Last couple days I've spent troubleshooting the non-working rev counter (tachometer) and clock. Finally figured out that the main shaft was frozen, which is why the drive cable kept snapping.
After lying on my back across the front seat, with the parking brake jammed into my kidneys and my left arm twisted up under the dash, I finally got it out. Took it apart, did some cleaning, let the drive shaft soak in my usual 50/50 mixture of acetone and ATF, and this morning it works. Also dis-assembled, cleaned and oiled the clock which is mounted in the tachometer, and got it working too.
Great to see it all back in order, but not looking forward to reinstalling it when the new cable arrives from Abingdon Spares. If you hear some colorful language from the general direction of New England, it'll be me, probably with my arm stuck behind the steering column..
I'm in big trouble - Abingdon Spares is only an hour away. The new owners are personable and helpful. I'm in *big* trouble.
On a different tack - Interesting MG story. The EX135 was quite a car.
https://primotipo.com/tag/mg-ex135/
Tom M.
Tom M.
