yellow dash light
tad
The yellow dash light stays on all the time. I do show a charge however. What do I need to do to correct the light issue? It's a 1959 TR3.
Thanks
PeterK
The yellow dash light is the turn signal indicator. The red light is indicates charging.
Check your bulbs, flasher connections and grounds.
TR3driver
Great Pumpkin - R.I.P
Was the flasher unit changed just before the problem showed up ?
Might be it's an incorrect unit, as I've occasionally found the wrong one listed for a TR2-4 and the light staying on is one of the symptoms of the wrong unit.
Adrio
The yellow one is the flasher, but to make sure they were not hooked up wrong (as in reversed), confirm the red one turns on when the ignition key is in the on position but the engine is not started. Conversely, confirm that the red one does not flash when you use the turn signals. If the red one flashed when you use the turn signals then you need to reverse the two then figure out why your ignition light is staying on, and it is probably, either a very loose fan belt, a poorly set voltage regulator, or a defective generator.
dwpirkeyjr Red? Bue? Purple? Yellow? Poly Bushings Complete Set For 1979 MG midget 1500 Spridgets 6
jfarris For Sale TR6 Yellow Fan - new Triumph Classifieds 0
K TR6 Need help with Mimosa Yellow Paint Triumph 1
1 For Sale 1980 Yellow MG MGB MG Classifieds 2
W New Yellow Bugeye Spridgets 12
Zitch For Sale 8 Blade yellow Fan for triumph Triumph Classifieds 2
K TR2/3/3A Yellow wire uprated condensor Triumph 1
D TR2/3/3A Have I mounted my Yellow fan backwards? Triumph 10
Jim_Gruber Yellow BE on BAT Spridgets 0
jfarris For Sale New 8-Blade Yellow Fan and Mounting Kit Triumph Classifieds 0
2billydavies TR4/4A yellow blinker light stays on all the time the shuts off when blinkers are used Triumph 2
N TR4/4A yellow fan Triumph 5
AN5Sprite Yellow TR6 on Turnpike Spotted 0
DerekJ Primrose Yellow / Black with yellow upholstery Austin Healey 18
F Source for Touch Up Paint for Primrose Yellow? Triumph 3
Mickey Richaud Yellow Alpine Spotted 2
T TR2/3/3A Wisconsin Yellow TR3 Triumph 0
S Lemon yellow early Sprite Spotted 0
aeronca65t Yellow Sprite Spotted 0
tahoe healey Yellow bulbs Austin Healey 17
longbridgehealey Leaf green? Primrose yellow??? Spridgets 22
JamesWilson Yellow Turner Usk A472, Lotus Elite M5, & more.... Spotted 1
M Prim Rose Yellow Spridgets 14
DNK Yellow 6 Spotted 0
KVH TR4/4A The Yellow Fan on a TR4 Triumph 4
ekamm Primrose yellow? Triumph 28
apbos Silver or Yellow Wheels Triumph 10
wangdango TR6 TR6 paint/azteck yellow Triumph 2
T here comes a can-o-worms: yellow fog lights Triumph 19
W Yet another yellow steering arm Spridgets 1
S TR2/3/3A tr3 yellow fan Triumph 4
RickB uh-oh... what's it mean when the yellow idiot,,, Spridgets 18
tahoe healey red paint/yellow paint Austin Healey 2
angelfj1 Wedge Awesome Yellow Wedge Beasty - Mere, Wilts UK Triumph 1
ronzet California Year Of Manufacture Law Yellow/Black MG 1
T TR4/4A 4A Yellow Blade Triumph 14
Michael Oritt Double yellow? Racing 10
B Nothing mellow about this yellow Austin Healey 1
Webb Yellow Headlamps? Triumph 14
PeterK TR2/3/3A TR3 Yellow fan Triumph 1
K TR6 The yellow TR6 fan on a TR3? Triumph 11
regularman The little'un is now a funny color of yellow Spridgets 32
SCguy TR4/4A Yellow plastic fan in early TR4? Triumph 8
MadRiver Has anyone made their own yellow-striped hoses? Triumph 3
D TR4/4A TR4 Fan [Yellow Plastic] on a TR3? Triumph 8
lawguy The car's yellow, I'm green MG 7
L What color yellow for fan? MG 6
Stinky Red Fan vs. Yellow Fan Triumph 28
R Red and Yellow lites Triumph 7
Simon TR4a Wedge Yellow TR7 coupe for sale at dealer. Triumph 3
