Rod & Main Bearings Recommendations
bigarestorations
After 2 1/2 year frame-off restoration on all but the engine, it's time! I have seen differences in brands of rod and main bearings discussed on the forums, but is there really one brand better than another? I would like to hear if someone, experienced with rebuilding, has an opinion. This is for a BJ8.
Thanks so much!
Bennet
red57
Regardless of what brand you use, I heartily recommend getting them coated before installing. Coated bearing shells will outlast anything (coated pistons are a good thing too).
These guys have been doing it for a long time and are highly regarded > Polymer Dynamics, Inc < . It's not very expensive when you consider the gains in lifespan.
dougie
Having built and ran multiple big Healey race engines for years, I'm not a fan of the King bearings available currently for our motors. I've sourced many correct NOS Vandervell bearings for my needs. The second best choice would be the AE made bearings. BoyRacer on this forum
(RIchard Mayer) had many sizes of rod and main bearings made for the big Healey 6, you can PM him for info.
B
bigarestorations
Thanks Bob!
Thanks for the info! Will reach out to him. Have a great week!
Bennet
B
bigarestorations
Thanks for getting in touch! At the machine shop now. Will know soon which ones I'll need. The crank is original stock, so it will most likely need to be turned... we'll see... I'll be in touch as soon as I hear from them.
Thanks!
Bennet
You'd be surprised; the original crankshaft for my 100/6 engine came back from the machinist std/std after just being polished. They're pretty tough. Although it's been AGES since I put the 3000 engine together that's currently in my car (since 1986) I believe that one came back std/.010.
I don't do batches of bearings as often as I used to, but I DO have some polymer-coated bearings already on hand. These were for personal stock, so if you're interested, once you know what size bearings you'll need, buy them from Richard (aka BoyrRacer) and if I have them, we can do an exchange + cost for the DFL (dry-film lubricant) coating.
Some examples...
Mostly Big Healey, including thrusts, and a single set of BMW S54 rod bearings (right above the "BU" & "RD" @ bottom-center)
Rod bearing comparison: BMW 3.2 Ltr/315hp @ 8000 rpm vs Austin 3.0/117hp @ 4800 rpm (IIRC?). Parasitic drag, much?
Pistons too!
B
bigarestorations
Some examples...
Pistons too!
Thanks Randy! Great info! Looking forward to getting all back from Mach shop... they're pretty backed up here so it might be a little while before they're done... I'll be in touch.
thx! Bennet
H Main and Rod Bearings Austin Healey 10
F Using 12 point ARP style rod and main bolts Spridgets 9
F Main / Rod bearing sizes. Spridgets 6
W Correct Tie Rod Ends Spridgets 0
D Separating the piston from the connecting rod. Spridgets 9
KVH General Tech Connecting Rod Bearings Triumph 8
Popeye TR4/4A Slave rod seems too long but is not Triumph 7
B For Sale Connecting Rod Bearings Austin Healey Classifieds 0
H Wanted Need Spare tire rod BJ8 Austin Healey Classifieds 1
A MGB MGB 1974 windscreen centre rod replacement MG 5
S For Sale TR-3 Tie Rod Assembly for Sale Triumph Classifieds 0
DrEntropy Shift rod seal in an automatic? Jaguar 7
K TR2/3/3A Clutch and Brake Master Cylinder push rod stop bolts? Triumph 15
Healey Nut Cross Rod Correct Length Austin Healey 14
7 General TR Hot rod Triumph 0
Healey Nut BT7 Panhard Rod Austin Healey 28
Walter74 Steering Rod Installation Austin Healey 6
red57 Rod Bearing Clearances Austin Healey 4
BoyRacer Odometer Reset Rod Austin Healey 4
K TR2/3/3A Removal of tie rod end? Triumph 7
TRopic6 For Sale Vandervell .010 Rod Bearings, MG TB, TC, TD, TF [Partial set] MG Classifieds 0
R TR2/3/3A Throttle rod spring location Triumph 3
I Brake rod questions Spridgets 7
Y MK V rod bearings Jaguar 1
Jim_Stevens TR2/3/3A Bonnet Stay rod safety latch differences Triumph 5
Phil73 TR6 VERY tight Tie Rod ends Triumph 1
K TR2/3/3A Isit possible to buy a single left hand thread tie rod end? Triumph 5
K TR2/3/3A Inner tie rod ball joint. Triumph 6
R Connecting Rod Big End Specification Austin Healey 4
John Turney The Panhard Rod is Supposed to be Straight, Right? Austin Healey 7
6 WTB +.040 piston with con rod for 2639cc Longbridge 100-6 Austin Healey 6
T TR6 Air vent rod connection Triumph 1
F TR2/3/3A Throttle linkage cross rod Triumph 4
K TR2/3/3A TR3 Tie Rod Sleeve Triumph 2
K Wanted TR3 Tie Rod Sleeve Triumph Classifieds 2
Rhodyspit75 Bugeye bonnet prop rod Spridgets 2
Michael Oritt Center rod, bracket and mirror info needed Spridgets 8
T Wanted WTB TR2/TR3 Hood/Bonnet Latch Assembly with Prop Rod Triumph Classifieds 0
M TR2/3/3A Connecting Rod Locking Tab Deformation Triumph 15
Talon TR2/3/3A Throttle rod link to carburetor; basic questions Triumph 4
Got_All_4 TR2/3/3A Inner tie rod ends Triumph 4
K TR2/3/3A SU horizontal carb linkage rod? Triumph 3
TAS525 TR2/3/3A Missing zerk from inner tie rod end Triumph 7
PeterK General TR Need a handbrake button and rod TR4a-TR6 Triumph 5
R Upgraded rod bolts for stock rods Austin Healey 1
D TR2/3/3A tie rod end Triumph 17
D TR2/3/3A 7.68, outer tie rod Triumph 4
D connecting rod stamps Austin Healey 1
Feathers 289I inner tie rod end. TVR 0
KVH General Tech Steel Wool on Rod Bearings Triumph 9
