Spitfire Spitfire Electric Tachometer Problems
Flatlander
I am trying to troubleshoot problems with the tachometer on my 77 Spitfire. My old tach was not working then finally I got it to work somewhat. It would seem to work properly during idle, registering 1100 rpm. When the gas pedal is pressed the needle would drop to 0 and remain there until the gas pedal is releasded and the engine returns to idle at which time the tach returns to 1100 rpm. I have tried using another tach out of a parts car with the same result. (I also thought about buying a cheap tach from Harbor Freight in order to rule out the tach.)
My thoughts are that either both tachs are bad and need to be rebuilt or there is something wrong with the voltage stabilizer. Any ideas? I have pulled the tach out of the dash and direct wired to the battery ground, power in dash and negative lead on the coil in order to rule out bad connections. Any way to check the working of the voltage stabilizer with a volt meter?
Thanks,
Gary
dklawson
The tachometer is not powered through/by the voltage stabilizer. If it is currently hooked up that way, change it so the tach is getting full battery voltage. However, since you have hooked the tach directly to the battery for testing, that doesn't really explain what is going on.
If you have a tune-up tachometer or engine analyzer, I would try that before investing even in a Harbor Freight tach. It seems odd to me that two tachs would have the same failure mode. I'd hate to see you buy another tach only to find out the problem is somewhere in the car.
What is really strange is that the tach is dropping out at higher RPM BUT the engine still revs. If the coil were failing I would expect you to report a bouncing needle at speed or that the engine misfires at higher RPM.
TR3driver
Great Pumpkin - R.I.P
What do you have for ignition? I think a 77 would have originally had one of those funky Lucas 'electronic' distributors, in which case I would suspect the electronics.
Doug is exactly right about the stabilizer, it should only supply power to the smaller gauges, not the tach.
F
Flatlander
I looked at the wiring diagram again and the power for the tach is shown going through the voltage stabilizer but not acted upon by the stabilizer. (I assume I am reading this correctly in that the "green" wire coming to the stabilizer is the "un-stabilized" voltage and the "light green" wire leaving to the fuel and temperature gauge is the "stabilized" voltage. So the voltage stabilizer has no impact on the tach.
Also the electronic ignition system has been removed and a points ignition system added.
Not sure what to try next.
DNK
Prolly just piggy backin of of the other green
dklawson
In Lucas wiring schemes, the "B" terminal of the voltage stabilizer is the "Battery" connection and is at full battery voltage whenever the ignition is on. That terminal is often used as a junction for other circuits. If your green wire goes to stabilizer "B", that is not going "through" the stabilizer.
Regardless, your test connecting the tach directly to the battery indicates that the problem is either in the distributor electronics, or (less likely) you have two tachometers that have failed in exactly the same manner.
K Spitfire Electric Fan- Spitfire Triumph 10
L Spitfire Spitfire electric fan installation... Triumph 11
motzart007 Wanted In search of used seats for 1969 Triumph Spitfire MKIII Triumph Classifieds 0
B For Sale GT6/Spitfire License Plate Light Assembly Triumph Classifieds 0
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
A Spitfire Spitfire Diff Pinion Seal? Triumph 2
3798j General TR Spitfire up in the Tree Triumph 2
E Spitfire '69 Spitfire hard top Triumph 2
D For Sale 1966 Spitfire 4 MK 2 for sale, Triumph Classifieds 1
R For Sale Spitfire MKIII projects Triumph Classifieds 0
Darwin Wanted Spitfire engine needed Triumph Classifieds 0
G Spitfire Spitfire 1500 differential whining Triumph 6
T Spitfire Spitfire MK2 Clutch Hydraulics Triumph 2
A Spitfire Spitfire Fuel pump issues Triumph 5
P Spitfire 1979 Triumph Spitfire starts then runs rough Triumph 2
Lairhead52 Wanted 78 Spitfire instrument panel lights / lenses Triumph Classifieds 3
D Spitfire 1980 California Spitfire, Help Figuring What To Do With It? Triumph 15
W Spitfire 1975 Spitfire 1500 shifting problems when hot Triumph 8
K Spitfire 1978 Spitfire possible Vapor Lock? Triumph 16
R Spitfire Turn signal wiring Spitfire Triumph 5
S Spitfire Spitfire 1296 engines Triumph 1
D Wanted WTB: Late Triumph Spitfire Top Frame Triumph Classifieds 8
C Spitfire 1967 Triumph Spitfire Triumph 2
Dnickels Spitfire Spitfire mk2 front suspension too soft Triumph 2
T For Sale One Owner 1969 Spitfire for sale Triumph Classifieds 0
Dnickels Spitfire Spitfire lighting issues Triumph 4
SteveTheBrewer Spitfire Spitfire Rebuild Update Triumph 5
Basil Spitfire 74 Spitfire Barn Find Triumph 1
I Spitfire Triumph Spitfire 1500 refuses to awake after 10 year hibernation Triumph 6
I Spitfire spitfire 1500 refuses to awake after 10 years Triumph 2
B Spitfire Mk3 seat rails Triumph Classifieds 0
M Spitfire 1500 LH Door Triumph Classifieds 0
P Spitfire Bits Triumph Classifieds 1
M 1976 Spitfire 1500 (RHD) Triumph Classifieds 2
B COMPLETE DROP-IN Rebuilt 1975/6 MG Midget 1500 engine PLUS rebuilt Spitfire Overdrive trans NEVER INSTALLED Spridgets Classified 2
FlyingCat Wanted 1980 Spitfire Rear Bumper Triumph Classifieds 2
SteveTheBrewer Spitfire Triumph Spitfire Restoration Blog Triumph 22
R Spitfire Spitfire 1500 Triumph 3
T Spitfire Spitfire lights Triumph 7
Basil Spitfire How do I adjust SU carbs on my Spitfire? Triumph 5
F Spitfire No output from coil HELP!! 1972 Spitfire 1.3L Accusspark Triumph 19
glemon Spitfire Spitfire Questions Triumph 7
tr6nitjulius General TR TR6*8 TR4*2 GT6 Spitfire Triumph 2
J For Sale 1974 Spitfire for sale Triumph Classifieds 0
F Spitfire Triumph Spitfire , what fuel to run Her on with no engine history? Triumph 11
J Spitfire 1979 Spitfire Running rough [sputtering, exhaust poping] at start up Triumph 2
eschneider Spitfire Float height - '64 spitfire w/ dual HS2 Triumph 1
S For Sale Triumph Spitfire Workshop Manual on CD/ROM - 1962 - 1978 Triumph Classifieds 0
