Tachometer ID Smith's Rn1412/00
apbos
Picked up this tachometer, with the hope it might work on my sprite. It is a 3:1 ratio and 4 3/4 OD. I am trying to get the working look of the Sebring Sprite I took the lower picture of a few years ago. I searched the web, but no luck finding out anything about it. I figure if the tacho cable fits it should work. Your thoughts? Thanks
Paul
dklawson
Being a 3:1 ratio tach you are correct that it should work without issue as long as it has the M12x1 thread on the back of the tach.
The needle type on that gauge is like what Smiths used in the 1950s. I have seen it on older Triumphs and Hillmans. I am sorry I cannot suggest what donor speedometer might match. If you do find a matching speedometer, in all likelihood you would need to have a ratio converter made to use it with the Bugeye's gearing.
Regardless, that is a very nice and clean looking period tachometer.
EDIT: Of course, the picture you posted of the Sprite shows it with what appears to be a "stock" speedometer so I assume I was wrong... you are not looking for a matching speedometer only the origin of the tach you have? Sorry if I misunderstood your intent.
I forgot that another car that used that style of gauge needle was the Nash Metropolitan.
apbos
apbos
Doug
Thanks for the info. The guy I purchased it from said it was from a Porsche 356. That does not seem likely. Before I cut my dash , I will make sure it works. I will stay with the original Speedo. The picture above is of a real Sebring Sprite! I is the car that won its class in 1959. Very cool car and is part of the inspiration for my Speedwell Sprite rally car.
paul
nomad
Can't wait to see your car when its done, Paul!
Kurt.
apbos
apbos
Here it is a few weeks ago. Getting ready for paint. We call it the "Spug":drunk:
:drunk:
nomad
Ah yes, I see you have eliminated the bug-eye's! Interesting look...you must be experimenting with streamlining!
Kurt.
B tachometer cable has a hole in it Restoration & Tools 7
F TR6 Tachometer lighting Triumph 8
S Engine or Tachometer Odd Problem Austin Healey 7
M Tachometer not working following ignition upgrade Austin Healey 10
Magyar Rebuild Speedometer & Tachometer - mechanical or electronic? Spridgets 17
S For Sale Early Sprite & Midget Speedometer/Tachometer/Generator etc. Spridgets Classified 2
E Oil leaking from the Tachometer cable Austin Healey 5
E MGB Tachometer 65 mgb MG 5
vette Just a note to Bill Young about his work with the electronic tachometer. Austin Healey 2
RAC68 Calibrate Smiths Tachometer Austin Healey 12
B For Sale MGA JAeger Fuel Gauge, Dual Safety Gauge, Speedometer and Tachometer MG Classifieds 0
B For Sale Austin Healey 100 Smiths Fuel Gauge, Dual Safety Gauge, Speedometer and Tachometer Austin Healey Classifieds 0
B For Sale Triumph Tr3 Fuel gauge Temp gauge Oil pressure gauge, speedometer tachometer Triumph Classifieds 0
T TR2/3/3A Noisy tachometer Triumph 9
S Intermittent operation of tachometer Austin Healey 9
Lin Tachometer/Dwell Meter Austin Healey 10
N Tachometer?? Spridgets 6
1 MGB Speedometer and tachometer on '66 MGB are not working MG 8
W Tachometer reads high when engine compartment heats up Austin Healey 3
D TR2/3/3A curious tachometer take-off Triumph 5
NutmegCT T-Series Tachometer repair MG 15
Boink Tachometer seize? Spridgets 11
Michael Oritt Electric tachometer connections--No Healey content Austin Healey 7
M TR2/3/3A Tachometer Malfunction Triumph 7
drooartz Geeking out over a tachometer Spridgets 15
C tachometer for XJ6 Jaguar 0
S TR4/4A Tachometer Triumph 5
GTP1960 TR2/3/3A Tachometer vs rpm analyzer? Triumph 5
Roger Lotus Elan S3 - Rev Counter [Tachometer] needed Lotus 4
5 Lazy Tachometer Spridgets 14
P I need a non-working electric tachometer for parts Spridgets 0
DanLewis Electronic tachometer for Bugeye Spridgets 18
J Mechanical tachometer to electric Austin Healey 11
J WTB: Bugeye Tachometer Blanking Plate Spridgets 11
B Smiths RVI Positive Ground Tachometer Bench Test ? Austin Healey 24
T BJ8 Tachometer and Fuel gauge stopped working. Austin Healey 27
Marvin Gruber Tachometer reading too high Jaguar 4
A Need Help with a Tachometer -- the drive portion. Austin Healey 1
M Quick tachometer wiring question on a '65 Spridgets 10
D Tachometer Triumph 9
L BJ8 Tachometer problem Austin Healey 6
P Tachometer versus lights Austin Healey 5
pkmh BJ8 Tachometer, "sparking" Austin Healey 35
G T-Series Tachometer and ignition switch MG 16
I Reproduction tachometer drive quality? Spridgets 4
K TR2/3/3A TR3 Dist Pedastal Tachometer Attachment? Triumph 3
K tachometer question Spridgets 9
B MGB MGB tachometer erratic, engine cutting out.... MG 11
F Ignition System/Electric Tachometer Triumph 9
F Spitfire Spitfire Electric Tachometer Problems Triumph 5
