Master Cylinder Actuator rods
65_BRG_Sprite
I measured the length of the actuator rod adjustments when I took it all apart many years ago- I've lost those photos. Can these rods be set up to be too long? I can see a problem if they are shortened too much. The manual just says they are set at the factory.
Pythias
Yes they can be too long. IIRC, (I can't find it in the book) they should be set so the the pedal(s) move at least 9/16"? before starting to actuate either the brakes or the clutch. Otherwise you risk not having those things properly release. ..
There's a mention SOMEWHERE of how much free play there should be at the master cylinder when the pedals are "at rest" but I can't find it now... Someone will weigh in.
Pythias
I found a listing for the BRAKES... . Free Pedal movement 5/32" I assume the same for the clutch. .. Still looking.
I found this too..
2. Set the length of the push-rod to give a free movement of the pedal pad of approx. 5/32" (4mm) before the m/c piston begins to move. the push-rod must have a minimum of 1/32" (.8mm) free movement before the piston begins to move.
L Removing Master Cylinder Without Paint Damage Austin Healey 27
6 Master Cylinder Rebuild Spridgets 6
K New Clutch Master/Slave Cylinder Austin Healey 1
wkilleffer MGB 1974 MGB clutch master cylinder questions MG 1
Racer-X- Frame mounted power brake pedal/booster/master cylinder kits for RHD cars? Restoration & Tools 1
Got_All_4 TR6 Which Clutch Master Cylinder Fork is for TR6 Triumph 4
bighealeysource Master Cylinder Installation Austin Healey 9
bighealeysource BN2 Master Cylinder Austin Healey 91
prb51 100-6 Brake Master Cylinder Bore Austin Healey 5
bighealeysource Brake Master Cylinder Austin Healey 27
A Brake Master Cylinder Freeplay Austin Healey 11
SNClocks Master Cylinder Bore Diameter Spridgets 0
W replace rigid master cylinder lines with flex. Spridgets 2
6 Master Cylinder Install Spridgets 5
rgfrey Bench Bleeding Brake Master Cylinder Austin Healey 2
K TR2/3/3A Clutch and Brake Master Cylinder push rod stop bolts? Triumph 15
R TR6 Clutch Master Cylinder Hydraulic Line (Thread / Flare Type) Triumph 4
mctriumph master cylinder brake/clutch Tr3 Triumph Classifieds 9
R TR2/3/3A Master Cylinder Re-build Triumph 6
mrv8q TR2/3/3A Brake master cylinder: rebuild or replace? Triumph 9
D TR2/3/3A sealing master cylinder pocket Triumph 8
J For Sale Triumph TR 2/3 original brake/clutch master cylinder Triumph Classifieds 2
R TR4/4A Master Cylinder Corrosion Do I replace? Triumph 4
BobHaskell MGB 1980 MGB harness question - brake servo/master cylinder MG 1
R TR2/3/3A 1961 TR3A Master Cylinder[s] Rebuild Kits Triumph 4
R TR2/3/3A Lockeed Master Cylinder Adapters Triumph 8
D TR2/3/3A master cylinder res plumbing and unknown spacer Triumph 6
D Clutch Master Cylinder Leak Austin Healey 20
6 Master Cylinder Rebuild Help Please Spridgets 3
D BJ8 brake master cylinder question Austin Healey 6
Lin Master cylinder packing pieces [shims] Austin Healey 29
angelfj1 Wanted '59 TR3A Clutch Master Cylinder - USED, RE-BUILDABLE, NOS Triumph Classifieds 4
angelfj1 TR2/3/3A 59 TR3A Clutch Master Cylinder Failure Triumph 19
F Austin Healey Sprite MK I - master cylinder cap Austin Healey 1
D TR2/3/3A Brake Master Cylinder. Triumph 4
D 1965 Alpine Clutch Master Cylinder Sunbeam (Rootes) 0
Michael Oritt Brake Master Cylinder access Austin Healey 0
warwick-steve Final fix for clutch pipe to master cylinder leak?? Austin Healey 13
KVH TR4/4A Clutch Master Cylinder Triumph 3
warwick-steve Clutch master cylinder to fluid reservoir leak Austin Healey 5
R 3/4" Bore or 7/8" Bore Master Cylinder For Disc Brakes? Spridgets 4
bugedd Master Cylinder Question Spridgets 7
S Smitty trans Master cylinder Austin Healey 21
Rob Glasgow Clutch Master Cylinder Issue Austin Healey 3
glemon General Tech Follow up on Master Cylinder and Brake Fluid Triumph 11
nevets Master Cylinder question Austin Healey 8
JimLaney Sprite MK III combined master cylinder issue Spridgets 10
Got_All_4 TR2/3/3A Clutch issue maybe master cylinder Triumph 13
S MGB MGB clutch master cylinder MG 0
