TR2/3/3A Timing Chain Tensioner - 1959 TR3
mt10flyer
Not again. There is that rattling inside the timing chain cover and I know what it is. The tensioner is broken...again. Third time. What the heck. Anyone have a solution. This time, after I remove the bumper, front apron, radiator, fan and all the other little crap, should I just leave it off? What is everyone else doing about this poorly designed and flimsy part?
NutmegCT
If you've verified all is installed correctly, I think the first step is for you to contact the supplier (again?) and report the problem.
What did they say the first time this happened with the part they supplied?
Tom
Geo Hahn
I agree -- a chat with the vendor is in order as I cannot see any good reason why a correctly installed tensioner on a decent chain should fail prematurely.
I installed one from Moss about 2 years ago and certainly expect it to 'see me out'.
Was the prior failure just the classic break at the bend?
mrv8q
Ooh, great pic! I'm going to follow this thread, as this is some PM I need to take care of, sooner than later...
mt10flyer
mt10flyer
Purchased from Moss, but probably made somewhere west of Japan. It is just like the pic above. Breaks at the bend and then rattles around. One time the chain drove it through the cover...found a "new" one on Ebay.
This time it is approx 500 miles after complete engine rebuild. It would be foolish to follow the same path of replacement since that path has not led to success.
NutmegCT
I'd think Moss would make good on that failure. Let us know what they say when you contact them.
Thanks.
Tom
mt10flyer
mt10flyer
The part is only $7.95 so that isn't very important. The hassle is what has to be removed to replace it...and then no guarantee the part will last any better than the first three. Am I the only one seeing this part fail on a regular basis?
NutmegCT
You're right. $7.95 isn't that big a deal. But the reliability of the part *is* a big deal. Please let us know what Moss says when you tell them about the problems you've experienced.
Thanks.
Tom
TR3driver
Great Pumpkin - R.I.P
TS15372L is still (AFAIK) wearing it's original factory tensioner.
The engine in TS39781LO (which originally came from an earlier TR3 in the TS11xxx range) did break it's original tensioner with an estimated 200,000 miles on it ... the replacement from TRF was still working fine when the car got wrecked some 50,000 miles later.
So IMO not a poorly designed part; just that the replacements are not properly made. Where have I heard that before? My advice would be to buy one from TRF this time. They're even on sale at the moment.
midnight
Hi - I am in Reno - just finished a four year body-off restoration on a 59 tr-3a - I looked forever for a tr-3 owner in reno - never found one - good luck - miles
mt10flyer
mt10flyer
Hi Miles. You'll see me around. Red daily drive in pretty good shape. Is yours green. I saw it once coming down Mt. Rose highway.
Thanks Randall. Will try TRF part this time.
sp53
I suggest that when you get it apart to look at the pin that holds thetensioner and make sure it is true and to also look and see if the bear plateis flat. I filled the last bear plate with weld and ground it flat where the tensionerhad cut a ditch because I felt the ditch was causing things to bind , but I guessyou can also purchase a plate new.
mt10flyer
mt10flyer
Good idea on the plate. I'd have to pull the engine to do that if it is the case, however. I think I would have noticed if was not flat, but maybe not. The pin is new (I've replaced it each time as well).
One thing I note is that running without the tensioner, is no reduction in performance. I suspect maximum a couple of degrees of timing off during deceleration and I don't notice that. I suppose the purpose of the tensioner is to keep the chain and cogs from wearing when power load is removed and/or applied. Frankly, with what I have been having to do I am tempted to run without the tensioner and pay the piper later with new gears and chain. Does this sound insane?
DornTRoriginal
Oh my.... So sad! I replaced my perfectly functioning chain tensioner during my recent rebuild thinking the years of wear would eventually catch up, I would be devastated if this happens to the new one. I hope this is an isolated issue and I encourage anyone knowing that this is a reoccurring problem will let everyone know. The manufacture, suppliers and the consumers would benefit from the information. Thanks!
mt10flyer
mt10flyer
Heh. I've killed many a kitten.
Here is my experiment. I ordered tensioners from Moss and TRF. I will let you know if there is a detectable difference in the quality and/or supplier. If they are the same, I will run naked without the tensioner. If TRF's looks better, I'll give it a shot. For obvious reasons I won't run the Moss one (though many other transactions with them have been more than satisfactory - I have no axe to grind).
