Stock Cam Timing
Morris
I am getting ready to put the stock cam back into my Midget 1500. Last time I use the timing marks to line everything up, and it seemed to go okay, but I am wondering if I can do better.
How can I check my cam timing to make sure it is dead spot on? Step by step instruction would be extremely helpful.
GB1
You will need a degree wheel, dial indicator and a base stand.
I have done it this way for years, but other forum members have told me that it is not necessary for a street going LBC.
If you need to purchase these items, I would recommend the old fashioned method.
Patrick
racingenglishcars
There's a nice bit on cam timing at minimania here. It sort of requires knowing the specs, but there is something about aligning equal lifts of inlet and exhaust valves at tdc.
I get to do this myself sometime soon, but I'm using a Kent cam with different lift and duration for inlet and exh. If you are using a standard cam, it is most likely the same lift and duration for both.
Donn
Morris
Morris
I have a dial and base. Is a degree wheel something I can pick up at my local auto parts store?
GB1
They may have it, if not any reputable place should. They are not that expensive.
I basically do it the same way as Donn's link, but without the head installed and using pushrods instead. This allows me to insure that I have TDC by putting the indicator on the piston.
Also for A series we use offset keys to adjust, I am unsure what the Rumph engine uses.
Patrick
Morris
Morris
With the gear I have, it seems the only adustment I can make is to move the chain over a tooth.
GB1
That would be too much.
Moss pn 327-220 should be sold by someone for your engine in 1-8 degree offsets.
Not being a 1500 guy, I do not know where you could get one.
Patrick
spitbits?
Westfield_XI
Patrick
You can do without the dial indicator if all you are doing is finding the lobe centers and then adjusting the timing. You just need some way of finding TDC: a stop or even a pencil riding up and down on the piston crown in a spark plug hole will do. A dial indicator is only required if you are going to measure lift or to check the timing at some specified amount of valve opening. Simply "degreeing" a cam can be done without much investment in precision measureing tools if you are a "shadetree mechanic".
GB1
I was going for the most accurate method that I know of, I believed that this is what Morris was looking for.
Patrick
Morris
Morris
WestfieldVII,
Could you please give a step by step description of how to degree a cam shade-tree style?
I am not 100% positive on this, but i think you will find that you can reverse the cam sprocket and also rotate the sprocket thru 180ª to make finer adjustments.
mark
Westfield_XI
IIRC I used a pencil with a line marked on it to indicate the piston position. Attach your degree wheel to the crank pully along with some sort of a pointer so that you can accurately indicate timing. Don't worry which number the pointer points to yet.
Now rotate the crank in the normal direction watching the pencil in #1 cylinder go up and down, sighting across the edge of the plug hole will allow you to stop the crank as your mark on the pencil lines up with the edge of the hole. Write down your degrees indicated by the pointer and continue to turn the crank as the pencil rises with the piston. It will reach TDC (top dead center) and begin to fall as the piston drops. Watch for your mark on the pencil and stop the crank when the pencil lines up exactly as it did before. Now write down the number from your degree wheel. Half way between the 1st and 2nd measurement is TDC. Repeat a couple of times to verify you are correct and stop the crankshaft at the number you calculated to be TDC.
Loosen the degree wheel and rotate it until the pointer reads 0, now the degree wheel is set to top dead center #1 cyl on compression stroke. Use the same method as before to find the degree at which the intake valve opens on #1 cyl, only use a thin feeler gage to feel when the cam lobe begins to touch the valve. Check the reading when the valve opens and again when it closes releasing the feeler gage. This will tell you lobe center of the cam.
A couple things to note:
1. Always turn the engine in the normal direction of rotation. If you go past your mark and have to rotate backwards, go back a 1/4 turn before proceeding again in the correct direction. This will remove any slack in the valvetrain and give a more accurate reading.
2. Make sure that #1 cyl. is on compression be checking the rocker arms for looseness. Intake and exhaust valves will both be seated with loose rockers on compression stroke.
3. It may be a bit easier to check the valves by introducing an extra bit of clearance to the valve adjustment, perhaps .010" or so.
I hope any readers will correct anything I may have left out.......
Morris
Morris
This is great! Thanks!
Once I know "lobe center" how can I use that knowledge to tell if my cam is properly timed?
If you match up the dots and then degree the cam you should see something in the 108-110 range give or take, if you're a tooth off that something like 16 degrees if I'm not mistaken, so you'll know you are wrong by your degree wheel readings. Try getting about a 3 degree off set keyweay, and advance the cam, this will wake up the midrange acceleration of the motor, pretty common with race cams and performance street cam, so the same thing should work for a stock cam. Most of the performance street cam I use in motors are on a 106-108 center line, most race cam 102-104, so expect the stock cam to be a little more than the performance street cams. With the cam in the block and a degree wheel mounted you can find out anything you want to about a cam, lift, centerline, duration etc..
