TR 3/4 connecting rods
TRMark
Bronze
According to the service manual: Length (center to center) 6.248-6.252
What are you doing?
G
Greg_Blake
I am looking at replacing them wiht Chevy or Ford rods and I could not find that length listed anywhere. Where is it listed in the service manual?
Thanks,
Greg
PeterK
Joe A told me he was running a set from Jack as a test. Maybe Joe will pick it up and offer it as a package if it works well.
TRMark
Bronze
Thanks,
Greg
I misspoke a little. It is listed in my old workshop manual not a service manual. It is listed on page 1-104
71TR6 Set of 4 TR2/3/4 Connecting Rods Triumph Classifieds 0
R TR4/4A CP-Carrillo or Pauter Connecting Rods Triumph 2
Got_All_4 TR6 Ballancing the connecting rods and pistons. Am I lucky? Triumph 4
D Balancing Connecting Rods Triumph 17
C Connecting Rods and Cams Lotus 1
mjobrien Connecting Rods - Big end Dia Austin Healey 10
T TR6 tr6 connecting rods/motorcycle connecting rods Triumph 2
Popeye General TR Connecting to Lucas switch grub screws? Triumph 5
D Separating the piston from the connecting rod. Spridgets 9
KVH General Tech Connecting Rod Bearings Triumph 8
B For Sale Connecting Rod Bearings Austin Healey Classifieds 0
R Connecting Rod Big End Specification Austin Healey 4
BN6_2197 Removing connecting link between shock absorber and rear axle Austin Healey 4
M TR2/3/3A Connecting Rod Locking Tab Deformation Triumph 15
D connecting rod stamps Austin Healey 1
Csarneson Connecting Rod Bolt Question Austin Healey 3
H TR6 OEM Connecting Rod surprise Triumph 4
S T-Series connecting rod bolts MG 4
W connecting distributor wires Austin Healey 2
T TR2/3/3A ARP connecting rod bolts Triumph 2
B 1275 connecting rod nuts/bolts Spridgets 7
RedTR3 TR2/3/3A Connecting Rod Bolts Triumph 10
germanmichel BT7 shroud connecting at front frame rail plates Austin Healey 6
Sarastro T-Series TD connecting rod big end diameter MG 4
KLUTZ Easiest method for connecting Emerg. brake cable MG 5
J TR2/3/3A TR3 connecting rod bearing replacement Triumph 11
PatGalvin TR2/3/3A TR3 Connecting Rod Needed Triumph 10
J TR4/4A Tr 3a & TR4 - connecting rod bolt problems? Triumph 11
G MGB MGB Connecting pin MG 5
Basil Connecting Rod Bolts Triumph 12
KVH Wellseal and Connecting Rod Place Bolts Again Triumph 2
KVH Connecting Rod Bolts Triumph 11
G Can't remove the connecting rod bolts...HELP Triumph 6
J Connecting Rod Front and Back? Spridgets 7
2wrench Connecting rod bushing needs work Triumph 16
D connecting rod/piston compatibility Spridgets 2
drooartz Connecting ignition wires Spridgets 10
tr6web TR6 TR6 Wiper Motor Connecting Rod Triumph 2
Y Connecting rod Triumph 1
kodpkd Adjustable Tie Rods Austin Healey 20
6 Master Cylinder Actuator rods Spridgets 2
B RHD BJ8 Throttle Control Rods Austin Healey 9
B TR4/4A Outer tie rods Triumph 8
rr64 Wanted Early MGB Inner Steering Track Rods Wanted MG Classifieds 1
K TR2/3/3A New Tie rods and Ends Triumph 3
AH67AH Tie Rods / Alignment Austin Healey 3
I Wanted emergency brake rods from later Spridget Spridgets Classified 0
PAUL161 T-Series Bent Push Rods MG 34
S TR2/3/3A shifting tower shifting rods on an early tr3 tower Triumph 11
John Turney Alumifix Flux-cored Rods Restoration & Tools 4
