TR2/3/3A TR-3A Trunk handle screw
Arrow
I am closing in on complete restoration. I have four trunks-hard to believe but all four are missing the screw that goes into the trunk handle square post inside the trunk. Anyone know what it is. Pan head? Flat head? Thread pitch? Any one have a picture? Thanks
TR3driver
Great Pumpkin - R.I.P
Believe it or not, there isn't one. The handle is designed to take a screw, but it isn't used in this application. The lock arm is held in place by a separate bracket and floats on the shaft from the handle.
Kleykamp
Far be it from me to question anything Randall says about TR3's. He's bailed me out more than a few times, but my '61 TR3 does have a screw in the shaft of the trunk handle. When I did teardown I took the two screws out of the bezel, pulled and pulled on the handle and finally saw the screw inside. The previous two cars I had owned did not have that screw. I will say however the screw head was painted body color and appeared to be original to the car, so I put it back in when I put the car back together. It is a #10 about 3/4" long, oval head. Sorry, but I don't know what thread...guessing 32 tpi. The only difference I can tell (in vs out) is the handle wobbles a little less in. I guess I'm "screwed" in concourse judging:friendly_wink:. I'd say 99.999% go with what Randall says. Without the screw, someone could remove the screws from the bezel, pull the handle out and open your "locked" trunk. Which is about the only real place to lock up valuables.
Kleykamp
Found a "known" 32 tpi screw. so the screw is Oval head,#10, 3/4", 32tpi. I tried it and it did fit. I'll leave it to you to decide if you get one or not.
TR3driver
That should be a tipoff right there. The factory obviously did not install the handle before painting the body! So someone has been there before you and not only changed things but tried to hide the changes.
martx-5
It might have "fit", but most likely it's a 2BA thread. A lot of the threads on the TR3 that are smaller then 1/4" are BA threads, especially body hardware. The 2BA is very similar in size to a 10-32, but the diameter is slightly different and it has 31.4 tpi. Also, the angle of the threads are different.
How far did you get the screw to go in? Usually a 10-32 will bind up within a 1/4" or so. Perhaps the PO re-tapped the thread.
See this link for info on BA threads...https://www.britishfasteners.com/threads/
Kleykamp
OK. It doesn't go there. Some prior owner was just sitting admiring his car one day and said " Everything is perfect on this car except it needs a screw in the truck handle." Will you at least give me?... "If it's not there you can take the two screws out of the handle bezel, pull the handle out and turn the whole thing and open the trunk." I can't test it because I don't have the key for the handle anyway. Upon a closer look, the paint is overspray from prior paint work. I trust what Randall says, but I've got the special limited edition trunk screw version....very rare and valuable. Humor injected for the overly serious reader.
Kleykamp
I wonder how many TR3 owner have checked their trunk for this "rare option" since reading these post. You can tell how busy I am...I took the screw out, ran a 10-32 nut all the way up the"original" screw and ran a 10-32 screw into the handle to its limit. I guess someone could have tapped it for a 10-32 but why tap for a screw that doesn't even belong there and isn't needed to start with . I'm going to keep mine in there as a conversation piece.
TR3driver
TexasKnucklehead
I doubt one philips head screw was original. Mine had none when i got it, but it didnt even have a trunk handle. Both 'original' trunk handles i got off ebay had the center screw. The latch is the same as one of the spare latches.
S TR2/3/3A T handle trunk lock Triumph 14
TRMark TR4/4A Trunk lid and handle assembly Triumph 7
B trunk lid T handle Spridgets 6
maxwedge5281 trunk hinge and handle gaskets Austin Healey 3
1 BJ8 Trunk Handle Austin Healey 0
TireKicker847 Wanted 07 Jaguar XK trunk covers Jaguar Classifieds 0
volunteer Wanted Need Door Seals, Vent Window Seals and Trunk Seal for Daimler ds420 Limo Jaguar Classifieds 23
Twit TR4/4A TR4 trunk badge Triumph 8
69MGC MGC Putting a 12v battery in the trunk MG 10
S For Sale TR3 front nose,trunk & petronix distributor Triumph Classifieds 0
6TTR3A TR6 TR6 Trunk lock set screws Triumph 2
S TR2/3/3A rubber seal go towards the inside of the trunk Triumph 3
A TR2/3/3A Brakes, exhaust and trunk floor Triumph 2
aero3113 100-4 trunk liner kit Austin Healey 4
D TR6 1976 TR6 Gas smell in Trunk Triumph 9
JimLaney Refurbishing the trunk lid Spridgets 2
R TR2/3/3A Trunk floor replacment Triumph 4
1 Wedge Breaking Into a Trunk Boot Triumph 3
R TR2/3/3A Boot/trunk floor Triumph 5
S TR2/3/3A tr3 trunk primer Triumph 2
H trunk floor pan replacement 1964 BJ8 Austin Healey 2
B Wanted I'm looking for a boot [trunk] lid and drivers rear fender for a 100/6 or 3000 Austin Healey Classifieds 0
S TR4/4A trunk seal question Triumph 10
C For Sale 67 BJ8 rear trunk luggage rack- Austin Healey Classifieds 0
T TR4/4A License plate on trunk lid Triumph 6
aero3113 Trunk Prop Stay Austin Healey 8
T TR2/3/3A Replacement Floor and Trunk Panel Quality Triumph 14
maxwedge5281 bn6 two seater trunk versus bt7 four seater trunk Austin Healey 27
MisterB And now.... the trunk Austin Healey 12
maxwedge5281 bn6 two seater trunk Austin Healey 16
bcbennett Wedge Bonnet and trunk prop rods Triumph 0
M TR2/3/3A Water in Trunk Triumph 10
69MGC MGC MGC Trunk Thingies? MG 5
Rob Glasgow Armacord Trunk Liner Austin Healey 8
S Trunk Lid Spridgets 26
T TR4/4A Trunk lid lettering - template wanted Triumph 0
Got_All_4 TR2/3/3A Fitting the trunk floor pad & fuel tank cover Triumph 2
maxwedge5281 bn6 armacord trunk liner kit Austin Healey 4
petnatcar Trunk modification for bt7 Austin Healey 15
magman BN-1 trunk latch adjustment Austin Healey 1
Scotsman TR4/4A TR4a trunk lid Triumph 2
Popeye TR4/4A Trunk [boot] lock removal Triumph 12
S TR4/4A door and trunk seals Triumph 3
B Gaskets for Trunk Lid Hinges Austin Healey 9
J TR4/4A Trunk Lid Seal Triumph 4
B Works Boot Rack [ For boot read trunk] Austin Healey 5
John Turney Trunk Lid Control Cable Austin Healey 2
M_Pied_Lourd TR2/3/3A 1960 Triumph TR3A Trunk Seal Orientation Triumph 6
M TR4/4A Trunk/Boot rubber seal. Triumph 8
M TR4/4A Position of wiring loom inside the trunk/boot area. ? Triumph 3