I will also report with links to pics if anything of importance is visually apparent.
CJD
Tempting, but I wouldn't do it. A new chain is very snug, but over the miles it slowly stretches from pin wear and metal creep. The result is that eventually the chain will start rubbing through the cover. Now, it'll work to run without if you plan to change the chain every 10-15k miles. I guess that's a lot less frequently than you're doing now, though!?!
mt10flyer
mt10flyer
Rubbing through the cover. Dang. I hadn't thought of that. When I have it apart I'll look at that possibility. That would be no good since covers are hard to find. I'll post here results.
TR3driver
I've seen chain drives run at speed without a snubber. There is always at least one rpm where the slack part of the chain starts to whip around wildly. That can't be good for long life of either the chain or the components it is attached to.
Got_All_4 TR5/TR250 Timing chain tensioner completely shot Triumph 11
mt10flyer TR2/3/3A Timing Chain Tensioner - again Triumph 13
D TR2/3/3A Timing chain tensioner. Triumph 3
Michael Oritt Replacing timing chain tensioner and more Austin Healey 24
B Timing chain tensioner help Austin Healey 15
K TR2/3/3A TR3 Oil Pressure Timing Chain Tensioner? Triumph 0
Darrell_Walker Timing chain tensioner wear Triumph 8
eschneider TR2/3/3A TR2/3/4 timing chain tensioner Triumph 4
H 100 Engine Timing Chain Tensioner Austin Healey 3
John Loftus Timing chain tensioner question Austin Healey 14
P Newbie Missing or Broken Timing Chain Tensioner? Triumph 11
michalotti_tr TRactor motor timing chain tensioner Triumph 7
A Timing chain tensioner---old or new?? Triumph 4
Y Timing chain tensioner spring Triumph 2
K TR2/3/3A How to tell if the timing chain has slipped...... Triumph 12
K TR2/3/3A Timing chain rattle on start up? Triumph 2
LAW75 Timing Chain Cover Gasket Austin Healey 12
J Crankshaft dog nut and timing chain cover removal advice Austin Healey 30
doc50 Metro 1500 Has Slack Timing Chain? Other British Cars 20
Got_All_4 TR6 Timing chain Triumph 10
Got_All_4 TR6 Double row timing chain in a 69? Triumph 2
DornTRoriginal TR2/3/3A Checking if Timing Chain is Installed Correctly Triumph 6
D BT7 Timing chain install Austin Healey 2
M Timing Chain on 948 Rebuild Spridgets 1
R General Tech Timing chain replacement Triumph 5
RJS TR4/4A Timing Chain Oil Seal Triumph 6
B TR2/3/3A Timing chain cover goop location Triumph 4
G Timing Chain - Slackend Austin Healey 5
T TR2/3/3A Is there any reason there is a stud bolt at top of timing chain cover? Triumph 7
GTP1960 TR2/3/3A Cleaning/degreasing timing chain Triumph 11
S TR2/3/3A timing chain cover and woodruff key Triumph 4
G TR4/4A timing chain and sprockets Triumph 9
DanLewis Looking for a good timing chain cover Spridgets 1
B Timing Chain Tension Ring for BN2 Austin Healey 5
J TR2/3/3A Timing chain pin Triumph 1
L 100 timing chain worn? Austin Healey 7
DornTRoriginal TR2/3/3A Timing Chain Installation Procedures [TR3 engine TS 36161E] Triumph 5
T Timing Chain Wear? Austin Healey 5
J TR2/3/3A TR3A Timing Chain Seal and Gasket Replacement Triumph 7
RJS Timing chain oil seal Triumph 12
K TR2/3/3A Timing Chain Cover Crack TR3...#%€£¥^% Triumph 10
K TR2/3/3A TR3 Timing chain cover scroll seal...... Triumph 5
Geo Hahn Timing Chain Noise Triumph 25
kyreb1862 Is It Best to Go With A double Row Timing Chain? MG 1
K TR2/3/3A Tr3:installing a speedi sleeve timing chain cover? Triumph 4
TulsaFred Timing chain Spridgets 22
6 timing chain sprocket Triumph 5
6 timing chain cover Triumph 4
bugedd Anyone have a timing chain cover? Spridgets 10
rikiwho123 timing chain to gear drive? Triumph 4
