TR4/4A Tachometer
shoopal
I have an RN1517/00 tach and it's making a rubbing noise between the magnet and the little cylinder attached to the needle. I guess that there is a bushing or whatever is in there that is worn. On ebay there is listed a 1319/02 for sale $30 including shipping but the chrome bezel is different.
Does anyone know if I can cannibalize the guts from the 1317 and repair mine?
Thanks
Al
HerronScott
Hi Al,
Are those typos on the part numbers? I've got the following listed as tachometers for TR4 and TR4A's
RN 1409/02 - Early TR4's with convex glass - TR4 RHD to CT15053, TR4 LHD to CT11307
RN 1417/00
They don't seem to match the TR2-3A part numbers either.
RC163
RN 1402/09
RN 1411/00
Scott
TRopic6
Aloha Al,
I found the ad and 1319/02 is for a Spitfire. While there are probably some common parts, the ratio is 3.55-1, same as a TR6. The ratio for TR 3/4 tachs are 2-1 and I don't know how they attain that (weaker magnet?). Maybe the magnetic bar is running too close or at an angle to the alloy cup. Anyway, try to get a spare TR4 tach and take yours apart. Anthony Rhodes has a PDF on "Repairing Jaeger & Smiths Speedometers"; Google that and you'll see how it works. At least tachs are simpler!
Happy Fourth - Jeff
ed_h
If the tach is similar to a TR6 unit, there would have to be something broken or bent inside for the magnet to scrape the eddy wheel. I don't think a worn bush by itself would cause this. Here is some info and a lot of pics of the inside of a TR6 tach and speedo.
https://bullfire.net/TR6/TR6-40/TR6-40.html
Ed
S
shoopal
Hi and aloha to all and thanks for your replies.
My tach is 1417/00 from a 65 TR4a CT61301. Anyway, I took it apart and the grease seemed pretty dry. Not surprising for a 60 year old car.
I will try to reassemble with white lithium grease when the auto supply stores open after the 4th. The bullfire link was really interesting but seems to be an incredible amount of work given that Nisonger will rebuild it (I haven't checked the cost yet but I would guess around $200)
I'll post further info
Al
CJD
I am sure cleaning it is all you need. The aluminum drum is very fragile, so a slight bend is all it takes to keep it from rubbing the magnet spinner. The speedo is complicated, but there are only 2 moving parts in the tach...so $200 for just a quick clean and lube sounds pretty pricey to me!
At most it's an hour long job. The bearings dry out and make noise or cause a pulsing indication, but I have never seen bearings worn out. I'm sure it's possible, but usually the mechanism locks up and frays the cable long before the bearing goes.
B tachometer cable has a hole in it Restoration & Tools 7
F TR6 Tachometer lighting Triumph 8
S Engine or Tachometer Odd Problem Austin Healey 7
M Tachometer not working following ignition upgrade Austin Healey 10
Magyar Rebuild Speedometer & Tachometer - mechanical or electronic? Spridgets 17
S For Sale Early Sprite & Midget Speedometer/Tachometer/Generator etc. Spridgets Classified 2
E Oil leaking from the Tachometer cable Austin Healey 5
E MGB Tachometer 65 mgb MG 5
vette Just a note to Bill Young about his work with the electronic tachometer. Austin Healey 2
RAC68 Calibrate Smiths Tachometer Austin Healey 12
B For Sale MGA JAeger Fuel Gauge, Dual Safety Gauge, Speedometer and Tachometer MG Classifieds 0
B For Sale Austin Healey 100 Smiths Fuel Gauge, Dual Safety Gauge, Speedometer and Tachometer Austin Healey Classifieds 0
B For Sale Triumph Tr3 Fuel gauge Temp gauge Oil pressure gauge, speedometer tachometer Triumph Classifieds 0
T TR2/3/3A Noisy tachometer Triumph 9
S Intermittent operation of tachometer Austin Healey 9
Lin Tachometer/Dwell Meter Austin Healey 10
N Tachometer?? Spridgets 6
1 MGB Speedometer and tachometer on '66 MGB are not working MG 8
W Tachometer reads high when engine compartment heats up Austin Healey 3
D TR2/3/3A curious tachometer take-off Triumph 5
NutmegCT T-Series Tachometer repair MG 15
Boink Tachometer seize? Spridgets 11
Michael Oritt Electric tachometer connections--No Healey content Austin Healey 7
M TR2/3/3A Tachometer Malfunction Triumph 7
drooartz Geeking out over a tachometer Spridgets 15
C tachometer for XJ6 Jaguar 0
GTP1960 TR2/3/3A Tachometer vs rpm analyzer? Triumph 5
Roger Lotus Elan S3 - Rev Counter [Tachometer] needed Lotus 4
5 Lazy Tachometer Spridgets 14
P I need a non-working electric tachometer for parts Spridgets 0
DanLewis Electronic tachometer for Bugeye Spridgets 18
J Mechanical tachometer to electric Austin Healey 11
J WTB: Bugeye Tachometer Blanking Plate Spridgets 11
B Smiths RVI Positive Ground Tachometer Bench Test ? Austin Healey 24
T BJ8 Tachometer and Fuel gauge stopped working. Austin Healey 27
Marvin Gruber Tachometer reading too high Jaguar 4
A Need Help with a Tachometer -- the drive portion. Austin Healey 1
M Quick tachometer wiring question on a '65 Spridgets 10
D Tachometer Triumph 9
L BJ8 Tachometer problem Austin Healey 6
P Tachometer versus lights Austin Healey 5
apbos Tachometer ID Smith's Rn1412/00 Spridgets 5
pkmh BJ8 Tachometer, "sparking" Austin Healey 35
G T-Series Tachometer and ignition switch MG 16
I Reproduction tachometer drive quality? Spridgets 4
K TR2/3/3A TR3 Dist Pedastal Tachometer Attachment? Triumph 3
K tachometer question Spridgets 9
B MGB MGB tachometer erratic, engine cutting out.... MG 11
F Ignition System/Electric Tachometer Triumph 9
F Spitfire Spitfire Electric Tachometer Problems Triumph 5
