TR2/3/3A Tachometer Malfunction
mxp01
All:
Over the weekend i replaced the oil pan and differential gaskets. Everything went well and i didn't disconnect anything. Oddly, when I started the car up today the tachometer spun all the way over and is now buried at the max range (by a zero).
I have a TR3B. The tach is cable driven. I disconnected it and re-connected it. Everything looks ok, but it still reads way too high.
Can someone explain what is happening?
Thanks,
Mike
Geo Hahn
Does the needle return to zero when the engine stops?
If not (and I expect not) then it is likely the hairspring is broken or detached.
Here is a good site for speedometer repair (note that the tach is essentially a speedometer w/o the two odometers):
https://triumph.daveola.com/NOTES/Speedo_Repair.pdf
That will get you a sense of what is inside - but I have never dealt with a broken spring.
If the needle does return to zero when the engine stops then it sounds like the magnet bar may be fouling on the drag cup.
CJD
I can't think of any correlation of the oil pan to the tach issue. It has to be a coincidence. As Randall says, check to make sure the cable is not forced too far into the tach. That can push up on the rotor magnet and cause mechanical contact between the rotor and the aluminum follower disc. If you removed the tach cable during your work, it's also possible to install it backwards and cause the same problem.
Aside from that the tach will have to come apart to fix anything else that could be wrong.
M
mxp01
John:
I didn't touch the tach cable at all during the work, so yes this must be a coincidence. Is it possible to pull the cable end out slightly at the end (by the engine) to counteract any possibility the cable has been pushed too far into the tach?
Geo Hahn
...Is it possible to pull the cable end out slightly at the end (by the engine) to counteract any possibility the cable has been pushed too far into the tach?
I think if you look at the speedo end of the cable you'll see that the solution (if a too-long cable is the problem) has to be there as there is a fitting that locates the cable against the speedo input connection.
I had a cable that would do this and as a stop gap I added a washer over the speedo end of the cable to act as a spacer and relieve the pressure of the too-long tip.
As I recall I had to start with a washer of a suitable ID and grind down the OD so it would fit inside the ferrule.
CJD
One end of the cable has a locating ring on it that looks something like an attached washer. What commonly happens is a tinkerer replaces the cable with the locating ring at the wrong end.
The quickest check of a too long cable end would be to loosen the cable sheath nut on the back of the tack and pull the sheath out of the tach 1/8" or so. Then try checking the tach operation with the loose cable. If it fixes it, then you know you are on the right track. The fix would be to try reversing the orientation of the cable, grinding just a tad off the tach end tip, or adding washers as Geo mentions.
B tachometer cable has a hole in it Restoration & Tools 7
F TR6 Tachometer lighting Triumph 8
S Engine or Tachometer Odd Problem Austin Healey 7
M Tachometer not working following ignition upgrade Austin Healey 10
Magyar Rebuild Speedometer & Tachometer - mechanical or electronic? Spridgets 17
S For Sale Early Sprite & Midget Speedometer/Tachometer/Generator etc. Spridgets Classified 2
E Oil leaking from the Tachometer cable Austin Healey 5
E MGB Tachometer 65 mgb MG 5
vette Just a note to Bill Young about his work with the electronic tachometer. Austin Healey 2
RAC68 Calibrate Smiths Tachometer Austin Healey 12
B For Sale MGA JAeger Fuel Gauge, Dual Safety Gauge, Speedometer and Tachometer MG Classifieds 0
B For Sale Austin Healey 100 Smiths Fuel Gauge, Dual Safety Gauge, Speedometer and Tachometer Austin Healey Classifieds 0
B For Sale Triumph Tr3 Fuel gauge Temp gauge Oil pressure gauge, speedometer tachometer Triumph Classifieds 0
T TR2/3/3A Noisy tachometer Triumph 9
S Intermittent operation of tachometer Austin Healey 9
Lin Tachometer/Dwell Meter Austin Healey 10
N Tachometer?? Spridgets 6
1 MGB Speedometer and tachometer on '66 MGB are not working MG 8
W Tachometer reads high when engine compartment heats up Austin Healey 3
D TR2/3/3A curious tachometer take-off Triumph 5
NutmegCT T-Series Tachometer repair MG 15
Boink Tachometer seize? Spridgets 11
Michael Oritt Electric tachometer connections--No Healey content Austin Healey 7
drooartz Geeking out over a tachometer Spridgets 15
C tachometer for XJ6 Jaguar 0
S TR4/4A Tachometer Triumph 5
GTP1960 TR2/3/3A Tachometer vs rpm analyzer? Triumph 5
Roger Lotus Elan S3 - Rev Counter [Tachometer] needed Lotus 4
5 Lazy Tachometer Spridgets 14
P I need a non-working electric tachometer for parts Spridgets 0
DanLewis Electronic tachometer for Bugeye Spridgets 18
J Mechanical tachometer to electric Austin Healey 11
J WTB: Bugeye Tachometer Blanking Plate Spridgets 11
B Smiths RVI Positive Ground Tachometer Bench Test ? Austin Healey 24
T BJ8 Tachometer and Fuel gauge stopped working. Austin Healey 27
Marvin Gruber Tachometer reading too high Jaguar 4
A Need Help with a Tachometer -- the drive portion. Austin Healey 1
M Quick tachometer wiring question on a '65 Spridgets 10
D Tachometer Triumph 9
L BJ8 Tachometer problem Austin Healey 6
P Tachometer versus lights Austin Healey 5
apbos Tachometer ID Smith's Rn1412/00 Spridgets 5
pkmh BJ8 Tachometer, "sparking" Austin Healey 35
G T-Series Tachometer and ignition switch MG 16
I Reproduction tachometer drive quality? Spridgets 4
K TR2/3/3A TR3 Dist Pedastal Tachometer Attachment? Triumph 3
K tachometer question Spridgets 9
B MGB MGB tachometer erratic, engine cutting out.... MG 11
F Ignition System/Electric Tachometer Triumph 9
F Spitfire Spitfire Electric Tachometer Problems Triumph 5
