Connecting Rod Bolt Question
Csarneson
I am a rookie rebuilder (though I will have some experienced help when I actually assemble) and just got my block back from the shop. I realized today that two of my rod bolts are missing the little locking pins that normally sit at 45 degrees. They must have broken off 40 years ago when the engine was disassembled. IMG_0330.jpgI hope that is visible. So 10 of my 12 bolts are fine. These suckers are speedy so I don't want to buy 12 if I don't have to. If I buy just 2 will I experience balance problems? Are those pins even necessary if a clamp could hold them tight when torquing? Suggestions? Anybody have a couple laying around that they'd sell for a reasonable price? Thanks in advance. You guys are invaluable.
Chris in WY
...will I experience balance problems? Are those pins even necessary if a clamp could hold them tight when torquing? Suggestions? Anybody have a couple laying around that they'd sell for a reasonable price? Thanks in advance. You guys are invaluable. Chris in WY
Were the rods balanced with the original bolts? If so, get 2 replacements and compare weights with the originals; chances are they'll be close enough to not matter or you could take a little metal off the heavier ones to maintain balance. If the rods weren't balanced to begin with it probably won't make much difference.
I don't know if the rods were even balanced--or balanced meticulously--at the factory. My builder had to take some metal off a couple of mine to get them balanced.
Deleted member 19315
I'd fit new ones throughout as a matter of course since you have no guarantee of previous use regarding load, or proper torque. Also rods are usually balanced end for end with a little rig that allows the mass of the big and little ends to be matched not just the overall mass. Usually the bolts are within a few micrograms of each other in mass if they come from the same supplier.
Andy
J TR4/4A Tr 3a & TR4 - connecting rod bolt problems? Triumph 11
D Separating the piston from the connecting rod. Spridgets 9
KVH General Tech Connecting Rod Bearings Triumph 8
B For Sale Connecting Rod Bearings Austin Healey Classifieds 0
R Connecting Rod Big End Specification Austin Healey 4
M TR2/3/3A Connecting Rod Locking Tab Deformation Triumph 15
D connecting rod stamps Austin Healey 1
H TR6 OEM Connecting Rod surprise Triumph 4
S T-Series connecting rod bolts MG 4
T TR2/3/3A ARP connecting rod bolts Triumph 2
B 1275 connecting rod nuts/bolts Spridgets 7
RedTR3 TR2/3/3A Connecting Rod Bolts Triumph 10
Sarastro T-Series TD connecting rod big end diameter MG 4
J TR2/3/3A TR3 connecting rod bearing replacement Triumph 11
PatGalvin TR2/3/3A TR3 Connecting Rod Needed Triumph 10
Basil Connecting Rod Bolts Triumph 12
KVH Wellseal and Connecting Rod Place Bolts Again Triumph 2
KVH Connecting Rod Bolts Triumph 11
G Can't remove the connecting rod bolts...HELP Triumph 6
J Connecting Rod Front and Back? Spridgets 7
2wrench Connecting rod bushing needs work Triumph 16
D connecting rod/piston compatibility Spridgets 2
tr6web TR6 TR6 Wiper Motor Connecting Rod Triumph 2
Y Connecting rod Triumph 1
Popeye General TR Connecting to Lucas switch grub screws? Triumph 5
71TR6 Set of 4 TR2/3/4 Connecting Rods Triumph Classifieds 0
R TR4/4A CP-Carrillo or Pauter Connecting Rods Triumph 2
BN6_2197 Removing connecting link between shock absorber and rear axle Austin Healey 4
Got_All_4 TR6 Ballancing the connecting rods and pistons. Am I lucky? Triumph 4
W connecting distributor wires Austin Healey 2
germanmichel BT7 shroud connecting at front frame rail plates Austin Healey 6
KLUTZ Easiest method for connecting Emerg. brake cable MG 5
G MGB MGB Connecting pin MG 5
D Balancing Connecting Rods Triumph 17
C Connecting Rods and Cams Lotus 1
mjobrien Connecting Rods - Big end Dia Austin Healey 10
G TR 3/4 connecting rods Triumph 6
drooartz Connecting ignition wires Spridgets 10
T TR6 tr6 connecting rods/motorcycle connecting rods Triumph 2
B Rod & Main Bearings Recommendations Austin Healey 10
W Correct Tie Rod Ends Spridgets 0
Popeye TR4/4A Slave rod seems too long but is not Triumph 7
H Wanted Need Spare tire rod BJ8 Austin Healey Classifieds 1
A MGB MGB 1974 windscreen centre rod replacement MG 5
S For Sale TR-3 Tie Rod Assembly for Sale Triumph Classifieds 0
DrEntropy Shift rod seal in an automatic? Jaguar 7
K TR2/3/3A Clutch and Brake Master Cylinder push rod stop bolts? Triumph 15
Healey Nut Cross Rod Correct Length Austin Healey 14
7 General TR Hot rod Triumph 0
Healey Nut BT7 Panhard Rod Austin Healey 28
