Tach Case Interior Colors
TexasSprite
I'm in the process of transplanting an electronic tachometer into my 59 BE and thought I'd repaint the interior. Note the two toned color scheme in the attached photo. For reference purposes the top hole is where the light bulb holder mounts, the bottom holder is where the light and shroud for the High Beam or Ignition lamp mounts.
Anyone know why the blue color?
I don't know that I've ever seen the two-tone color explained. However, most people I know of who have rebuilt or refurbished their gauges have painted the inside either gloss white or highly reflective silver.
Is your picture showing the donor movement in the BE gauge case?
Hard to see, almost looks like a shadow. As Doug mentioned I've seen most people go with a bright reflective white to try and get better gauge illumination.
If want to make it as it came from the factory and no one knows the answer I have a tach that I believe to be original will go track down and crack open.
FYI, the picture is of a case from a 67 Midget. It is a 4" case that will work in the bugeye. It has the advantage of already having the mounting holes for the tach electomagnetic movement I am transplanting the Bugeye tach face and adding new electronics to feed the existing movement. This is precipitated by the plan to replace the generator with an alternator.
For the most even lighting of the gauge face, paint the inside of the case matte white. Don't paint it glossy white. Glossy white will pick up dark reflections from the mechanicals in the case and give uneven lighting on the face. I think that dark color at the top of the case is just the result of a sloppy job at the factory and no real quality control.
I've noticed light blue paint inside most of the gauges that I've gone thru in the cars I've had. It seems to be universal regardless of make, year, or country of origin. I figured it was an optical trick, to color-correct the yellowish light of the gauge bulbs. That way the white numbers and pointers would look more white than yellow. Since the bottom light is shrouded, I guess the BMC guys just figured a shot of blue around the gauge light, where it would reflect the most, would suffice.
FWIW, I've always left my gauge interiors blue. (If memory serves, Testors' Robin's Egg Blue is a close match.)
I always restore the insides of my gauges.
I found a almost perfect match spray can color at one of the home improvement stores. American Accents is the brand and it's a pastel blueish green.
Check the caps, you will find it, I forget the exact color name, it's a foo-foo color name but it's real close to what the insides of the speedo and tach were.
I paint the white first, then mask it and paint the blue, then mask the holes from inside and spray the outside of the housing matte nickle.
For the little rubber tube at the ign and hi beam light, use a short piece of heat shrink tube. A piece that fits, do not shrink it on.
Anyone know a way to replace a missing or damaged ign or high beam jewel in these unit's???
KA.
Oh yea, get some of the file devider plastic tabs from your local Kmart or what ever. Use a hole punch and make a small button and glue it to the inside of the hole. You will never know the difference from the real thing.
How about a blue or red LED? You have to put a resistor in series with the LED to drop the 12 V car voltage down so as not to toast the LED, but the parts are very inexpensive. For those instruments that had the plastic "jewel", a small LED could be made to sit a bit proud of the Tach or Speedometer faceplate to duplicate the look of the original.
A dazzlingly bright LED may look out of place amidst the dim dreary glow of our instruments.
Maybe you could Lucasize the LED by dipping it in bearing grease first...? :jester:
TexasSprite Tach Case Interior Colors MG 3
B MGA Tach drive issue MG 1
S TR2/3/3A "Vintage" engine analyzer tach unstable? Triumph 14
Celtic 77 MGB Non working tach. MG 4
jackq Wanted Need a C Tach MG Classifieds 2
S Sticky Tach Spridgets 2
Joe Reed MGB Tach slow to wake up...why? MG 6
Lin Tach drive housing for BT7 Austin Healey 4
HealeyRick Tach Trouble Spridgets 2
W Tach wiring problems Jaguar 12
Marvin Gruber BJ7 tach cable location. Austin Healey 3
EWD TR6 ‘74 Tach Triumph 7
PAUL161 T-Series Lazy Tach MG 3
boxofparts MGB busy tach on 1979 MGB at 75 mph MG 3
J Speedometer Tach Correlation 1965 Austin Healey BJ8 Austin Healey 3
J 1965 BJ8 Tach Austin Healey 3
longbridgehealey Alternator conversion and tach Austin Healey 9
Healey Nut Mechanical tach drive Austin Healey 2
Healey Nut Mechanical tach drive assembly Austin Healey 4
S TR2/3/3A grounds the tach and speedo dash lights Triumph 1
S TR2/3/3A tach cable lubricant Triumph 4
D BT7 tach question Austin Healey 8
5 Tach Drive Generator for a Bugeye Spridgets 2
I Tach help Spridgets 3
Marvin Gruber BJ8 tach Austin Healey 9
Superwrench Tach not working Austin Healey 6
JimTR4 TR4/4A Capping off redundant tach cable connection Triumph 0
Zitch TR4/4A Tach and Speed inner gaskets Triumph 13
W Use of original Tach Spridgets 8
A Need help wiring my tach Spridgets 11
Patrick67BJ8 Tach Hookup Instructions from Nisonger Austin Healey 23
S TR5/TR250 tach problems Triumph 2
J Hunting tach and back fire TVR 8
B Longbridge 100-6 Tach Cable and Speedo Angle Drive Questions Austin Healey 7
M Tach generator gearbox Spridgets 6
M Strange Healey Tach Austin Healey 9
steveg Checking Healey Mechanical Tach at idle Austin Healey 3
busybrit Tach stops when flashers are turned on !! Jaguar 3
busybrit Electrical tach issue on Aston Martin DB5 Other British Cars 2
AngliaGT What Goes to the Left of the Tach? Spridgets 3
S TR2/3/3A speedo and tach until the weather gets better Triumph 3
J How can I tell if I have a negative ground tach? Austin Healey 5
E TR4/4A Speedo v Tach cable Triumph 2
rjc157 tach goes crazy Austin Healey 8
Sopwith_Camel tach-less Spridgets 11
B Lazy Tach Austin Healey 2
J Tach drive housing eccentric Austin Healey 14
G MGB Tach and speedo rebuild. MG 3
Schroeders T-Series TF Tach Calibration - DIY? MG 3
Darwin Spitfire Help wiring up a tach Triumph 9
