culpa - TR3 Alternator conversion Triumph 1
mgedit TR2/3/3A Alternator Conversion TR3 Triumph 7
T TR2/3/3A TR3 alternator conversion Triumph 19
B TR2/3/3A TR3 Denso alternator conversion question Triumph 2
bluemiata90 TR2/3/3A TR3 alternator conversion problems Triumph 5
gsalt57tr3 TR2/3/3A TR3 Alternator Conversion Triumph 3
D TR2/3/3A TR3 alternator conversion Triumph 1
mgedit TR2/3/3A Alternator Wiring for TR3 Triumph 18
H TR2/3/3A TR3- Who offers a good alternator kit + starter Triumph 28
T TR2/3/3A New TR3 alternator Triumph 19
H TR2/3/3A TR3 Nippondenso Alternator Triumph 24
martx-5 TR2/3/3A Delco Alternator on TR3 Triumph 7
J TR2/3/3A Alternator for TR3 Triumph 3