Morris
Morris
Sorry for being a dunder head, but I want to make sure I understand this...
I found these specs for a stock 1500 cam on Paul Teglar's site.
Seat Duration: 247°
Intake: 18-58°
Exhaust: 58-18°
Lobe centers: 112°
So, if I use the techniques described above, starting from TDC before the intake stroke on #1, my intake valve should open at 18 and close at 58.
Right?
Starting from the same place, I could check the exhaust on #4, and it should open and close at the same time... right?
Morris
Morris
Sadly, I don't have a BMC camshaft. Mine is a BL. /bcforum/images/%%GRAEMLIN_URL%%/wink.gif
Dadandson Stock Cam VS Performance Cam Spridgets 1
D Stock Camshaft TVR 0
jfarris For Sale TR3 Stock Fan used (1956) Triumph Classifieds 0
V MGB Stock Alloy Wheels from Other Cars That Fit 4 114.3 and 14" with correct offset? MG 10
nichola TR6 Stock exhaust sound... short video Triumph 4
Joel Lester TR2/3/3A Are all "stock" camshafts the same? Triumph 9
F Wanted wanted new old stock driver side door latch Triumph Classifieds 2
johnrip Wedge Tires for TR7 stock alloy wheels Triumph 1
steveg TR6 Installing stock trailing arm bushings on the car - is it possible? Triumph 2
S TR2/3/3A stock fog light Triumph 2
PC Actually in stock? Spotted 0
S TR2/3/3A Stock air cleaners and aftermarket air cleaners. Triumph 7
S TR2/3/3A Mounting a stock steering wheel. Triumph 3
M TR4/4A Fuel Line Fittings - Stock or Upgrade? Triumph 6
R Upgraded rod bolts for stock rods Austin Healey 1
S New Build Stock Wheels? Spridgets 38
T How to add a bit more realiability/endurance to a stock 1275 engine rebuild? Spridgets 9
B Wanted stock Bj8 distributor Austin Healey Classifieds 1
S For Sale Triumph tr3 tr3a tr3b tr4 tr4a differential cover new old stock Triumph Classifieds 0
simon1966 Rarity of Stock 100! :-] Austin Healey 13
T Front Tilt or Stock Fit Bonnet Spridgets 18
I Tips for installing intake manifold plugs in a stock Bugeye? Spridgets 6
S For Sale Tr3 tr3a tr3b tr4 tr4a differential cover new old stock Triumph Classifieds 0
Jim_Gruber Thoughts on stock '69 1275 manifold vs LCB Headers for street use Spridgets 9
T Tilting the stock seat for comfort Spridgets 6
simon1966 Does taking a stock BN1 and adding M bits increase its value? Austin Healey 10
T WW Axles in stock Bugeye housing? Spridgets 7
L Modifying stock shift surround for Datsun 5 speed Spridgets 20
K TR4/4A Stock Triumph Radio Troubleshooting? Triumph 4
C Smaller diameter steering wheel - that looks like stock? Austin Healey 16
G TR6 TR6 air filter element replacements for stock housing Triumph 3
CJD TR2/3/3A Stock Valve Lift Triumph 3
RJS TR4/4A TR4A Stock Ride Height - my measurements Triumph 0
CJD General TR BSW thread stock Triumph 2
T TR4/4A Flywheel... Lightened or Stock, that is the question Triumph 14
RJS TR4/4A TR4A Stock Ride Height Triumph 5
Gerard Anybody have a steering wheel emblem for '68 Sprite stock steering wheel? Spridgets 11
Jim_Gruber Tire Size and Stock BE Wheels Spridgets 40
K TR2/3/3A Lightening a stock TR3A flywheel..... Triumph 13
M Healey Mk2 with Colored stock steering Wheel Austin Healey 3
B Found more unopened stock to ofer/trade/giveaway to a good home Spridgets 0
C Stock seat belt color? Austin Healey 11
K Converting a MkII with a V8 back to stock Jag 6? Jaguar 3
Ed_K Modifing the stock BJ8 air cleaners Austin Healey 0
T TR2/3/3A Attaching HS6s to the stock TR3 manifold. Triumph 3
D Stock oil filter vs spin on filter Austin Healey 17
R Planing my built. Stock vs transplant Spridgets 58
T Single Weber Redline carb for stock Midget 1275 Spridgets 12
T stock bugeye front springs Spridgets 4
T Milling a head on a Stock 1275 for compression? Spridgets 13
