bthompson
Well, it finally happened. Rough running became hard start, became no start. Maybe you guys can help me diagnose!
<span style="color: #990000">Backstory:</span> It began with an intermittent miss in hard rains, accompanied with a fluctuating tach needle, last summer. A few months ago my electrics started dimming, most notably the right headlight. Then I noticed the miss was getting worse under <span style="font-style: italic">any </span>electrical load. A week ago, It would stumble noticeably with the turn signals or brake lights. Brake lights plus turn sigs would kill the engine. Then it ran with a stumble with the lights on, and <span style="font-style: italic">anything </span>else would kill the engine. The battery seemed sluggish, as if it wasn't charging fully. An overnight trickle charge didn't affect the problem.
<span style="color: #CC0000">Troubleshooting:</span> Air+fuel+spark=run.
Air: I checked the intake manifold, and the bottom two nuts were loose to the point that the clamps were free. Tightened them back up, resolving a possible air leak. Valves are adjusted. Compression is good.
Fuel: Checked the fuel pump for adequate delivery. Check. DGV accel pump squirts. Check.
That leaves spark. I've replaced the cap, rotor, wires, and plugs recently. I have the Pertronix in the the dizzy. I get a spark from the coil upon cranking. The spark timing is correct.
<span style="color: #CC0000">Observation:</span> The battery shows full voltage. The alternator light on the dash does not light until the engine dies completely. I take this to mean the alternator/battery relationship is working. I get 9v from the battery under load, and 7v at the solenoid. The solenoid gets hella hot while cranking. It cranks slowly, but doesn't catch -- not even with a shot of starting fluid.
I'm stumped. There's not a lot that gets in the way of the ignition circuits. The lead from the batt goes straight to the solenoid, from there to the coil, from there to the dizz, from there to the plugs. How can accessories kill the primary voltage that easily?
Possibilities: Weak battery? Wouldn't that show on the dash light?
Weak coil? Spark is spark; but not enough to light off ether?
Weak connection? The only real junction is the solenoid. Not enough juice to spin the engine I could see, but the coil is sparking, which means the secondaries are getting juice, and the pertronix is tripping.
What am I missing? I've gotta be overlooking something easy. Heck, <span style="font-style: italic">everything </span>is something easy in a Midget. I've ordered a new solenoid from Moss to be on the safe side, but I'm gonna be rather bummed if that doesn't do the trick.
