T-Series connecting rod bolts
saltiga
I read in the moss cat. that there is a set of improved big end bolts, is it common to have a big end bolt failure? any experience from t series owners would be appreciated. Saltiga
PAUL161
I sent you a PM. PJ
PAUL161
More important (or at least as important) is the gudgeon pin pinch bolt at the little end of the rod - they take a tremendous amount of strain and need to be a premium bolt. I believe that Tom Lang https://www.mgtrepair.net/index.html carries the correct bolts for that application.
Cheers,
I totally agree! Also two things to remember, torque up to but not over 25 foot pounds and while doing so, don't hold the rod by the big end, hold it by the pin, otherwise you might bend the rod, or so I've been told. PJ
T TR2/3/3A ARP connecting rod bolts Triumph 2
B 1275 connecting rod nuts/bolts Spridgets 7
RedTR3 TR2/3/3A Connecting Rod Bolts Triumph 10
Basil Connecting Rod Bolts Triumph 12
KVH Wellseal and Connecting Rod Place Bolts Again Triumph 2
KVH Connecting Rod Bolts Triumph 11
G Can't remove the connecting rod bolts...HELP Triumph 6
D Separating the piston from the connecting rod. Spridgets 9
KVH General Tech Connecting Rod Bearings Triumph 8
B For Sale Connecting Rod Bearings Austin Healey Classifieds 0
R Connecting Rod Big End Specification Austin Healey 4
M TR2/3/3A Connecting Rod Locking Tab Deformation Triumph 15
D connecting rod stamps Austin Healey 1
Csarneson Connecting Rod Bolt Question Austin Healey 3
H TR6 OEM Connecting Rod surprise Triumph 4
Sarastro T-Series TD connecting rod big end diameter MG 4
J TR2/3/3A TR3 connecting rod bearing replacement Triumph 11
PatGalvin TR2/3/3A TR3 Connecting Rod Needed Triumph 10
J TR4/4A Tr 3a & TR4 - connecting rod bolt problems? Triumph 11
J Connecting Rod Front and Back? Spridgets 7
2wrench Connecting rod bushing needs work Triumph 16
D connecting rod/piston compatibility Spridgets 2
tr6web TR6 TR6 Wiper Motor Connecting Rod Triumph 2
Y Connecting rod Triumph 1
Popeye General TR Connecting to Lucas switch grub screws? Triumph 5
71TR6 Set of 4 TR2/3/4 Connecting Rods Triumph Classifieds 0
R TR4/4A CP-Carrillo or Pauter Connecting Rods Triumph 2
BN6_2197 Removing connecting link between shock absorber and rear axle Austin Healey 4
Got_All_4 TR6 Ballancing the connecting rods and pistons. Am I lucky? Triumph 4
W connecting distributor wires Austin Healey 2
germanmichel BT7 shroud connecting at front frame rail plates Austin Healey 6
KLUTZ Easiest method for connecting Emerg. brake cable MG 5
G MGB MGB Connecting pin MG 5
D Balancing Connecting Rods Triumph 17
C Connecting Rods and Cams Lotus 1
mjobrien Connecting Rods - Big end Dia Austin Healey 10
G TR 3/4 connecting rods Triumph 6
drooartz Connecting ignition wires Spridgets 10
T TR6 tr6 connecting rods/motorcycle connecting rods Triumph 2
B Rod & Main Bearings Recommendations Austin Healey 10
W Correct Tie Rod Ends Spridgets 0
Popeye TR4/4A Slave rod seems too long but is not Triumph 7
H Wanted Need Spare tire rod BJ8 Austin Healey Classifieds 1
A MGB MGB 1974 windscreen centre rod replacement MG 5
S For Sale TR-3 Tie Rod Assembly for Sale Triumph Classifieds 0
DrEntropy Shift rod seal in an automatic? Jaguar 7
K TR2/3/3A Clutch and Brake Master Cylinder push rod stop bolts? Triumph 15
Healey Nut Cross Rod Correct Length Austin Healey 14
7 General TR Hot rod Triumph 0
Healey Nut BT7 Panhard Rod Austin Healey 28
