TR6 The yellow TR6 fan on a TR3?
karls59tr
Bronze
Anybody done this? I've heard that it can be installed backwards to allow for clearance and the blade tilt dosn't affect quantity of air moved that much. I've also heard that the fan can be installed the right way round if the rad is moved forward slightly. Anyone done this?
mrv8q
Karl, I've put the TRF yellow fan on my '59, "backward", and it seems to work fine. I've had no issues on overheating on my otherwise bone stock system, even on 100º days. I did use the TRF mounting kit, as well. From what I remember, the fan won't fit the other way, it's too close to the cross-brace.
Hope that helps!
jessebogan
I have done it to a couple of TR3s also. One has been on for over 20 years, and still runs OK. It is a good mod.
Bob_Muzio
Karl, a friend with a TR3A move the radiator forward 1 inch during restoration and the fan cleared. I've also heard that it is affective if mounted backwards.
MGTF1250Dave
Aloha Ed,
I have removed the stock fan from under neath the car, but it is a difficult. As I recall there is only enough room to use an open end wrench and you have to loosen all the bolts, slide the fan forward to clear the crank bolt, then drop the fan down and out. I don't think you could mount the "yellow" fan with out removing the cowl and radiator. You will need a socket to tighten the mounting bolts. I don't see how you could do that unless your radiator has the crank hole in it. Even then it still might not give you access to the mounting bolt heads.
K
karls59tr
Bronze
When the yellow fan is mounted backwards is it necessary to use the balance piece and locking plate assembly or leave it out? Someone posted on another site that they installed two washers under each of the four fan bolts (inbetween the hub extension and the fan)to bring the fan closer to the rad.Im thinking there wouldnt be much threaded bolt left to go into the hub extension if doing this. What have others done to fasten the the yellow fan to the extension hub.....just use the four bolts with lock washers?
mrv8q
Hello, Karl don't know if this pic will help you; here's what I did a year and a half ago:
I used the standard TRF yellow fan mounting kit..... at the same time, I changed the motor mounts; didn't make much difference....
TRclassic3
Aloha back at ya Dave,
Thanks for the reply...confirmed what I figured would be the situation. Hopefully I can get through this season without having to take action and then pull everything apart next winter. I have a back up radiator that I will have recored and change that at the same time. Also rebuild the leaky steering box. Now isn't that all something to look forward to.
My apologies to karls59TR. Didn't mean to infringe on your post.
wifegonnakillme
Hey Ed,
I have another string on the rad fan - if you are worried about overheating, you can slip in an aux pusher fan cheaply and easily by just removing the front grill.
I put a 12" in last weekend - works great. I used the plastic mounting hardware that comes with it. Others have suggested it is better to use a welded connection - I may switch should the plastic mount fail - but they seemed pretty sturdy to me and will certainly outlast my older radiator,
Cheers,
Kerry
Banjo
I'm glad this thread is here. I'm probably gonna do this mod when I get to it on the TR2 rebuild. My main reason is that I worry about the integrity of the old metal fan. I've seen enough pics, and heard enough stories about metal blades flying throught the bonnett, that I worry about that on my car. really, really hot days don't last around here. And TRs tend to hold thier own, but improving the cooling system would just mean I could push it a bit further. hehehehe.
jfarris For Sale TR6 Yellow Fan - new Triumph Classifieds 0
AN5Sprite Yellow TR6 on Turnpike Spotted 0
wangdango TR6 TR6 paint/azteck yellow Triumph 2
dwpirkeyjr Red? Bue? Purple? Yellow? Poly Bushings Complete Set For 1979 MG midget 1500 Spridgets 6
K TR6 Need help with Mimosa Yellow Paint Triumph 1
1 For Sale 1980 Yellow MG MGB MG Classifieds 2
W New Yellow Bugeye Spridgets 12
Zitch For Sale 8 Blade yellow Fan for triumph Triumph Classifieds 2
K TR2/3/3A Yellow wire uprated condensor Triumph 1
D TR2/3/3A Have I mounted my Yellow fan backwards? Triumph 10
Jim_Gruber Yellow BE on BAT Spridgets 0
jfarris For Sale New 8-Blade Yellow Fan and Mounting Kit Triumph Classifieds 0
2billydavies TR4/4A yellow blinker light stays on all the time the shuts off when blinkers are used Triumph 2
N TR4/4A yellow fan Triumph 5
DerekJ Primrose Yellow / Black with yellow upholstery Austin Healey 18
F Source for Touch Up Paint for Primrose Yellow? Triumph 3
Mickey Richaud Yellow Alpine Spotted 2
T TR2/3/3A Wisconsin Yellow TR3 Triumph 0
S Lemon yellow early Sprite Spotted 0
aeronca65t Yellow Sprite Spotted 0
tahoe healey Yellow bulbs Austin Healey 17
longbridgehealey Leaf green? Primrose yellow??? Spridgets 22
JamesWilson Yellow Turner Usk A472, Lotus Elite M5, & more.... Spotted 1
M Prim Rose Yellow Spridgets 14
DNK Yellow 6 Spotted 0
KVH TR4/4A The Yellow Fan on a TR4 Triumph 4
ekamm Primrose yellow? Triumph 28
apbos Silver or Yellow Wheels Triumph 10
T here comes a can-o-worms: yellow fog lights Triumph 19
W Yet another yellow steering arm Spridgets 1
S TR2/3/3A tr3 yellow fan Triumph 4
RickB uh-oh... what's it mean when the yellow idiot,,, Spridgets 18
tahoe healey red paint/yellow paint Austin Healey 2
angelfj1 Wedge Awesome Yellow Wedge Beasty - Mere, Wilts UK Triumph 1
T yellow dash light Triumph 3
ronzet California Year Of Manufacture Law Yellow/Black MG 1
T TR4/4A 4A Yellow Blade Triumph 14
Michael Oritt Double yellow? Racing 10
B Nothing mellow about this yellow Austin Healey 1
Webb Yellow Headlamps? Triumph 14
PeterK TR2/3/3A TR3 Yellow fan Triumph 1
regularman The little'un is now a funny color of yellow Spridgets 32
SCguy TR4/4A Yellow plastic fan in early TR4? Triumph 8
MadRiver Has anyone made their own yellow-striped hoses? Triumph 3
D TR4/4A TR4 Fan [Yellow Plastic] on a TR3? Triumph 8
lawguy The car's yellow, I'm green MG 7
L What color yellow for fan? MG 6
Stinky Red Fan vs. Yellow Fan Triumph 28
R Red and Yellow lites Triumph 7
Simon TR4a Wedge Yellow TR7 coupe for sale at dealer. Triumph 3
